Question about Blomberg Dishwashers
Dishwasher water inlet valve ok
My dishwasher wont fill. It drain ok
  • 1462 Answers
SOURCE: dishwasher won't fill
could be. there is a float in the base of the machine. take the bottom front cover off and have a look. alternatively, tilt machine over and see if water runs out. water in the base of the machine means you have a leak
Posted on Apr 01, 2007
  • 11 Answers
SOURCE: Bosch SHU4300 Water Fill Issue.
Similar problem for us turned out to be water accumulating in the tray which set off the float switch.  I vacuumed the water out and function returned to normal.  However, we are now facing a repairman's assertion the clay in our well clogged the water inlet systems necessitating $285 in repair parts and labor.
Posted on Oct 13, 2007
SOURCE: Bosch SHU 4000 series dishwasher; Water keeps on filling
Follow-up: I was able to fix the problem on Bosch model # SHU 4002UC. Purchased water inlet valve (part number 425458) from Sears Parts Center. I required the Sears unit number from the original invoice as Sears computer system apparently cannot identify the Bosch model number. The valve is as described by meyerjr above; however it is located at the bottom front of the machine so could be replaced (not so easily) without removing the machine. Cost of part was $30.50 Cdn including tax.
lwou
Posted on Apr 20, 2009
marka19
  • 1430 Answers
SOURCE: dishwasher will not fill, water supply checked OK,
Check the float switch. Sometimes you can jiggle it around to get it working. Also check the leads going to the water inlet to see if you have power unit must be started to check this. If you have power to the valve it has failed if not check that float switch for continuity. One of the leads from the water inlet goes to the float switch.
Posted on Mar 03, 2010
SOURCE: Miele G 7856 Commercial Dishwasher
Hi. The above machine stops mid cycle and drain/fill light is on, also error code F3E, have cleaned both hot and cold water inlet filters, also checked drain pump and drain line, all ok. Machine drains with no issues and fills with hot water, runs for a while then shuts down.
Any ideas?
Posted on May 29, 2010
Dishwasher slowly fills after cycle
If water slowly fills in the tub when not in use.
a) Most likely your machine inlet water valve not seating properly and closing. Change the machine water valve.
b) May be sink drain water back flowing to the tub. But you have checked that.
So it has to be the machine inlet water valve.
Apr 11, 2015 | Whirlpool Dishwashers
Switch dishwasher on and starts up ok but when it comes to pumping water in it stops and does not do anything else.
Hello
Investigate these five areas if your dishwasher won't fill with water:
As water is filling your dishwasher, a float rises along with it. When the float reaches a predetermined level, it shuts off the flow of water, thereby preventing a leak. Sometimes the float can get stuck in the wrong position in your dishwasher, and it can prevent your dishwasher from filling. Check your float assembly. Replace it if you need to.
The water that fills your dishwasher lifts the float, and when it reaches a certain level, it acts as a trigger for the float switch. The float triggers the float switch to shut off, thereby shutting off the flow of water into the dishwasher. A defective switch may interfere with your dishwasher's filling ability.
Your dishwasher may not be filling with water simply because the water valve's filter screens are dirty and debris-filled. Gain access to your water inlet valve and try cleaning it out. This might be enough to solve the problem. You can learn how to access your water inlet valve in the replace a dishwasher water inlet valve section.
Alternatively, your water inlet valve could be defective altogether. That could be the reason your dishwasher is not filling. Test it for continuity. If it is not functioning as it should, replace it.
Your dishwasher's drain valve is regulated by a drain solenoid. If the solenoid is malfunctioning, it may not allow the drain valve to funtion properly, which in turn could be the reason your dishwasher is not filling with water. Investigate your drain valve and test the solenoid. If the solenoid is faulty, replace it.
Aug 22, 2011 | Dishwashers
Hotpoint Super Plus 7821 dishwasher isn't drawing water, please help thank you
Hello
Water Inlet Valve
Aug 03, 2011 | Dishwashers
No water is coming in the dishwasher. I can hear the water running, but the water is not coming into the dishwasher
If you can hear the water running - but it's not filling, you most likely have a drain problem, which is being stuck open. Usually the motor kicks in and either pumps the water through the wash arms (during wash cycle) or through the drain (during drain cycle) the switch that/or flap could be stuck on the drain and it is pumping it out the drain all the time instead of the wash arms.
Apr 18, 2011 | Kenmore 1348 Builtin Dishwasher
Dishwasher will not fill with water. What could be the problem?
Dishwasher will not fill with water .
  • Check that the water supply is turned on. The valve may be located under the sink.
  • Check the door latch
  • Test the door switch
  • Inspect the float assembly
  • Inspect the fill tube for kinks
  • Test the float switch
  • Check the inlet valve filter screens
  • Test the water inlet valve
  • Test the drain valve lever arm
  • Check the drain valve
For trouble shooting click this link:--- http://www.partselect.com/dishwasher+dishwasher-wont-fill+repair.htm ----------- Thank you.
Jan 24, 2011 | Maytag Dishwashers
Optima G2430 Miele dishwasher with intake/drain flashing light
F13 is an inlet fault.
First the unit drains and then fills with water. When the unit has intially drained open the door and manually fill the unit with water, about 5lts. This will then allow the dishwasher to go to the next step which is to circulate the water. If this works ok then the water tap is defective, water inlet valve is defective or the electronic unit is not sending the signal to activate the valve. The water inlet valve is the white square box attached to the tap. Remove this and check the filter and make sure water comes out of the tap.If ok then remove the bottom panel of the unit under the door. On the right hand side there is a 2 core cable with a male and female connector. Unplug this and check for voltage from the electronic when the unit goes to fill with water. If there is 240v then the electronic is ok. You will then need a new waterproof system from Miele.
Feb 27, 2010 | Miele 24 in. Incognito G843SCVi Built-In...
My g595sc miele dishwasher after about 2-3 minutes of working come to stop with the "WATER INLET" light on. Please help.
Jan 22, 2010 | Dishwashers
Hi, i have a mieled/w g1. it give a code of f13 which is inlet but i dnt think the waters getting thro the electonic non r/ valve
Jan 14, 2010 | Miele G880 Dishwasher
The motor turns on but no water is entering the dishwasher to start the wash cycle.
Hello there
Here is the most common troubleshooting tips
Dishwasher does not fill with water or it drains while filling
  • Please check each one of these out carefully ok
  • Hope this is very helpful for you
  • Best regards michael
Jan 10, 2010 | Bosch Integra 300 Series SHX43C0xUC...
Dishwashers Logo
21 people viewed this question
Top Blomberg Dishwashers Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Blomberg Dishwasher Expert? Answer questions, earn points and help others
