Question about Panasonic TC-P58V10 Plasma TV
Continuous blinking light on Panasonic Plasma
TV does not turn on via remote. If I press the power button randomly, the TV eventually powers on.
  • 3 Answers
Had the same problem wih my panasonic, it was a faulty power switch. make sure the power switch is sitting centrally in its housing, if not you may need a new switch
Posted on Jan 02, 2014
SOURCE: TV won't turn on.
hi i had the same problem,
did you check the fuse if it looks burnt out you can get a new one from a b&q or a hardware store
hope it helped
Posted on Oct 05, 2008
  • 61 Answers
SOURCE: Power light blinking 2 times
2 blinks means the unit is having problem with 12 volt supply.
while power on you can check 12DC on power supply before shutdown.if the voltage is constant before shut down I would recommend to replace D board.
Posted on Oct 09, 2008
SOURCE: Panasonic remote and volume/channel buttons do not work
My son put a penny in the SD card slot of my Pansonic flat screen tv. I finally got the penny out but now the volume and tv controls do not work. I can change the channels through my cable box but that is it. The volume does not work on my cable remote or the flatscreen. What do you suggest I do to fix this problem?? Thanks, Josh
Posted on Aug 23, 2009
phil_frye
  • 295 Answers
SOURCE: Panasonic plasma 50PZ85 power led blink 10 times
Either a bad power supply or a bad processor board.
A Good Service Shop should know what the 10 blinks are indicating.
May be a repair cost between $200 and 400 dollars.
Be prepared -
Blessings,
A/V Media Guy
Posted on Nov 22, 2009
  • 12 Answers
SOURCE: I have a panasonic flat panel tv 1080i. 46
the s1 models have been having several problems. it really depends on how many times the red led is blinking. panasonic uses a certain number of blinks to tell you what board has failed. the s1 models have just recently come out. therefore your tv should still be under manufacturer warranty. call panasonic and see if there is a servicer in your area. our company is in dallas texas. Aces Tv Service.
Posted on Mar 04, 2010
My COby tv wont turn on.
I unplugged my TV for 5 minutes after 5 minutes I pressed the Power button on the side of the TV not the power button on remote for a full minute. Plugged the TV back in, pressed the power button and it turned on. Doing this essentially does a reset.
Dec 26, 2016 | Coby Televison & Video
There is a blinking red light next to power button.Panasonic tv will not turn on.
1. Subject
Information of LED Flashing timing chart.
2. Contents
When an abnormality has occurred the unit, the protection circuit operates and reset to the stand by mode. At this time, the
defective block can be identified by the number of blinks of the Power LED on the front panel of the unit.
Hopefully it eventually stops blinking after unplugging set from the outlet, otherwise claim your Nobel Prize for wireless energy transmission.
Oct 17, 2014 | Panasonic Viera TH-50PZ80U Plasma TV
Medion lcd hd 31.5 inch tv won't turn on
I bought one also from ALDI for my son's Xbox 360, it is only 3 weeks in use and I have the same problem. The red led is on, indicating that it is in standby mode and recieving power but I can't turn it on either by pressing the power on button on the TV it's self or the on button on the remote. This started happening a few days ago and it's totally random. I found that if you unplug the TV from the power point or alternatively switch off the power point for a minute, than power it on again it will "WORK AGAIN" for a while. Like I said it is random, eventually it will return to the not being able to be switched on state at which time you will have to repeat the process. So thus, this is not really a solution. I am about to return the TV for a refund, and it's a shame because otherwise it's not too bad. and looks OK too.
Jan 21, 2013 | LG 37LC7D 37 in. LCD HDTV
One for all remote codes don't work URC-3920
Hi keep teaching should come up with more if still dosent work try one for all web site or phone them very helpful
Aug 04, 2012 | Televison & Video
Lg w2234s-bn Monitor Cycling randomly through Light View Modes/Power Button turning It's self on and off.
On and off cycleing could be caused by a bad power supply or a low battery on your remote. Check them both out. Good luck.
Apr 28, 2012 | LG 22" FLATRON LCD Monitor
I need a code to program a remote for a sanyo tv
all you need to do is press the code search button until the red light is on then press tv button...then point the remote at the tv and continue to press the power button until your tv turns on/off...then press enter. Be patient...it may take any wear from 2 or three clicks up to 100 clicks....but it will eventually operate your television....be careful though...if you press the power button even 1 more time after it turns your tv on or off...you will have to start all over....Good luck! and if this doesnt work..you can always buy a universal remote from any department store..some are as cheep as 5.00. and they all come with program guides.
Nov 03, 2011 | Sanyo DP42849 42 in. HDTV
I just hooked my insignia t.v. to dishnet work but there codes do not control my t.v.
Depending on the age of the dish paperwork you might be able to get some newer codes from dishes website. There is a slim chance that you might find some codes from Insignia for the dish remote; and some times you can reverse it and program your tv remote for the dish box. Other than that they should have a step by step on how to find a code that will work with your tv. Usually its something like have the tv powered up and then on the remote press and hold a couple of buttons until you get a light code on the remote (flashing or solid) then. Something like press tv then power, wait, tv then power, wait, etc. And eventually the tv will turn off. Its laborious but that will usually, eventually, work.
Good luck.
Apr 15, 2011 | Insignia Televison & Video
I have an aquios LC-42D64U which suddenly has the following two lights blinking power & OPC. They both blink, once together, the second blink is only the power, and repeating the sequence. I've...
Sharp LED/LCD EEP cleared Step 1 Remove Mains Plug 2 Press On/Off Switch from LED/LCD Panel 3 Press Ch Down & Input Switch together and plug in mains cord 4 LED/LCD will start 5 "K" will appier on Screen 6 Press Ch Down & Vol Down from LED/LED Panel 7 1/9 Page will appier on Screen 8 Go to 9/10 page by pressing Up & Down arrow of remote 9 Select EEP Cleared 10 Press ok button from remote 11 On Screen dispay EEP running 12 Remove Mains Plug after complete EEP Run 13 Restart LED/LCD
Feb 05, 2011 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Panasonic TC-P58V10 Plasma TV Logo
82 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
