Epson TM L500A
We keep getting the error message "ERROR MSG COVER OPENED / CANT FEED PAPER" despite the cover being correctly closed and the printing head correctly inserted... What else could it be ?
    Problem Solver:
  • 20 Answers
Locate where the cover sensor is and check the sensor pin or switch
Posted on Jan 03, 2014
  • 3 Answers
SOURCE: printer cover open error message
I had that problem too.
Unplug the printer.
Hold the printer cover open while you plug in the printer.
Then wait for the printer to power on while still holding the cover open.
Then close the cover.
The buttons should work and th error message should be gone.
It worked for me.
Posted on Dec 29, 2007
  • 3 Answers
SOURCE: HP Deskjet 5150 - top cover open
I had the same problem, and the cause turned out to be the cover switch not being fully pushed in. On the underside right edge of the top cover, there's a little triangular protrusion that pushes down a black rectangular button (the cover switch) when the cover is closed. The problem occurs because the flimsy top cover is made of plastic and flexes slightly when you close it. This means that sometimes, the right edge of the cover won't seat properly even though it appears as if the cover is closed all the way. When this happens, the triangular protrusion isn't fully pressing the switch down.
To test if this is this is happening, send a print job to the printer and wait for the "top cover is open" error message to appear. Next, open the top cover door and locate the cover switch. It's a little black button in a rectangular hole at the right edge of the doorway near the ink cartridges. Take a pen or a car key and use it to push the cover switch down. You can also use your fingertip to do this if it's skinny enough. If you keep the cover switch pressed down, the power button should start blinking to indicate a print job is coming through. If the print job actually starts printing, then you know the problem was the cover switch.
In my case, all I had to do the fix the problem was close the cover and make sure it was fully seated by firmly pressing down the right edge of the cover until I heard a plasticky "click" noise. After that, the problem went away.
Hope this helps.
Posted on Sep 16, 2008
SOURCE: Epson Sx200- Paper wont feed
Just a thought,as I had a similar problem.The instructions are abysmal,but it may be worth having a look where you feed the paper in and squeezing the grey plastic gizmo,and moving it to the left to allow the paper to enter the feed properly.
Posted on Dec 28, 2008
SOURCE: epson r2400 won't feed paper
I had the same problem, then found these instructions for cleaning the feed roller: http://www.museofineart.com/files/RollerCleaningProcedureRev2.pdf I used the paper towel method and it's working fine now with no issues.
Posted on Mar 06, 2009
  • 526 Answers
SOURCE: Epson R340 does not feed paper or feeds it crooked
two things I would do, first carefully flip the printer upside down, (anything that looks like it can flap open, tape it well), and jiggle it slightly and see if anything falls out.
second, i would clean the pickup roller with an alcoholic pad or swab, if its not easily accessible, you will probably need to take the upper an middle casing off, which I dont recommend.
thanks adi
Posted on Jan 02, 2010
Print not clear, double struck, cartridges are new and sometimes paper jams
Paper Does Not Feed Correctly - Epson
https://files.support.epson.com/htmldocs/pho22_/.../trble_4.htm
EpsonPaper does not feed correctly when using the double-sided printing feature. If one of the ... The ink cartridges are not empty. ... If the error does not clear, open the printer cover and remove all of the paper inside, including any torn pieces. Then ... If yourpaper jams frequently, make sure of the following: ... Load a new stack.
Epson Stylus COLOR 600, Top FAQs - Technical Support ...
www.epson.com/cgi-bin/Store/support/supDetail.jsp?...FAQs...
EpsonThis link provides access to Top FAQs for the Epson Stylus COLOR 600. ... I just replaced an ink cartridge and the printer still won't print correctly. ... [ Answer ]; The printer is not producing any black or color ink. ... [ Answer ]; I'm only getting partial printouts or a "paper out" or "printer off line" error appears. ... How do I clear this?
epson printer problems ' FixYourOwnPrinter
www.fixyourownprinter.com/posts/23851
I loaded a new black ink cartridge into my Epson Stylus C86. .... hit this problem when we first bought it, apparently it needs all colours to print ... i am using Epeon L 110 printer The colour print was good before But now the colour print is not clear ... No paper jams (sometimes paper feeds sometimes it doesn't). it appears that ...
