Question about Kitchen Appliances - Others
Need owner manual for Elkay home water cooler Model TBM-AKV-AB.
I "inherited" this 10-year-old home water cooler that has a special nipple on the 5 gal bottle. I need to know if I can still purchase these bottles of water or if they can be refilled.
ThaMp3Doctor
  • 8596 Answers
SOURCE: substitute water refill..
I'm not sure what you're asking. You can run a plastic tube from a faucet head to the reservoir of this water machine - liable to get messy/wet if not handled properly. You can also puncture a hole in the water bottle - toward the bottom (careful) and tape a plastic tube from the water bottle to nowhere - be sure to tape the end shut so you don't experience leakage - will get annoying over tiem.
Just call the manufacturer/distributor - if they can't fix it or replace it under warranty, just buy a new one.
Posted on May 30, 2008
  • 14 Answers
SOURCE: advise
you need to purge the air out of the "hot" side after placing the bottle on top. If not enough water is inside the chamber the water will boil.
Posted on Jul 10, 2008
  • 70 Answers
SOURCE: BRAND NEW BOTTLE WARMER
If they got it at a store, return it as defective. It should be simple to operate, manual or not.
Also the store may be able to give you a copy of a product instruction sheet. You don't say what brand it is.
Posted on Aug 03, 2008
farfield
  • 462 Answers
SOURCE: whirlpool watercooler hold a 5 gallon bottler won't cool
The thermostat is suspect if the compressor is room temp and you do not have voltage at the compressor.
Do you have voltage at the compressor?
Posted on Mar 14, 2009
SOURCE: need owner manual for POLAR water cooler with fridge
how do i set the thermostat on my polar water dispenser.model#PWD335-
Posted on May 12, 2010
Need instructions for a MARCY APEX plus
Free Impex Home Gym User Manuals ' ManualsOnline.com LINK:
http://fitness.manualsonline.com/manuals/mfg/impex/impex_home_gym_product_list.html
There are five downloadable manuals at this link:
AB 4000 - Impex Home Gym OWNER'S MANUAL AB 4000
AB 4050 - Impex OWNER'S MANUAL MARCY AB BENCH AB 4050
Apex TC-2210 - Impex Inc. Power Tower Owner's Manual
Apex TC-3500 - Impex Fitness Home Gym Brochure
AX-PWR7 - Impex Home Gym OWNER'S MANUAL AX-PWR7
Jul 16, 2014 | Televison & Video
Overheating
Hi, Anonymous and the usual suspects are:
1. Engine oil level and SAE weight are too low or not circulating.
2. Insufficient or blocked air flow over the engine.
3. Heavy combustion chamber carbon deposits.
4. Ignition timing retarded due to faulty MAP, CKP, or CMP sensor.
5. Carburetor jetted too lean.
6. Leaking intake or exhaust valve.
7. Water coolant old or low change every two years.
8. Water pump failure.
9. Radiator clogged, cap loose or malfunctioning.
10. Radiator fans not coming on.
11. Clutch slipping, brakes dragging, heavy load, towing a trailer etc.
12. Idling too long without moving.
13. For constant hot weather temperatures, mountain, or desert riding conditions consider adding an oil cooler and or cylinder head cooler.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
Overheating
ViragoTechForum com
Yamaha XS 400 SH Service Manual ENG XS360 2D XS400 2E 2F SG Supplement ENG...
OEM parts for Yamaha
YAMAHA 1977 XS400 OWNERS MANUAL MOTORCYCLE eBay
Mar 01, 2014 | 1981 Yamaha XS 400 Special
My yz 80 overheats soon as you start it
Hi, Jamie and the usual suspects are:
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
YZ80 overheating and no powerband
YZ80 overheating problem
1994 YAMAHA YZ80 YZ80F FACTORY OWNER REPAIR SERVICE MANUAL Download... $10
http://mybikemanuals.com/yamaha/yamaha-yz-owners-manuals
Mar 20, 2012 | Yamaha Motorcycles
Elkay drinking fountain M#erpb28c continuously runs, having problems getting mounting nut back onto bubbler, seems basin should come off for access, however needind a reapir manual or access instructions...
The Elkay fountains are turned on by a solenoid powered valve. There is a rubber grommet in that valve assembly that gets holes in it and then water gets behind it, causing the valve to stick on. To test that it is a solenoid problem, turn the water on and then unplug the power to the fountain--if the water continues to run you have a solenoid problem. You'll need to replace the solenoid and I've detailed how to do it with all the steps and lots of pictures on my blog: http://johnfixesstuff.blogspot.com/2014/10/how-to-fix-elkay-model-ezfs81b-replace-solenoid-35981c.html John Fixes Stuff How To Fix an Elkay Model EZFS8 1B Drinking Fountain...
Feb 22, 2011 | Vacuums
HOW DO YOU GET THE EKLAY WATER FOUNTAIN APART TO REPLACE SOLENOID SWITCH
I have written up the entire process with all the steps and lots of pictures on my blog at: http://johnfixesstuff.blogspot.com/2014/10/how-to-fix-elkay-model-ezfs81b-replace-solenoid-35981c.html
Sep 16, 2010 | Elkay Water Cooler ADA Wall Hung 8 Gallons...
How can adjust the volume of water coming from the drinking spout on my Elkay water fountain?
On our Elkay drinking fountain there is a set screw underneath that you can turn to adjust the flow rate. I have detailed how to adjust the flow along with how to replace the solenoid on my blog at: http://johnfixesstuff.blogspot.com/2014/10/how-to-fix-elkay-model-ezfs81b-replace-solenoid-35981c.html John Fixes Stuff How To Fix an Elkay Model EZFS8 1B Drinking Fountain...
Mar 19, 2010 | Elkay Water Cooler ADA Wall Hung 8 Gallons...
Water pressure is low on the elkay fountain
if you mean the amount of water that comes out of the bubbler head....you can adjust that by accessing the push button cartridge and turning it to adjust how far it is pushed.
Oct 18, 2009 | Elkay EZS8-L Single-Level Wall Mount Water...
Elkay water cooler does not turn on
You need to first check the circuit breaker for that wall outlet, and see if you short circuited it from water going behind the wall. if that is the case you need to reset it at the circuit box and then run a bead of clear silicone on the back of the water cooler to prevent water from dripping down the back .
May 30, 2009 | Elkay Water Cooler ADA Wall Hung 8 Gallons...
Need temp control for water cooler has BOTH HOT/COLD
Company called Ranco makes replacement contols. Contact your local Appliance Parts Dealer.
Apr 22, 2009 | Refrigerators
Kitchen Appliances - Others Logo
240 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
