Question about Hannspree HannsPad SN10T1
My hannspree tablet would not allow me to go on the internet eventhough it says it is connected
Why wont my ipad connect to internet . all that it does is give the name of ipad but nothing more , why is this ?
Unless your tablet has 3g/4G LTE data plan from a cellular provider you will need to use a WiFi access point. No idea about your tech ability so does this make sense to you?
Oct 21, 2015 | Hannspree 10.1" Android Tablet Grey Tablet...
Why wont my hannspree 10.1" tablet connect to onboard cameras?
to contact a camera, you need a correct working camera app. If the app you try to use does not work, reinstall the app, or choose another app from the App Store.
Jul 22, 2014 | Hannspree HannsPad SN10T1
How do I adjust brightness on hannspree tablet
Go to Settings, Display, Brightness. If you have never accessed Settings, do a finger slide from the edge of the screen where you see the battery indicator symbol, and you should see an option for Settings (or a small symbol at top right that looks like a cog such as you see where the chain connects to the back wheel on a bike). Selecting/touching that will open the full Settings menu. Then scroll down until you see Display, touch that, and then find Brightness and touch that. Then you should see a slider. You should also see an option for Automatic brightness control. Some tablets come with this selected by default. Choosing it will cause the tablet to brighten when outdoors or in a brightly lit room, and to dim automatically when lighting is low. I have never liked it, but it works for a lot of people who are not as picky as me, and can potentially allow your battery to last longer. Good luck and enjoy your tablet!
Jul 17, 2014 | Hannspree SN10T1 101 Tablet
How to fix camera can not connect on hannspree tablet
Hard reset your tablet , if your tablet is updated the camera stops functioning. Hold power and Up or Down volume button to hard reset.
Jun 28, 2014 | Hannspree SN10T1 101 Tablet
I have a hannspree SN1AT71WEE301 i cannot connect to the camera is there an easy fix.
Assuming the built in cameras are the issue,
\are you using the provided software ?
You can try to update the ROM and / or drivers for those devices.
sometimes an update may not install properly and re-updating the ROM and / or specific device drivers would solve the issue
Attached is a link for the English device manual:
http://www.hannspree.eu/uploads/Downloads/TabletPC/UM/SN1AT71/SN1AT71_User-s_Manual_EN.pdf
If you are having difficulties with the device recognizing an attached camera device, you may need to go to camera device manufacturer website and download the appropriate drivers to match your tablet device operating system and connection type.
Ex: USB driver for camera connecting using a usb port connection. Also ... confirm proper cable is being used.
Ex: Some connections require 5 contact point cables, others only 4 contacts - this will be determined by your devices.
I hope this was helpful.
May 08, 2014 | Hannspree SN10T1 101 Tablet
Cannot connect camera error
Mine has stopped working as well. I did as restore, deleting everything. Don't bother. It didn't fix it. I am calling Hannspree today and will post here if there is a solution,
Apr 04, 2014 | Hannspree SN10T1 101 Tablet
I can not connect to internet with my stealthg2 eventhough wifi strength strong
check to see if it's doing MAC filtering(turned on) if so you need to add your mac address for the device
Dec 27, 2013 | Mach Speed Trio Stealth G2 Tablet -...
Hannspree Hannspad user manual
My 10.1 hannspreed tablet will not download free games after I reset it to factory,what did I miss ?
Feb 14, 2013 | Hannspree HANNSpad Tablet User Manual
Hannspree HannsPad SN10T1 Logo
Top Hannspree Tablets & eReaders Experts
David Payne
David Payne
yobo007
yobo007
ka4iup
ka4iup
Are you a Hannspree Tablet and eReader Expert? Answer questions, earn points and help others