Jan 05, 2016 | Epson Stylus NX420 Inkjet Multifunction...
Tip
Main Error MINOLTA DI 1611, DI 2011 Messages and Their Remedies
PAPER JAM A paper misfeed occurred in the
main unit.
Open the cover at the indicated
location, and then remove the
misfed paper. (“When the Message
(Flashing alternately)
OPEN XXX SIDE COVER
All misfed paper was not removed
from the main unit.
Check the message in the display
for the location of the paper misfeed,
and then remove the misfed paper.
ORIGINAL DOC.JAM A paper misfeed occurred in the
Document Feeder.
from the Automatic Document
Feeder.
Open the Document Feeder Cover
and the Document Feeder, and then
OPEN DOC.FEED COVER
∗REMOVE PAPER IN
BYPASS TRAY∗
Paper is loaded in the Manual
Bypass.
Remove the paper from the Manual
Bypass.
FRONT COVER OPEN The Front Cover of the main unit is
open or not securely closed.
Securely close the Front Cover.
CLOSE FRONT COVER
DUPLEX COVER OPEN The Duplex Unit Cover is open or
Securely close the Duplex Unit
Cover.
CLOSE DUPLEX COVER
DOCUMENT COVER
OPEN
The Document Feeder is lifted up
(while a document is loaded into
it).
Securely close the Document
Feeder.
CLOSE DOCUMENT
COVER
DOC.FEED COVER OPEN The Document Feeder Cover is
open.
Feeder Cover.
CLOSE DOC.FEED
COVER
TONER EMPTY The toner is empty. Copying and
printing cannot be performed.
Replace the toner bottle with a new
one.
SUPPLY TONER
PAPER EMPTY The selected paper tray has run
out of paper.
indicates the paper tray, and
“XXX” indicates the paper size.
Load paper of the specified size into
the specified paper tray.
on Dec 18, 2009 | Office Equipment & Supplies
I received a cleaning failed message on my epson TM-u325d
For some reason, our clients bought the Epson TM-U325D, and now we are charged with the duty of fixing these things. So, I, naturally ran the self-test upon first starting the printer (hold down the feed button while powering it on) and it went through both parts and I received a "Completed" message. After a second, it printed out a message that said "This is validtion sensor self-cleaning start message. Wait for a while.". It then began opening and closing the clamp for about five or six iterations of this. Then it prints :Cleaning failed. Please call a service person." Sound like your message or error? Well, in this particular instance, this is how I solved it:
First, I removed the printhead, and cleaned out the built up, dried ink along the pins just behaing the print surface. I ran 99% denatured alcohol through the printhead (careful to not get it on the PCBs, but let it flow out the front) until the alcohol came out clear. I then disassembled the print mechanism and cleaned the two rods, the printhead carriage with alcohol. I then took some simple lubricant like MArvel Mystery Oil and lubricated the felt bushings within the printhead carriage and the two guide rods. I then made sure no pieces of debris like paper dust or pieces of paper were anywhere else. I put everything back together, and the error no longer occurred.
Hope that helps. I've fooled with several validators, and 95% of the time, it seems to be that they are just dirty if they haven't been abused or run to *****. It can be time consuming, but a lot of things can be fixed with a thorough cleaning.
Mar 02, 2012 | Epson TM U325D Matrix Printer
The paper keeps jamming, I cant see anything in the way. any help is appreciated.
If paper doesn't feed correctly when printing, remove it and fan the edges of the paper to separate the sheets. Reload the paper against the right side and slide the edge guide against it. Do not load too many sheets at once.
If paper has jammed: 1. Press x Start to eject the jammed paper. 2. If paper is still jammed, gently pull it out from the output tray or sheet feeder. If paper is stuck inside, press the P On button to turn off the printer. Then lift the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the printer back on.
