Question about Ridgid Rd80903 3000 PSI 2.6 GPM 5.7 HP Subaru Sp170 OHC Gas Powere
What spark plug
Need to know spark plug number
  • 54 Answers
Go here and input your model number to search for your manual. The number is in there.
https://www.ridgid.com/us/en/literature-search
Posted on Sep 16, 2014
Need spark plug
Champion spark plug RCJ6Y
May 04, 2013 | Garden
Need to change spark plugs but i dont know what to do, on what number does the spark plugs go?
Go into a motor factors (spares Shop) and look at the spark plug catalogue. the plugs you need for your vehicle will be listed under your model name and year.
Jan 07, 2012 | 2005 Chevrolet Malibu
Don't know if its a spark plug problem, need to need size of spark plug if needed for the blower?
look on the old one should be letters and numbers of the plug you need
Dec 16, 2010 | Garden
How do I install a distributer on 1998 vortec engine. old distributer missing
Hi: To Install the Distributor Correctly, 1st thing to do is Remove your #1 Spark Plug assuming it will turn over have someone Turn the Key Off and On in Short Intervals.Either put a Compression Gauge in the #1 Spark Plug HoleOr the Old Fashion Way Works as well just put your Finger in the #1 Plug Hole.As your Helper Cranks the Engine On -Off On -Off.Not A Continuous Crank.When You Feel Air Pressure or See gauge Come up.TYhats when your Engine is a The compression Stroke.Now you Can Drop the New Distributor in its Hole.NOTE: You'll need a Spark Plug and Timing Diagram to See the Position your Distributor ROTOR Line it up to where the Diagram Shows your #1 Spark Plug Wire Will go in the Distributor Cap.If the Distributor Rotor is Not n That Position Your goning to Get Either Back Firing engine May Not Even Stsrt, To This Is Crucial. After The Know that you have The Distributor Droppped The Right position you'll need to Put Gap your Plugs at the Correct Specs, With All Plugs in Now You'll need to Put New Plug Wires on .And They MUST be in the correct order.Sitting inside your Vehicle #1 Plug is the Front Plug on the Drivers Side Next is #3 plug Next is #5 and Your Back Plug is Number 7,On the other side Passenger Front Plug is #2 next #4 Next is #6 and the Back is #8 Assuming you know have your Distributor Dropped in The Proper Position, Put the #1 Spark Plug Wire on the Front Spark Plug (Drivers Side) The Spark Plug Firing Order in Your Engine is 1-8-4-3-6-5-7-2 Clockwise So the Next hole after you have #1 Plug and Wire on And Distributor In Correct Position on COMPRESSION STOKE, Going Clockwise you next wire will be your #8 Position in The Cap And it wil go to the Back Spark Plug on The Rear Spark Plug on Passenger Side. NOTE: Drivers Side Spark Plugs on the Drivers Side Front to Back are Your Odd Numbers 1-3-5-7 Pasenger Side is Your Even Numbers From The Front is #2-4-6-8 Is The Rear PLug .
Heres a Diagram of your Spark plug Positions
Front of Engine
1 2
3 4
5 6
7 8
Hope This Will Get You Going. Let me know The Quality of Help and Solution I've Given You By Voting on It.And May Can Also Send a Testamony
From d_hubbs
Jun 03, 2010 | Chevrolet Silverado 1500 Cars & Trucks
Spark plug wiring diagram
If u can't see the diagram go to the link, just match up the numbers on the coil to the engine cylinder numbers.
http://autorepair.about.com/library/firing_orders/bl-fo-5630.htm
Apr 05, 2010 | 1997 Pontiac Trans Sport
Number 1 spark plug for 2000 Mazda MPV
The cylinder order is 1,2,3 (rear row, left-to-right) and then 4,5,6 (front row, left-to-right).
When replacing spark plug wires or plugs, it's very helpful to do one at a time to avoid connecting them incorrectly.
Hope this helps, Sherwin
Dec 29, 2009 | 2000 Mazda MPV
Number 2 spark plug
Are you sure it's the spark plug that's faulty or the ignition wire?? How old are plugs and wires?
If you don't know if it's your spark plug not firing or your ignition wire you could move spark plug to number 1 then check your code reader.
Or you could do an ohms continuity test on your number 2 ignition wire to verify that there is no break in the wire. Common problem to check for. If wires and plugs are old and high mileage maybe should change all including cap and rotor on distributor. Fresh wires plugs cap and rotor always improve mileage and performance.
Good luck, sorry can't help with tranny.
Dec 10, 2009 | 1998 GMC Jimmy
I have a UT08580 Mighty Lite backpacker blower with a missing spark plug, I need to know what plug goes in it.
The Homelite part number for this spark plug is 870174001. This number crosses to Champion spark plug RCJ6Y which can be bought at any Home Depot, Lowes, Ace Hardware, etc for about $3
Oct 20, 2009 | Homelite Consumer Products Backpack...
Need to know correct wiring of the 8 spark plug wires
first you need to figure out which one is number 1. the firing order is counterclockwise 15426378
Sep 20, 2009 | 1997 Chevrolet Cavalier
Changing Spark Plugs
2.0L SOHC (single overhead cam) AGSF34EE plugs gap 0.054
2.0L DOHC (dual overhead cam) AZFS32FE plugs gap 0.050
The plug numbers are the motordraft numbers
Apr 02, 2009 | 2001 Ford Focus
Ridgid Rd80903 3000 PSI 2.6 GPM 5.7 HP Subaru Sp170 OHC Gas Powere Logo
124 people viewed this question
Top Ridgid Garden Experts
Jerry Kramer
Jerry Kramer
protojexxx
Level 1 Expert
Are you a Ridgid Garden Expert? Answer questions, earn points and help others
