Question about Xerox DocuMate 262 Path-Through Scanner
Constant paper jam - Xerox DocuMate 262 Path-Through Scanner
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 99 Answers
Clean inside
Posted on Mar 19, 2016
Getting a constant "Paper Jam 071-100" error when printing from Tray 1 (no jam found).
You need to replace the paper pick up, feed rollers and separation sub-assebly.
Nov 27, 2012 | Dell 3115CN
Constant paper jams
Open the printer and with a blower clean it thoroughly.
This resolves the paper jam issue many times.
Nov 16, 2011 | IBM Infoprint 1332 Laser Printer
Constant paper jam on Canon PC735 copier. Tried all the usual steps to removing or preventing as paper jam, and they are not helping. The problem started after the cartridge was removed and rocked back...
If the machine did not show a paper jam until the toner cartridge was removed and then reinstalled, I would remove the cartridge and check the paper path for the paper switch, it normally is a small black lever. Make sure it isn't stuck in the down position. If the switch is OK, check the cartridge to be sure there isn't any damage that may cause the paper switch to be actuated when the cartridge is installed into the machine. Sometimes there is a protective cover on the cartridge that moves when installed, this cover can be knocked out of place.
Jul 19, 2017 | Canon Office Equipment & Supplies
How do you fix a paper jam?
remove all paper from printer,then check the paper path,if error persists then u should check the sensors,remember when the paper jams its important to get it out in one peice if not you can jam a sensor causing a constant paper jam error,hope this helps
Nov 18, 2009 | HP LaserJet 1012 Printer
Msg is paper jam when there is no paper jam
I had what seems to be a similar problem and the issue was that the rubber "feet" that grab the paper weren't grabbing anymore. So, I constantly got a paper jam reading. I read elsewhere to wipe some glass cleaner/ammonia on the "feet" so that they become "sticky" again. When I did this, the "Feet" or rubber semi-circle parts that rotate around a metal bar then started to correctly grab the paper again and the error stopped.
Aug 31, 2009 | Konica Minolta magicolor 2300DL Laser...
Constant Paper jams on CLX-3175FN
The fact that there appears to be no actual jam tells me that it is not picking up paper out of the tray. Try some alcohol on the pickup rollers, rubbing well. If that helps, replace these rollers.
Aug 12, 2009 | Samsung CLX-3175FN Color Laser All-in-One...
All of the sudden, constant paper jams & no paper signal when ful
You can clean them from the rear access/jam cover. Just be careful when turning the rollers, must be slow and smooth movement.
Aug 04, 2009 | HP PSC 1610 All-In-One InkJet Printer
ADF (automatic document feeder) constantly jams
change paper pick-up roller & paper stop roller in ADF
Oct 30, 2008 | Brother MFC-8840D All-In-One Laser Printer
PAPER JAMS CONSTANTLY
Well, it might be theres something stuck in there. Pick it up and give it a few shakes. I work on printers, and not too long ago I found a wedding ring, paperclip, banana sticker and other things in printers. If that doesn't work, try going to staples and getting a laser cleaner kit. They're basically sheets coated to pick up any paper dust, or bits of paper that might be clogging the path
Mar 11, 2008 | Brother HL-2070N Laser Printer
Xerox DocuMate 262 Path-Through Scanner Logo
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
