Question about HP Scanjet G3010 Flatbed Scanner
Slip adapter is part of the scanner ? How to use slip adapter to scan negative film ?
  • 864 Answers
The film goes into the adapter and the adapter mounts on the underside of the lid.  Complete manual available free at http://www.scribd.com/doc/7571067/HP-Scanjet-G3010-Users-Manual
Posted on May 21, 2009
My canon lide 700f will not calibrate to scan a 35mm film
For those having the "Executes calibration. Pull out the film and place the Film Adapter Unit at Frame 1." issue and cannot calibrate the scanner for NEGATIVE FILM, it took me ages to figure out how to solve it.
Solution: calibrate the frame, WITHOUT any film, adapter plug and placed in frame 1, and proceed to do the calibration WITH THE SCANNER COVER OPEN.
Before I tried everyhing, install new drivers for Windows 8.1, MP Navigator, and nothing happen. Now it works like the first day. Hope it helps! it certainly helped me.
Jan 29, 2013 | Canon CanoScan LiDE 700F
Can HP psc 1410 PRINTER SCAN NEGATIVE AND SLIDES
Chances are that somewhere in your family photo collections you have a bunch of slides and negatives that you wish you could do more with. You may want to include them in your family history, to publish them on the Web, or simply to make digital copies so you can share them with the family.
If you've ever tried to scan a negative or slide on a regular flatbed scanner, you'll know that it doesn't work, and you end up with a pure black scan. In this article we'll show you how you get your negatives and slides into digital format, and what issues you may face along the way.
pixblue.gif Benefits Of Scanning Film
There are some key benefits to scanning film (we'll use the term to include slides and negatives) in comparison to scanning a photo. When you scan film, you can use the full area of the slide or negative, whereas a photo will generally only display a cropped portion of the original. You are also scanning the original source image rather than the color corrected and tweaked version of it that the photo processor has provided you with. The process of turning a negative image into a positive one involves inverting the colors in the image and removing the orange cast from the negative. This would be a complicated process if you were doing it by hand; however, your scanner will provide you with software to do this automatically, or you can purchase standalone software to do it.
Most cheaper flatbed scanners are designed to scan photos and other images that reflect light when it is shone onto them. The problem is that film is transparent and light passes through it rather than being reflected off it. Many flatbed scanners have an optional transparency adapter, which replaces the scanner lid with a larger box shaped ob....
Jun 09, 2010 | HP PSC 1410 All-In-One InkJet Printer
Problem scanning film with EPSON V300
check if upper cover remove for film scanning, bulb must be visible upon scanning in negative or positive film.
Feb 04, 2010 | Epson Perfection V300 Film Flatbed Scanner
I am looking for instructions on this product.
Step 1: Open the scanner lid and remove the Transparent Materials Adapter (TMA).
Step 2: Place your slides or negatives into the appropriate template. Follow the orientation indicated by the icons on the template.
Step 3: Tip: If you are scanning fewer than the maximum number of negatives with the TMA, cover the empty spaces with the provided light shields to avoid letting any extra light in
Step 4: Place the template on the scanner glass, aligning the arrow on the template with the indicated mark on the scanner bed.
Step 5: Close the scanner lid and press the Scan Film button (or select the Scan Film option if you're using the HP Solution Center application on your PC).
Step 6: In the Scanning from dialog box, click Change Settings.
Step 7: Under Scan Shortcut Settings, select your Scan Type (either Negatives (TMA) or Slides or Positives (TMA)).
Step 8: Under Scan To select Save to file. Then click Scan.
Step 9: Under the Save Location dialog box, click Browse and enter the destination folder of your choice. Click OK and follow any on-screen instructions to finish scanning. The scan will be sent to the destination folder you selected. s.gif s.gif
May 01, 2009 | Office Equipment & Supplies
First time i have scanned slides. not sure how to load them. do you slip them in from top, then cover with the vertical slide? i have put in a slide but can't read it--it comes out black when i try to scan...
double click the HP solution center open the scanner lid remove the TMA cover (transparent material adapter) by pulling the cover up place the slides onto the slide holder insert the slides w the top of the slides pointing up and the front of the slide facing you close the lid press the scan film in the HP dialog box select picture select scan positive, and select TMA click scan
goodluck
cheers
Dec 22, 2008 | HP Scanjet 4850
Lide80 Film Scanner
You can scan all the image and then crop out necessary parts!
