Question about Pioneer PL-990 Turntable
I need to reattach the belt under the table
The belt is not attached below the table. I need easy instrustions on how to reattach it so we can use it. Pioneer Turntable model PL-990
  • hewson7691 May 22, 2009
    Thank you so much.
  • 864 Answers
Download the manual free at http://www.nodevice.com/user_manual/pioneer/other_home_component/pl-990.html
There are instructions there and pictures showing how to attach the belt.
Posted on May 21, 2009
How do i change the alternator on a 2000 Chrysler Concorde lxi?
I have a concorde. Let me tell you its not easy to work on. The alternator is located just below the power steering pump. The power steering pump is attached to the power steering reservoir. To gain access you have to remove the metal plate that has the washer fluid bolted to it. It has alot of bolts. Then remove the radiator fans so you have more room to work. The engine has two belts. Once you get the belts off the alternator is attached by a metal plate just below the power steering pump. Once its loose remove it from under the car. Hope this helped.
Sep 26, 2014 | 2000 Chrysler Concorde
Altenator
These are instructions that I found online. From reading them I am glad I have not yet had to replace the alternator on "MY" Sedona. Hope this helps as the KIA manual does not supply alternator R & R instructions. Good luck.
As for #5 I removed the front wheel and plastic panel when I had to replace "just" the serpentine belts and idler pulley.
1. Remove the terminal connections on the battery. Allow 30 minutes to pass for the airbags to automatically disable.
2. Remove the air filter intake. The air filter intake is the large plastic box above the radiator that is connected to the air filter housing. With the air filter intake removed, you can now remove the support beam above the radiator itself. You will have to use a Phillips screwdriver to remove a total of 10 screws from the support beam.
3. Place the large pan underneath the vehicle right under the radiator. Unplug the two radiator hoses that are connected to the radiator.
4. Remove the pipe that the radiator hoses were connected to. Remove both fans that are attached to the radiator by unscrewing the four screws holding each fan in place. This will allow access to the alternator itself.
5. Remove the serpentine belt by loosening the manual adjustment pulley held in place by two nuts. Use the socket wrench to remove the nuts and then remove the serpentine belt. Remove the support bar that connects the engine block to the alternator. Remove the 2 screws holding the support bar in place to remove it.
6. Remove the three bolts on the left side of the alternator. Disconnect the wire harness to the alternator by squeezing the tabs and pulling it out. Disconnect the hot connector by pulling it out. Pull the alternator out of the vehicle. Place the new alternator into the vehicle and reconnect the hot connector and wire harness to the alternator.
7. Reattach the support bar by reinstalling the two screws. Reattach the serpentine belt into the vehicle and tighten the manual adjustment pulley. Reattach the two nuts holding it into place.
8. Reattach the fans attached to the radiator. Make sure there are four screws for each fan to secure it into place. Reattach the pipe that the radiator hoses were connected to and reconnect the two hoses that were connected to the radiator.
9. Use all ten screws to reattach the black support beam above the radiator. Place the air filter intake back into the vehicle. Reconnect the terminal connections to the battery and close the hood.
Jan 18, 2013 | 2004 Kia Sedona
Need to no how to reatach it came off
Did you mean that you need to know how to reattach your bicycle or some parts? Each model is different. Tell me your model and which part you wan to reattach, I will send you information. In the meantime,the link below show you short video clip in general how to reattach rear bike tire, but also has links to other parts that you may want to check it out.
http://www.wonderhowto.com/how-to-re-attach-your-rear-bike-tire-after-removing-135198/
Jul 26, 2011 | Cycling
BEATER BAR WILL NOT WORK. I ACCIDENTLY RAN VACUM OVER SMALL THROW RUG WHICH GOT CAUGHT IN BEATER BAR AND IT STOPPED AND I COULD SMELL BURNING. I SHUT IT OFF RIGHT AWAY. WHAT DO I DO?
remove the bottom of the machine, and if your lucky re attach the belt, if not replace it , you need to remove the beater bar to do this, so prior to taking it out, look at the ends so you know where they are and the positioning before you remove it for easy reattachment
Jul 03, 2011 | Miele Vacuums
The belt inside my scanjet 4200c has come off. How do I reattach it? I have opened the scanner. It looks to be relatively easy but I don't know how to attach the belt to the motor etc
Instructions
1 Lift the hatch on the feed tray and pull up the large green tab to the left of the roller. Remove any jammed or torn paper from under the roller and around the feed tray.
2 Pull the input feed tray out of the automatic document feeder. Grasp the feed tray with both hands and pull it straight out.
3 Check the interior of the automatic document feeder for jammed paper. Remove any jammed paper, then reinsert the feed tray into the automatic document feeder. Push down the feeder cover until you hear a click.
Mar 08, 2011 | HP Scanjet 4200c Flatbed Scanner
The pulley attached to the arbor for the belt on my 15 year old table saw keeps flying off. It is the type with a metal spline that goes into a slot in the drive shaft and two hex screws to hold it tight....
Sound like a nasty problem. Something has to be wrong, maybe the keyway is cammed out on the arbor shaft?? Did you try some lock tite, on the set screws, then I am guessing you got the set screws tight for sure? I know thats not easy. I deal in table saw parts on ebay as "Hokienpokie" if you need to try a different arbor assembly I should be able to get you one with your saw model #, Jim
Dec 10, 2009 | Craftsman Saws
Table not roatating
There is a belt and a motor that turns the table. If you take it apart you will find both under the bottom plate. Neither part is expencive and are easy to replace.
Please rate solution
Sep 07, 2009 | Panasonic Microwave Ovens
I have a 10' Craftsman table saw model 315-218290. I ordered new belts I removed the motor how do you attach the belts, I tried to stretch it won't work
Jun 20, 2009 | Craftsman 10" Table Saw
Broken piece on an old Craftsman table saw
Boy I would be livid if it were my saw. I had a similar problem with a very old marine engine I resrored. A casting was damaged and not avalabled so I went to a machine shop who sent it or to be welded and than the shop tooled it. You can give it a try if you can't find the part. Good luck.
May 03, 2009 | Craftsman 10" Table Saw
Pioneer PL-990 Turntable Logo
1,250 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
