Question about Dell Latitude L400 Notebook
How to upgrade memory in a Dell Latitude L400?
Have Latitude L400 with 128MB ram and I want to upgrade to 256MB ram (maximum allowed) but cannot find instructions how to remove/replace.
  • Dell Master
  • 13,433 Answers
Hi
the service manual has very good instructions and pictures on that.
http://www.elhvb.com/mobokive/edwin/laptops/Dell/LATITUDE/L400/67CUJ0.PDF
thanks and good luck
Ekse
Posted on May 21, 2009
  • Dell Master
  • 19,396 Answers
Follow the instructions here.
Do not forget to leave feedback.
Thanks.
  • 37 Answers
It should be relatively simple =).
Dell notebooks have plates on the bottom where you can unscrew and gain access to specific components, namely the RAM.
If you have RAM already, you'll need to remove the plates. It's a trial-and-error, but usually around the middle of the notebook. From there, simply remove the existing RAM (if you wish to) and replace with your new RAM.
If you do not currently possess the RAM, I suggest newegg:
http://www.newegg.com/Product/Product.aspx?Item=N82E16820159402
That should work, but this is guaranteed to work:
http://www.edgetechcorp.com/memory/upgrade.asp?cid=24692
  • Steve Rolfe May 21, 2009
    Well that was rude.
SOURCE:
Dell Optiplex GX110 currently runs 128mb sdram pc125 cl3.0 . Am I correct to assume maximum upgrade would be 2 x 256mb sdram pc133 non-ecc unbuffered 3.3v ? Maximum memory per slot being 256mb ? Is my...
If I remember correctly, that Dell has two memory module slots, so 2 512 mb modules of non-ecc pc133 memory is the max that the system board will allow.
This is controlled by the system board chipset, and not by the bios.
Dec 15, 2010 | Dell OptiPlex GX110 PC Desktop
Upgrade RAM in a Latitude D600. one bay seems to fail
The memory bay is a part of the motherboard. Try each stick in each bay to make sure that the problem is the motherboard itself. Sometimes memory is incompatible with a particular laptop. Sometimes there is a maximum allowable memory. The maximum for your PC is 2 GB.
Apr 12, 2010 | Dell Latitude D600 Notebook
Adding computer memory
The only thing you could do is put in a 256MB module in the slot that you have access to. Only one socket is user upgradable. The second socket is only upgradable by a Dell service center. They would have to install a second 256 module to get you to the 512MB max.
Jan 22, 2010 | Computers & Internet
Dell Lat d620 duo: ran a full system scan yesterday as I normally do for maintenance and got the BSOD. Message: page fault in nonpaged area. Tried all options to reboot, always eventually gets to BSOD and...
Take out the memory and replace with the old one.
If you have a 32 bit Windows and have more that 4GB RAM then you need to upgrade to 64 BIT.
This is the RAM you need:
Standard Memory : 256MB (Removable) Maximum Memory : 2GB Total Memory Slots : 2 Memory Type : DDR2 533MHz (PC2-4200) 200-PIN SODIMM Notes :
http://orcamemory.com/asp/prodtype.asp?prodtype=11759&ft=m
Jan 06, 2010 | Dell Latitude D620 Notebook
I want my Laptop Dell Latitude C800 physical memory upgraded to 128 mb to 256 mb I myself already installed 256 mb Ram but it still showing 128 mb of memory...can I get help in this regard ?
I assume you installed another 128Mb of RAM to give you a total of 256Mb.
It is most likely the 2nd RAM module is not compatible with the other RAM module. Try using the same make.
OR
Purchase and install a single RAM module 256Mb or 512Mb these are not expensive.
Dec 20, 2009 | Dell PowerEdge 2600 Server
Maximum RAM I can use in Dell Dimension 8500c desktop
please check our model number. here's link direct to dell memory locator page.
Nov 29, 2009 | Acer TravelMate 529ATX Notebook
My Dell Latitude C840 works only with one memory module
Your motherboard is bad or there might be something in the slot preventing the memory from seating properly.Check if there is something in the slot preventing the memory from seatting properly.good luck
Sep 14, 2009 | Dell Latitude C840 Notebook
New ram memory on dell dimension celeron trying to
You should check with the folks at Dell since whoever wrote their technical manuals for this machine can't do basic math. There are 2 memory slots and each can handle a maximum capacity of 512MB, yet they claim the maximum capacity for the machine is 2GB instead of 1GB. Using 512MB modules would probably work.
Jul 06, 2009 | Dell Computers & Internet
I want to upgrade my ram what type of ram should i use and how what is the maximum amount of ram i can upgrade to?
Memory Upgrade for Sony VAIO PCG-K35 Laptop, the Sony VAIO PCG-K35 Laptop takes the PC2100 DDR SDRAM SODIMMs Memory Type, and comes installed with 512 MB = 256 MB (removable) + 256 MB (removable) of Memory. You can upgrade your Sony VAIO PCG-K35 Laptop to up to a maximum of 1.0 GB Memory, the system has 2 sockets to install Memory, already with 512 MB = 256 MB (removable) + 256 MB (removable) standard Memory installed. For best Laptop performance use the maximum amount of allowed Memory per slot for your Laptop.
Regards
Jun 29, 2009 | Sony VAIO PCG-K35 Notebook
Dell Latitude L400 Notebook Logo
291 people viewed this question
Clive
Clive
Alun Cox