Oct 01, 2008 | Office Equipment & Supplies
No option to scan Film Negatives
In order to see these options, you must have the Film Adapter Unit (FAU) attached to the scanner. The FAU is designed to scan in 35mm film, either positive or negative. The scanner has no options to scan in mounted 35mm slides.
Does the scanner work for scanning at all? If not, you may have a communication problem between the computer and the scanner, i.e., the computer doesn't know how the scanner is configured so it doesn't show the options. If it's a communication problem, check for any other USB devices that might interfere with communication. Especially, some printers seem to take over communications. Try disconnecting all other USB devices (except keyboard, mouse, etc.), reboot, and see if the situation corrects itself.
Also, try the online troubleshooting database for this model at this link.
Sep 30, 2008 | Canon CanoScan LiDE 600F Flatbed Scanner
COLORED SLIDES
do you have the optional film adapter? The optional Film Adapter (B81317) lets you scan negative film strips and slides
Jan 11, 2008 | Epson Expression 10000XL- Photo Scanner...
LS 2000 w/SCSI connection
does the nikon scan sofware recognise the scanner ?
Sep 20, 2007 | Nikon LS 2000 Film Scanner
Unable to use film adaptor
Please do the following to scan slides or negatives in manual mode of the Epson TWAIN:
1) In the program you are working from, begin the scanning process. If working in full auto mode, as the scan begins you will see a message that reads TO CANCEL SCANNING IN FULL AUTO MODE AND SWITCH TO MANUAL MODE, CLICK CANCEL. At this point, click CANCEL, then MANUAL MODE.
2) You will now see all Epson Twain settings displayed. If the scanner has not previewed automatically, click the full page preview button (icon of a paper with one corner folded down).
3) Ensure the settings on the right hand side of the Twain are correct. For example, the DOCUMENT SOURCE for transparencies must be either TPU: COLOR NEGATIVE FILM, TPU: MONOCHROME NEG or TPU: POSITIVE FILM.
FILM here indicates that the item being scanned is transparent to light; this setting is also used for slide scanning. Positive indicates that the image is in true colors (ie the grass is green and sky is blue), whereas negative indicates reversed colors, as produced in some photo finishing processes. (If you are scanning a black and white slide in true colors, choose TPU: POSITIVE FILM as the DOCUMENT SOURCE and BLACK AND WHITE PHOTO as the IMAGE TYPE.)
If the DOCUMENT SOURCE is flatbed, the scanner will not activate the backlight in the transparency unit. If the DOCUMENT SOURCE is greyed out and you cannot select a TPU option, close the twain, reseat the power/communication cable connecting flatbed to TPU, then re-open the twain and try again.
4) Ensure the other twain settings are correct for the type of scan you are doing.
IMAGE TYPE should be color photo for all positive or negative color transparencies, or BLACK AND WHITE PHOTO for monochrome transparencies.
DESTINATION is unimportant, however you should select a RESOLUTION appropriate to what you plan to do with the scans. (There are no hard and fast rules for DPI. As a general guideline, if you are saving scans at original size, a resolution ranging from 400-600 DPI should capture enough information to faithfully record the image. If the slide or negative will be enlarged, you will need to increase this DPI accordingly. We have no guidelines on this; you will need to experiment and view the output to gauge the appropriate input DPI from the scanner.)
PREVIEW. If your scanner is doing an AUTOMATIC THUMBNAIL PREVIEW, the slides will automatically preview and appear in boxes on the left side. Here, you can select or deselect the slides you wish to scan.
If you recieve a message that the scanner could not find the film, click the CONFIGURATION button and uncheck AUTOMATIC THUMBNAIL PREVIEW FOR FILM, then OK, and try the PREVIEW button (page with corner folded down) again.
In this mode, you will have to manually marquee or crop the slides you wish to scan. Use the left mouse button to lasso one slide inside a box made of dotted lines, then click scan. Only the selected area will scan. Repeat this process (manually crop then scan) for as many slides or filmstrips are on the bed.
5) Click CLOSE once scanning is complete. The images will now transfer to the application in use.
Aug 16, 2007 | Epson Perfection 1200 Photo Flatbed...
HP Scanjet G3010 Flatbed Scanner Logo
112 people viewed this question
Seeker5211
Seeker5211
