Question about Logitech Extreme 3D Pro Joystick
Logitech Extreme 3D Pro will not work with Flight Simulator 2000 in Windows 8
I downloaded the latest Logitech Profiler and successfully ran the calibration test for the joystick. Flight Simulator 2000 successfully loaded on Windows 8. After opening Flight Simulator 2000, I selected Options/Controls/Calibrate Joystick from the menu. In the Settings tab, the joystick calibrated properly but in the Test tab, the Slider/ Throttle did not register. When I try to take off, the throttle will not work nor will the joystick lift off, land or bank the plane. If I assign a specific key on the joystick to the Full Throttle event through the Assignment function from the Options menu, it will work. The program or operating system does not seem to recognize what the joystick defaults should be.
  • 16 Answers
SOURCE: 3d pro joystick
There is now.
Visit: http://www.logitech.com/index.cfm/441/291&cl=us,en to download the driver.
Posted on Dec 16, 2007
dotball
  • 64 Answers
SOURCE: installed joystick extreme 3d pro wiil not work
Sometimes on those games, if you used a mouse originally, they do not auto-detect that ur using a joystick now - go into the options tell the game ur using a joystick and also there you may be able to set custom control features (what button does what).
Please let us know how it went.
**.The best way to acknowledge contribution is to rate it's relevance.**
Posted on Feb 02, 2009
SOURCE: I need calibration software for the logitec 3d pro
this was not originaly my post but i saved it.and it worked for me. HOW TO CALIBRATE THE LOGITECH EXTREME 3D PRO JOYSTICK
I just figured out how to calibrate this joystick. I am using Windows XP. I assume it will work with all Windows operarting systems though.
Go to Control Panel, click on "Game Controllers", or however you get to your joystick settings. Hold down the "Ctrl" (control key) and the "Shift" key together - at the same time, THEN click your mouse on the "Properties". This should take you to a different calibration screen that you would get to without holding the two keys together. IMPORTANT - Click on the "Test" tab first. If you go to the settings tab first, it likely will not work. Without doing anything else after clicking on the "Test" tab, next click on the "Settings" tab. Then click on the "Calibrate" button below. Click "next". Click the thumb button on the left side of the joystick which should bring you to another screen. Then follow the prompts......
* On the "axis calibration", move your joystick in full circles, making sure the "+" symbol moves around the far margins of the square. After a few complete circles, click the "next" button with your mouse.
* On the next screen, click the left button on the joystick again, which should bring you to the next screen. Move the throttle lever back and forth a few times. Then click "next" again.
* On the "Z rotation screen", move the joystick to the left and right (rotate it) a few times. Then click "next" and then "finish" then "ok". Thats it. It should be calibrated now. Hope this helps everyone with problems.
Posted on Jul 08, 2010
  • 2678 Answers
SOURCE: can't get all the buttons to work with SIM tractor
If you haven't already download the correct drivers from here
Posted on Jan 12, 2011
e-Guru
  • 3917 Answers
SOURCE: twist handle on logitech extreme
Hi
Go to Control Panel, click on "Game Controllers", or however you get to your joystick settings. Hold down the "Ctrl" (control key) and the "Shift" key together - at the same time, then click your mouse on the "Properties". This should take you to a different calibration screen that you would get to without holding the two keys together.
Please check the bellow links to read the article for the tutorial:-
http://forums.bf2s.com/viewtopic.php?id=81419
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Posted on Jan 14, 2011
Why won't Microsoft Combat Flight Simulator for Windows 98 recognize my logitech joystick?
click on the joystick and then click on the properties tab
check and adjust compatibility
tick the box and move down the list to win 7 and click that ---apply and ok
it sound slike a compatibility fault or a missing driver for the joystick
Mar 15, 2017 | Logitech Extreme 3D Pro Joystick
Do i need an installation disk for the extreme 3d pro joystick if I'm using it with a mac
Follow the below guide from Logitech.....
The following Logitech gaming devices will function on a Macintosh computer running Mac OS 9 with Input Sprockets 1.7 or higher. You must also have a functioning USB port.
