Question about Dishwashers
Granddughter stood on dishwasher door and now it goes down too far when opening. Spring assembly (pulley type) is FINE...but door goes so far down bottom shelf nearly breaks dishes when pulling out
Granddaughter stood on GE profile dishwasher door and now it goes down too far when opening, making the bottom shelf of dishes "fall" when pulling out. The SPRING assembly itself is okay (it's the one with pulleys).
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 62 Answers
This happens when people leave the door down, I've seen it many, many times, sometimes the door/hinge assembly can be replaced or even bent back, sometimes it totals out the unit...Good luck !
RMK...
Retired GE Factory Service
Posted on May 21, 2009
My door is locked on my dishwasher and will not open?
You will have to pull the unit out from under the counter and you need to remove the screws that hold the hinges on the bottom of the door in order to remove the door to service it.
Apr 02, 2015 | GE 24 in. Profile PDW7800 Built-in...
I own a GE Profile Trition quietpower III GSD5940F00SS dishwasher. The dishes, particularly the mugs and cups, are not getting clean.
Your sprayer arms may be clogged. You can remove them by loosening the screws holding them in place. Flush them with the sprayer at your sink. If you can SEE residue (parts of paper labels, bone fragments, fruit peel pieces, etc) remove them with a tweezer.Reinstall the spray arms and see if that works.
Three more ideas:
(1) run a cycle without dishes OR detergent and use 1/4 cup of white vinegar instead. This will break down soil and "gunk" and help your dishwasher run more effectively.
(2) use an old toothbrush and clean the underside of the door INSIDE the dishwasher. The door will be open and you just brush the bottom of the open door on the INSIDE of the dishwasher. A lot of "crud" gathers there and can be redeposite on your dishes. We seldom think to check that area.
(3) the pipe that carries water to the upper sprayer arm MUST fit against the outlet in the back of the dishwasher. If it is dislodged or not seated properly, the water won't flow to the upper sprayer arm.
Hope one of these suggestions helps. If it does, please rate my suggestion. Thanks.
Jun 03, 2011 | GE Dishwashers
How do you reset the spring on the door? the door falls down when opened.
just need to on do the unit from the two screws that hold the top of the dish washer in,,,make sure you have enough hose and power cord to pull the unit out just a little ways,,,but it is always best to unplug the dish washer,,,but the unit needs to be pulled out and the springs just need to be hook back on towards the bottom of the dish washer,,,always work safe,,unplug the dish washer. water and electrical never works together
Feb 19, 2011 | KitchenAid 24 in. KUDI01IL - Multiple...
GE side by side # PSCS 5RGX CFSS freezer shelf fall out
I also have this problem with the same GE Profile series. The shelf sits above the "quick freeze" drawer. It's very annoying and I am looking for a way to fix it.
May 09, 2010 | General Electric Profile PSCS5RGXSS...
Freezer shelf issue, roller adjustment, Icemaker problems
There is not a recall per say on this issue but there is what's called a training bulletin.. The cabinet tends to spread out causing the shelves to fall out typically in the middle.Some models have wider shelves that will not fall out but also can not be pulled out due to the recess in the sides of the inside of the cabinet. The other fix is installing a little c clip on the sides of the trouble shelf in hopes that it will stop it from falling out. part # is WB4X174 and I have not had good results with them but it is a cheap fix. 2 per side are needed. Ge would have to be contacted to see if wider shelves are available but they are very expensive!
Mar 21, 2017 | GE Profile PSC25MSWSS Stainless Steel...
Our GE Profile dishwasher will not open. I have
door latch must have broke take a knife and jimmy the latch
Dec 10, 2009 | GE 24 in. Profile PDW9880JSS Built-in...
Door leaks at the bottom of my ge profile dishwasher
1 has the machine been pushed into the cupboard hole,this will push the door away from the front of the machine,does it hit the trim around the opening before the closeing?pull out check under are the legs still straight,some you can remove the lower front panel to look under
Dec 02, 2009 | GE Profile PDW8400J Built-in Dishwasher
START/RESET LIGHT STAYS CONTINUOUSLY ON
you do not mention the make or model nor do you mention if this was the case since purchasing dishwasher. But before you repost, turn off your breaker to the dishwasher for at least a minute to reset the dishwasher. Hopefully this works. The other options get far more involved and some of them are not for most DIY.
Sep 19, 2017 | GE 24 in. Profile PDW9880JSS Built-in...
GE Monogram DIshwasher
Before taking anything to bits, check you aren't just loading the machine in such a way that something (for us, it's usually a frying pan) is stopping the soap dispenser from springing open all the way. A.
Apr 21, 2007 | GE 24 in. Monogram ZBD6880KSS Stainless...
Dishwashers Logo
487 people viewed this question
Top Dishwashers Experts