If documents don't feed correctly in the Automatic Document Feeder, make sure the corners of the paper are not bent, folded, or curled up. Do not load more than 10 sheets of legal-size paper at a time. If documents have jammed: 1. Open the ADF cover and pull any paper out to the left. Caution: Do not try to remove the paper without opening the ADF cover first, or you could damage the mechanism. 2. Select Yes or press OK to clear any messages on the display screen. 3. Reload the paper.
Feb 28, 2011 | Epson WorkForce 600 All-In-One InkJet...
When i print the test page on my epson TM-T88IV it displays the "paper out" error when the paper is there. What could be the problem? Please help because they are two of them doing the same.
Try to take out paper roll and try reinstalling it, make sure cover is closed properly as well.
If same issue persist, call your dealer or Epson for Authorized Service Centers. Or you may Visit their website at www.support.epson.com
Hope this helps.
Feb 16, 2011 | Epson TM T88 Thermal Printer
Does epson tm-t88iiip have a ribbon
No. thermal printers do not use ribbons or ink cartridges. They have thermal heads that heat up and use that heat to print on the specially treated, heat sensitive paper rolls. If the printer has stopped printing, check to see if the paper is thermal and loaded correctly (shiny side facing the front when it feeds).
Jul 13, 2010 | Epson TM-T88III Thermal Printer
The error light on the Epson TM-T88IV keeps flashing whats wrong with it?
The following is from the Epson Users Manual:
Troubleshooting
No lights on the control panel
Check the power supply cable connections and the power outlet.
ERROR LED on (not flashing) with no printing
If PAPER OUT is on, the roll paper is not installed or is near the end.
If PAPER OUT is off, the printer cover is not closed properly.
ERROR LED flashing with no printing (and no paper jam)
Printing stops if the head overheats and resumes automatically when it cools.
If overheating is not the cause, turn the printer off, and after 10 seconds, back on.
Removing Jammed Paper
CAUTION:
Do not touch the thermal head because it can be very hot after printing.
1. Turn the printer off and press the cover open button.
2. Remove jammed paper, reinstall the roll, and close the cover.
3. If paper is caught in the cutter and you cannot open the printer cover, open
the cutter cover as shown in illustration J.
4. Turn the knob until you see a triangle in the opening. This returns the cutter
blade to the normal position. There is a label near the cutter to assist you. See
illustration K.
5. Close the cutter cover.
6. Open the printer cover and remove the jammed paper.
Cleaning the Thermal Head
CAUTION:
After printing, the thermal head can be very hot. Be careful not to touch it and
to let it cool before you clean it. Do not damage the thermal head by touching
it with your fingers or any hard object.
Turn off the printer, open the printer cover, and clean the thermal elements of the
thermal head with a cotton swab moistened with an alcohol solvent (ethanol, or
IPA).
Epson recommends cleaning the thermal head periodically (generally every
3 months) to maintain receipt print quality.
It sounds like your print head is overheating. Clean as instructed above.
Oct 23, 2009 | Epson TM T88 Thermal Printer
Epsom TM-U220 Error Codes
From the manual its probably one of this item.
-printer temp is too high
-cover is not properly closed
-print head is not in the correct position
-paper cutter is not in the correct position
-paper jam
Try turning off the printer, remove the power cable, turn it on again for 5 seconds to reset it. Connect back power cable, press the feed button and turn it back on. The printer should do a self test, turn it off and on again after the self test. It should make the red light go away.
Oct 27, 2008 | Epson TM-U220 Matrix Printer
Epson aculaser cx11nf MP E paper jam
open the mp tray
locate 2 white plastic egg shaped piece on the ends of the steel rod
gently push one or the other towards the back of the machine
if the paper jam error message is on then the roller will turn as soon as you give it a push
re load the paper
open and close door a or e
printing should resume
that white piece works with the paper lift to get the paper up to the in feed roller
Sep 01, 2008 | Epson ACULASER CX11NF All-In-One Printer
Cd tray error Canon Pixma MP810
Sorry a little late only just read your problem.
The location is not the bottom tray feeder but the disk tray. In settings change your media type to "Printable Disk" the paper scource should automatically change to "Disk Tray" and hopefully every thing will work OK.
May 19, 2008 | Canon PIXMA MP810 All-In-One InkJet...
83 people viewed this question
jasbo
jasbo
