Question about Pioneer Televison & Video
1982 kdk 80
It want record
I have a 1979 yamaha gt 80.i was riding and shifted into 3rd and now its stuck there and i cant shift up or down.why is that
Hi, Anonymous and the usual suspects are:
1. Clutch not disengaging.
2. Bent shift shaft.
3. Shift fork bent or seized.
4. Gear seized on the shaft.
5. Gear positioning lever binding.
6. Shift return springs weak or broken.
7. Shift return spring pin loose
8. Shift mechanism arm spring is broken.
9. Shift mechanism arm is broken.
10. Shift drum is broken.
For more information about your question and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
1982 GT 80 Enduro Wont shift
Fixing the 2nd Gear on Yamaha Triple Engine
YAMAHA DT80 DT100 GT80 FULL SERVICE REPAIR MANUAL 1977 1982 Download... $18
OEM parts for Yamaha
1979 1980 YAMAHA GT80 GT 80 FACTORY OWNERS Manual OEM BOOK 80 eBay
Apr 16, 2012 | Yamaha Motorcycles
I don't have the disk to hook the kodak printer to the computer can you help?
Yes, the software is available from kodaks website, if you wish I would be available to help you right now, we can start a remote support session and I can set it up for you if you wish.
Let me know.
Feb 12, 2011 | Kodak KDK-1099969+KDK-8946139 -...
Kodak esp3 missing 8200ui file
Uninstall the driver / utility with your Control Panel - Add Remove Programs.
Reboot
Then go to WWW.KODAK.COM in their SUPPORT section.
Find you printer by model number and download / install the driver / utility from there.
Good luck and please comment back if this was helpful or if you need further assisance.
Feb 03, 2011 | Kodak KDK-1099969+KDK-8946139 -...
Hello! Audi 80 B3 1982 The ventilator of sitting room only works on top speed. Does the motor broke ?
Perhaps try spinning the motor in polarized fashion if it may broke you.
Aug 07, 2010 | 1992 Audi 80
1982 Aspencade rear suspension Hits solid
Check rear swing arm. When the bike is on the center stand, check the distance of the rear tire to the ground, if it looks too low, might have to do some work. Also, check the rear shock springs.
Oct 03, 2009 | 1982 Honda GL 1100 Aspencade Gold Wing
How do you connect the exhaust to the head on a 1982 DT 80
It's an older model but didn't it have a fibre sort of washer to go into the head,and the flanged end of the pipe was then pushed in.It then may have been held in place by 2 springs from the pipe to the head.I might be wrong so don't bet the farm on it.Hope this helps
Sep 06, 2009 | 1974 Yamaha DT 360
Can I use gl-5 80 90 wall-mart brand gear lube in my 1982 v-45 750 honda sabre
if the bike is a shaft drive,then the oil you are referring to is a gear oil only,will be fine in the rear drive unit as most standard hondas use 80-90 as standard....but under no circumstances put this grade of oil into your engine or gearbox,you will destroy the motor in a very short time
Jun 28, 2009 | 1982 Honda VF 750 S
KDK A.C. Electric Fan needs repaired
The motor is temporarily dead. These fans had a thermal fuse that cut off whenever the motor exceeded certain temperature or if the fuse became defective due to it's own quality. The fan can be repair.
Oct 11, 2008 | Dryers
Televison & Video Logo
20 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
