Switch to hdmi - Televison & Video
    Master:
  • 708 Answers
Hdmi splitter and hdmi switch are different,pls get that,more details:
Amazon com MALLCROWN 4 Port 1080p HDMI Splitter with Ac Power adapter...
Posted on Nov 20, 2016
    New Friend:
You need to check HDMI Splitter, Switcher and Matrix products.
Posted on Oct 30, 2014
    New Friend:
Http://lsm-video.en.alibaba.com/
3DHDMI Splitter, 4k HDTV SPLITTER
3DHDMI Switcher, 4k HDTV SPLITTER
3DHDMI Converter,Audio
Splitter,Audio Converter,Audio
Matrix and others AV Products.
You are welcome to contact us today.
Duke Chu
Posted on Jan 03, 2014
My sat box is connected to hdmi tv with hdmi cable and scart lead, but when i switch on in morning will not go to tv
You don't need the scart if you're using HDMI. However, the TV will not auto-switch with an HDMI connection.
If your TV does not switch on remembering its previous settings, you'll need to reselect HDMI each day.
Feb 27, 2014 | Televison & Video
Dear Sir/Madam : Re: ONKYO HT-SR800 7.1 ch HOME THEATER SYSTEM The system will not deliver video output in television mode . Audio is fine . Initially , I press the...
Check the input selector on the TV, if you have audio only then it is a cable problem,
that means that cables are not connected in the right way.
Oct 10, 2008 | Onkyo Televison & Video
TV box is not working wend Is connected to HDMI switch.
CONNECT IT AGAIN TO HDMI INPUT AND CHANGE SOURCE ON THE TV SETTINGS INPUT SHOULD BE HDMI1
Jan 31, 2014 | AUVIO 4-In/1-Out HDMI Selector Switch with...
How can I to control multiple HDTVs in several different rooms via a HDMI matrix switch?
There are HDBaseT HDMI Matrix solutions for applications like yours. I would recommend to visit KVMSwitchTech as they offer a wide range of 4x4 HDMI Matrix and 8x8 HDMI Matrix solutions with HDBaseT support and zone remotes.
http://www.kvmswitchtech.com/8x8-cat5e67-hdmi-matrix-switch-with-hdbaset-over-single-cat5e67-cable-includes-8-hdbaset-receivers-p50030.htm
Apr 04, 2013 | Aten 4x4 HDMI Matrix Switch witch
Connecting Ps3 with philips tv (full hd) when i got hd cable in, and click to switch so the ps3 uses hd to show things and i than switch over to the channel i plugin the hdmi cabel it gives blac kscreen
If it's the first time using your PS3, use the composite cables that came with it. Turn on the PS3 go to video settings and switch the input to HDMI. After you've switched to HDMI, turn the PS3 off and connect your HDMI cable, go back to video settings and change the resolution to 1080p. If this isn't the first time you've used HDMI for your PS3, make sure your T.V. is on the correct input. If the T.V. is on the correct input, try switching the HDMI cable to a different input. If that doesn't work try using a different HDMI cable, testing different HDMI connections if you're still getting the black screen. If none of those work then it's probably a problem with the PS3, but just to make sure try plugging something else with HDMI to see if that works. If another HDMI device works, then it's your PS3, if it doesn't then it could be a problem with your HDMI connections on the T.V.
May 04, 2011 | Philips 52 In. LCD HDTV
Can't get audio since switched to HDMI cable
The audio ouput of the box must not be set to hdmi. If hdmi is not an audio output choice you may have to choose 48khz or 96khz also known as pcm.
If this is an hdmi to dvi cable it would not carry sound and you would have to connect a red and white audio composite cable in addition to the hdmi cable if you tv and box allows for that.
Jun 13, 2010 | Initial DTV-262 26 in. HD-Ready LCD TV/DVD...
51F510 Input settings for HDMI
Okey,
Connect the hdmi, into the HDMI 1. that is automatically input one. Connect the 2nd device on Input 2, thats next to input 1 and hdmi, leave the input 1 empty, as the hdmi is connected to that.
3rd device into input 3
4th device into input 4.
Sep 08, 2008 | Hitachi 51F510 51" Rear Projection...
Hi guys, don't know if the previous post got through. Have a new LCD tv and DVDr, connected with a HDMI cable. when DVDr switched off analogue and digital picture is fine. as soon as dvd is switched on...
yes, hdmi will give you better results..
are you running hdmi to hdmi connection on tv from cable box?
if so, that is correct but as for the dvdr, what tv port are you connecting it to? i would use another hdmi cable for the dvd too for best picture resultif it's an option on your dvd.. you should have multiple input outlets on your lcd with 1-3 options for input devices via analog or hdmi.. so analog is not hdmi--hdmi is digital so it switches to the hdmi resolution when you turn it on..
let me know how it goes and if i was helpful involving resolution.. helpful feedback is appreciated.. thanks, d
your dvd player should be set to a different
Feb 27, 2008 | Televison & Video
Hdmi connections
Yes you should be able to do that. Make sure u switch between hdmi 1 and 2 on your tv. If you are still having problems try and get the tv company to fix the problem if they won't you could get a hdmi splitter on amazon for like 20 dollars.
Jan 21, 2008 | Televison & Video
Hdmi switcher
you need use the remote learning method to correct this, for some reason it seems that if you just push the buttons on the hdmi switch box ie, inp2 to switch to a second hdmi output, after about 5-10 min it will revert back, but if you use a infared remote set to switch it, it stays.
Jan 03, 2008 | Matrix Video Storm CRM84D HDMI,...
Televison & Video Logo
104 people viewed this question
Top Televison & Video Experts
Electro Med Services...
