Question about GE Profile PEB1590 1.5 Cu. Ft., 1000W, Countertop Convection/Microwave Oven, Convection Cooking
Not heating Relay-type click sound upon start, interior lights and timer counts down, but no fan and no heating in either microwave or convection mode. Door safety switches seem to be operating correctly (tested with door open in convection mode, got expected behaviors). Unit only ~18 months old, so a little early for magnetron to die, and since convection mode also not working, suspecting a relay or capacitor?
4 Suggested Answers
jeltey
  • 44 Answers
SOURCE: JVM1190 wont cook
You have a blown actuator. This is the device that creates the microwaves that cook the food. The cost of one of these will be as much as a new unit.
Posted on Nov 09, 2008
SOURCE: GE Profile JE2160 - Just stopped working. Touch
Microwave ovens use a series of micro switches to operate as interlocks to ensure the unit will only operate once the door is securely closed.
If these locks are not operating properly, the timer would count down just like it was operating. There will be no noise like the normal vibration or fan sounds when the start button was pressed. It will simply act like it will operate, but it will never turn on any of the components.
You would need to check these switches if they are functioning properly and would need the help of a qualified technician to test them. If you plan to do it yourself, Check if the switches are mechanically operating and that electrical continuity would change as it was actuated.
There will be at least three of these switches aligned so they close in a specific sequence when the oven door is closed.
This closure process is designed to prevent someone from just sticking something in to actuate the switch and run the microwave with the door wide open and becoming exposed to the microwave energy.
Two of the switches are in place to provide power to the units high voltage section and to tell the control board when the door has been closed. These are usually normally open switches.
The third switch is called the monitor and acts as a safety switch blowing the internal appliance fuse in the event any tampering is going on, and this one is usually a normally closed switch.
If you find the fuse inside your microwave is now an open circuit, check the monitor switch as it may be the cause.
Hope this helps.
Posted on Aug 19, 2011
  • 6771 Answers
SOURCE: GE Spacesaver Microwave not heating, inside fan not working
I suggest you have the microwave oven replaced, the prices have dropped considerably for the last several years and you have got your money worth out of the unit.
Posted on Mar 02, 2012
My GE Profile Countertop Convection/Microwave Oven PEB1590DMBB Has stopped working.
It sounds like you may have a shorted cook relay on the control circuit board which can be repaired simply and inexpensively.
A YouTube video showing how to remove a typical over the range control panel assembly in under 5 minutes, is here.
Nov 30, 2012 | General Electric PEB1590DMBB: Profile 1.5...
My microwave doesn't work, but display works
I would strongly consider replacing the microwave oven, prices have dropped considerably. The problem you are describing is in the keypad controller board.
Apr 01, 2012 | Samsung Microwave Ovens
Light, fan and timer work but microwave does not
Microwaves are pretty much a non repair item. It will cost you more to fix than it would to replace.
Aug 14, 2009 | GE Advantium 120 Convection/Microwave Oven
Microwave won't heat food, new smart board unavailable?
HAVE YOU THOUGHT ABOUT TRYING TO BUY A USED ONE AND TAKING THE BOARD FROM THAT ONE AND PLACING IT IN YOURS ?
Apr 13, 2009 | Microwave Ovens
GE Microwave Model # JE1860: Unit does not heat. The timer counts down, but the oven does not heat.
When you hit Start to cook, do the inside light, cooling fan, and turntable come on?
Any unusual noises? Is it louder or quieter than usual?
These answers will help me judge whether it's in the high voltage section (magnetron, transformer, or diode) or the control section (door switch or control board relay or connection).
Nov 27, 2008 | Microwave Ovens
JVM1190 wont cook
Nov 09, 2008 | GE JVM1190 Microwave Oven
Does microwave ovens make noise while it is in process of heating?
It seems like it is the first time you either own or using a microwave oven. Yes, there are more than one fan/motors inside a microwave, depending upon the model/type.
Nov 04, 2008 | Microwave Ovens
GE Profile PEB1590 1.5 Cu. Ft., 1000W, Countertop Convection/Microwave Oven, Convection Cooking Logo
24 people viewed this question
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
