Question about Poulan Snowblower 205cc 8.0 TP Briggs OHV ES 27 PR8P27ES
Engine surgings after running 1hr
Engine runs for 1 hr surges and dies new fuel line ,gas cap carb cleaned
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 188 Answers
You're on the right track its definitely fuel starvation. Try cleaning the fuel tank breather (it's probably in the tank filler cap). This allows air in to the tank as the fuel is used, if it's blocked you get a partial vacuum in the tank and the fuel wont come out.
Posted on Jan 20, 2014
2 Suggested Answers
  • 17 Answers
SOURCE: Poulan tiller with 85 series engine 8.5 hp will
Sounds like the float valve is stuck. This means that there is not enough gas coming in. Try some solvent such as berryman's b-12 chemtool. First drain gas from system, then use only enough solvent in fuel tank to fill carb bowl. Let is sit for several hours and then drain the bowl. This will dissolve any gum that has formed in the carb and will free everything up. I would try this before making any modifications to the adjustments.
Posted on Mar 23, 2012
Engin surges on onan tractor moter?
try to turn out high screw on carb half turn if not work try one turn if die put screw were it was restart look for water in gas if dump gas clean carb bowl put in fresh gas new gas try starting if still doing tkea some fuel additive sea foam put that in the gas follow instrutions on can carb should run better will take 2 tank fulls of gas for it to work if that dosnt help rebuild carb
Sep 04, 2014 | Garden
Engine surging
you could have leaking head gasket
Jan 02, 2014 | Tecumseh Snowblower Snow Blower Starter...
Cant get 5.5 hp Briggs and stratton to start after cleaning out fuel lines tank and carburator changed plug it ran for a sec then died again what now
hello sir, mower will not start or run, does it have good spark,good compression,or only runs on full choke,engine surges up and down, are you getting fuel to the engine if not try this, your carb. is clogged up here is what you can do for a simple repair and other things if you want to, you will need a new air filter,spark plug, oil, if you want to a new blade also ,sears has a mini tune up kit that you can buy. now for the carb, empty fuel tank, place mower on side to where carb is facing up place a rag under carb to catch excess fuel,remove the bowl nut and bowl careful of the gaskets,now spray carb cleaner in the small port holes in the carb steam in the middle of the carb until clean,now spray the bowl nut holes until clean there are three,after cleaning put bowl on the same way you removed it with dip towards front of float,put bowl nut in, now while you have mower on side drain the oil remove filler cap to drain,put pan under spout,mower holds 21 o/z of 30 wt oil,you can remove blade to get sharpened or put new one on,to remove blade put a pair of vice grips on the body where the blade can stop and not turn it is usually a 9/16 or 1/2 socket, put blade on add oil,add new and fresh gas,you should be good to go,hope this helps,what i am telling you here is what i would do if it was here in the shop,any comments welcome,thank you.~~
Jan 22, 2012 | Mtd Garden
Gas blower engine surges and shuts off when engine gets hot
check your fuel lines for cracks, could be sucking air or could be your carb needs cleaning, make sure you clean the screen inside the carb, if you run it with the choke on partially does it smooth out and quit surging, if so it is definitely a fuel problem. Hope I helped you. 2StrokeJim
Nov 27, 2011 | Poulan 25CC Gas BlowerVac
After about 30 minutes engine will start surging, by partly pulling the choke out it will run better. The carb has been recently rebuilt as well as new filter and fuel line to carb. Tried different fuel...
Typically a surge is caused by a lean condition. I'd say the float is set to low and this is causing the engine to lean out & when you apply the choke it richens it back up.and the surge stops.
Oct 12, 2010 | Craftsman 20 hp 42 in. Deck Yard Tractor
Briggs & stratton 550 / surges, gas hog
check your air filter. If it's clogged, the engine will spool up to keep from dying, run for about 15 seconds, then it will happen again. If that's it, just clean the air filter. Solved my problem
Jul 26, 2010 | Briggs & Stratton Garden
Coleman Powermate 3000 surging
Check your air filter to make sure it is clean, especially if the gen. has been run in dirty, dusty conditions. Make sure the gas tank vent is not clogged.
Also, pour some combustion cleaner into the carb. through the air intake to clean the carb. It sounds like it is starving for gas.
Hope this helps.
Rob
Sep 27, 2009 | Coleman Powermate Premium Plus 6250W...
Cub Cadet 2165 engine surges and eventually stalls
Replace the fuel cap!!! The problem is that hte fuel cap vents from it's underside. In so doing it sucks up all of the grass debris and dust that hte mower deck kicks up and the vents get clogged up. As the engine uses the gas, it builds up a vacuum in the tank and the gas can no longer flow from the tank to the engine.
Jun 15, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Craftsman GT5000 W/22hp B+S surges and dies when warm
Replace the spark-plug, check the quality of the fuel(gas that is mixed or was stored more then three months is stale and wont fire correctly) make sure the fuel and air filter not clogged. If there is no change then your problem may be more technical, a nest may be restricting the govenor or you missed something with the carb and there still is debre causing it to stall.
Apr 24, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Poulan Snowblower 205cc 8.0 TP Briggs OHV ES 27 PR8P27ES Logo
190 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