Logitech® Freedom™ 2.4
Logitech® Dual Action™ Gamepad
Logitech® Extreme™ 3D Pro
Logitech® Attack™ 3
WingMan® Attack™ 2 on the USB port
WingMan® ActionPad™
WingMan® Formula™ GP on the USB port
WingMan® Precision GamePad (USB version only)
WingMan® Extreme™ Digital 3D
WingMan® Formula™ USB
WingMan® GamePad USB
These devices will use the Mac OS Human Interface Device (HID) support. If you are experiencing detection problems using one of the supported devices on a Mac, please contact Apple to ensure your computer meets these requirements. If you are experiencing problems in a particular game, please contact the game manufacturer.
To determine if your Logitech game controller is detected please do the following:
  1. OS 9.x
  2. Click the "Apple Menu".
  3. Click "System Profiler".
  4. Click the "Devices and volumes" tab.
  5. Look at the USB tree to confirm that the controller is listed.
  1. OS 10.x (Traditional View)
  2. Double click the "Hard Drive" icon.
  3. Double click the "Applications" folder.
  4. Double click the "Utilities" folder.
  5. Double click "System Profiler".
  6. Click the "Devices and volumes" tab.
  7. Look at the USB tree to confirm that the controller is listed.
Jul 19, 2010 | Logitech Extreme 3D Pro Joystick
MCFS Joystick Problem
Make sure, that your Joystick is compatible with the version you are having problems with. If not, make sure that it's enabled in the configuration of MCFS. If none of those work, you will most likely have to purchase a more compatible Joystick.
Matt P,
Computer/Gaming Relations Team.
Sep 16, 2009 | Microsoft SideWinder Precision Pro 2.0...
Wingman extreme will not work with my vista.
Changing the game to work in compatibility mode for windows xp may solve your problem. right click the game >properties >compatibility and set to windows xp. Good luck!
May 27, 2009 | Logitech WingMan Extreme Digital 3D...
Installed joystick extreme 3d pro wiil not work
Feb 02, 2009 | Logitech Extreme 3D Pro Joystick
When I bank right or left with joystick the screen Freezes
To check the joystick isn't the problem, go into control panel game controls, then check that the joystick appears and you can move the cross-hair around on screen, most modern joysticks are
auto-calibrating, but you could try running the calibration.
To check the game isn't a problem, unplug the joystick, then use the arrow keys to fly the plane, if it doesn't crash when you bank then it isn't the game.
I assume the game is Combat Flight Simulator 3, as very old games that were written for Windows 95,98,ME series often won't run on Windows NT,2000,XP,Vista as they are completely different versions of Windows. If this is actually Flight Simulator 3, you may need to consider buying a later version of Flight Simulator (FSX is the latest version, but may not run on your laptop).
Other things to try are updating the graphics card driver.
Norton shouldn't need deactivating, although it could cause problems if you're playing online.
Also remember that laptop graphics cards are never as powerful as desktop graphics, and games very rarely specifically support laptop graphics.
Hope this helps.
Jan 21, 2009 | Logitech Extreme 3D Pro Joystick
Instalation problem, Extreme 3D pro
If it is the game controller you are talking about then yes you just need to get the driver here
Dec 09, 2008 | Logitech Extreme 3D Pro Joystick
Flight simulator
Have you tried to set the control sensitivities on FS ? Try turning them down and try again. JLS
Aug 28, 2008 | Logitech Extreme 3D Pro Joystick
Joy stick
this worked for me, i have a ibookg4 and all all my dad had to do (complete nerd) had to do was REBOOT THE COMPUTER WITH THE JOYSTICK PLUGGED IN and the joystick worked after that.  Posted by his dumb as a post sun...
Dec 20, 2007 | Logitech Extreme 3D Pro Joystick
Logitech Extreme 3D Pro Joystick Logo
47 people viewed this question
Top Logitech Video Game Consoles & Games Experts
Zhenya Ogorodnikov
Alun Cox
Are you a Logitech Video Game Console and Game Expert? Answer questions, earn points and help others
