? 5:45 www.youtube.com/watch?v=fRxKs2EEfbU Feb 1, 2013 - Uploaded by Michael Borders
My Kenmore washer's agitator stopped spinning my cloths during the wash. NO BIG DEAL!!!! EASY and ...
My machine canon ir6055 display error E000840-0001 and E00060-0001 i am all so cheek the machine fuser unit last time automatic open the lock fuser i am set the fuser agin problem
and E000013-0001
I just found your question, so I'll try to help you, you said you just had the machine serviced and it's still showing the error 88, is this error why you took the machine in to be serviced for? if it is then I suggest taking the machine back to the repair shop and tell them it wasn't fixed correctly. I've had other people say that they've took their machine in to be fixed and then brought the machine home and it still had the same problem so that means that they didn't fix the machine .. have you tried changing the needle--needle that is correct for the fabric being sewed try rethreading the machine top and bobbin also try using a different bobbin make sure the top thread has not come off the thread take up lever make sure the top thread is not wound around the spool pin make sure the bobbin is turned the correct way do you have a manual for the machine?
Sir I have canon 2870 machine. The machine giving the finisher problems, when starting the finisher going down. The machine showing the problem E540. Please kindly solve
need to have a look at the machine, how old is the machine 15 years roughly, Yes this is when the machine plays up, hard to find spare parts. If you are getting rid of the machine let me know. 0412676652 Since I want to learn fixing the machine, I did fix one of this model long time ago
Your machine can be fixed but I do not recommend fixing it as the cost of this repair is prohibitive. You are better of replacing the machine, even with a good used one for under 200 as this particular repair will be much more than that
