Question about Ricoh Aficio 1013F Copier
Ricoh Aficio 1075 - Change paper size on TRAY 1
Hi from Argentina! I´ve changed the paper size on "Tray 1" of my Ricoh Aficio 1075 from A4 to Letter, but I still see A4 in control panel. Does anybody know how to tell the machine the correct paper size? Thanks!
  • 1 more comment
  • martin100181 May 21, 2009
    Thak you, but I didn´t find any dial. Remember I´m talking about the big tray.
    I found where to change tray 2 and 3, but tray 1 is not showed. Maybe is somewhere in technical service menu, because paper size of that tray is not to be changed by end user.
  • martin100181 May 22, 2009
    Thak you,¨I´ll tell them to do it.
Press Clear Mode then 107 C/stop (press C/stop about 10 second) - then 5919 - change paper type in tray 1.
If you want change paper in tray 2 and tray 3 you can set in user tools
Posted on Feb 11, 2014
  • 313 Answers
Go into the user tools and select copier and the n go to paper tray settings yuo will have to manually select tray 1 and the go to paper size and change it here..you can also change the other tray sizes or by using the arrow down change the paper type.. good luck A
Posted on Jun 12, 2009
You need to set the dial on the back of the paper tray
Posted on May 21, 2009
  • Anonymous May 21, 2009
    Oh...oops, then It should under the "user tools menu", select "copier settings", then "paper tray settings", and select the proper tray and set it. I may be slightly off on the buttons, but you should find it.
    Sorry, I have limited experience with that particular model, so I was giving advice based on my knowledge of other Ricoh machines. I['ve now referred to the service manual, and you're right, the tandem tray is an adjustment performed in service mode after the guides have been removed and adjusted accordingly, and the position sensor bracket moved. I'm not sure from your post if you have performed all of the necessary changes within the tray that need to be done prior to even making the adjustment in service mode. I'm sorry, but I'd prefer not to provide this adjustment to you because if the guides, and sensor are not postioned correctly, you could severely damage the tray unit. Perhaps, the next time you have a technician in, you could ask to have the settings changed.
My aficio 1013f can not scan a4 but only b5
CHECK THE PAPER SENSOR, U CAN SEE ON THE RONT OF TRAY COLOR GREEN AND SELECT THE RIGH PAPER SIZE RICH FOR U
Jan 17, 2014 | Ricoh Aficio 1013F Copier
A3 prints - printing on A4 - Ricoh C4500. When users print to our Ricoh C4500 using RPCS the print comes out as a cut off A4 print, so it does not seem to be detecting the fact that it is needing to use...
Enter on the computer the follow path:
1. enter start menu
2. enter printers and faxes
3. enter by right click into properties
4. enter paper size settings
5. set the paper size for the tray or trays and press update then apply and ok
after thet it will work
Also see on the printer menu enter the same paper tray settings and set the trays by size but more important is to set the compute settings
Jul 08, 2009 | Ricoh Aficio SP C410DN Laser Printer
My printer will only print from bypass tray. Why?
It may be something to do with the paper size settings on printer driver, document print settings or page setup. If for example the computer thinks the paper size is Letter, and the paper in Tray 1/2/3 is A4, it won't print.
Jan 23, 2009 | Ricoh Aficio AP3800C Laser Printer
Paper tray default issues
you need to go into the print menu on the printer and change the paper tray size back to letter, when you have it right there will be an asterik next to letter confirming that it was programmed
http://www.websitetoolbox.com/mb/copierquestions
Dec 23, 2008 | Ricoh Aficio SP C410DN Laser Printer
Ricoh CL3100N
Have you setup for double-sided printing?
Jul 15, 2008 | Ricoh Aficio CL3500N Laser Printer
Error code 92
It sounds like the print job you are sending is probably on A4 and the machine is set to A4 or has A4 in the tray.
Try changing the page size that you send to the printer and ensure the paper size in the tray is the same as the print job AND that the tray sizes are set correctly.
Jun 18, 2008 | Ricoh Aficio CL3500N Laser Printer
Ricoh Aficio 1085 Paper Tray 1 Jamming
you can change the tray setting in user mode to tray 2 and same time do not fill the tray one. same apply on print job from a computer, select tray two as default with print driver.
Jan 07, 2008 | Ricoh Aficio 1085 Laser Printer
Ricoh Aficio 450 paper format printing problem
This could be a few things, first thing i would try is to go in page setup under the program you are using and make sure paper is set to auto select (File>page setup). The program will override the print driver.
next make sure the driver setting (paper source) are also set to auto. make these changes by right clicking on the driver>printing preferences.
third I would go to the copier, Make sure the tray are set to the proper paper size and the display paper size matches the tray
Dec 26, 2007 | Ricoh Aficio 450 Copier
Copier will not sort documents correctly
Hi songman to sort you need to have the A4 paper in both cassettes one cassette needs to be A4 portrait(wide edge first) and the other needs to be landscape (short edge first)make sure you have the green paper size selector set correctly as well regards Dr Bob1
Apr 09, 2007 | Ricoh Aficio 1018D Copier
1,109 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
