Duraflame heater stops working until its unplugged
DuraFlame heater model #DFS-750-6. Heater works great for a bit then stops blowing. If its unplugged for a while then plugged back in it will work fine for a few hours and then do the same thing.
night71
  • 328 Answers
SOURCE: No Heat!
Sometimes too much dust around the heating elements can cause the heater to switch off to prevent a fire. Check for dust build up first. You can try using a can of compressed air that can be found at many electronic stores.
Posted on Oct 26, 2007
  • 19 Answers
SOURCE: troubleshooting reddy heater 115,000btu
Remove the nozzle and clean it. Clean the photo cell also. Check the fuel pump pressure it should be 5.1 #.
Posted on Mar 06, 2008
rickzilla
  • 706 Answers
SOURCE: Heater wont blow hot air anymore.
In all probability the heating element has failed and the cost to repair would be more than the cost to replace it. Inexpensive heaters do that over time.
Posted on Dec 02, 2008
  • 3 Answers
SOURCE: my heater won't turn on.
There really isn't anyway to give a difinitive answer to your problem. it requires some trouble shooting. Did you blow the breaker on the circuit feeding the outlet you had your heater plugged into? Is there a power indicator light on your heater? If so, when the dog tipped the heater over was it still working (ON)? If no indicator the problem gets more tedious and techy.
Oil heaters are great and simply designed. They are closed systems with heating elements that connect to the other end of the wire that plugs into your wall. The switch is in between the two to allow current to pass or not. If any of those connections was shaken loose by the fall it would cause your heater to malfunction. That's something you (or a service person) can only verify by opening the unit up. Hope this has helped...:-)
Posted on Jan 15, 2009
runs for awhile shuts down with a big puff of smoke comes out poured diesel 911 thought i had water in diesel fuel cans nothing help need solution ASAP
Posted on Jan 18, 2009
Duraflame dfs 950-5
If your Beats not working that means your heater coil is going out change out the mini heater calls its 99% won the most breaks that you're going to get on a dryer
Feb 07, 2018 | Dryers
NO FLAME
There are little light bulbs (like large Christmas lights) that have probably burned out.
remember to replace with only the same wattage and type.
Apr 12, 2014 | Duraflame Electric Fireplace Stove DFS-750
Blown fuses
a popped breaker is a short in circuit, first check cord for damage, second it could be heater shorted to block. best checked with multymeter on ohms scale, circuit through block heater is usually 25 to 45 ohms.
Mar 13, 2014 | Duraflame DFS-550-0 Black Metal Electric...
DFS-550-29 REDUCED EFFICIENCY
sounds like the heating element is going bad..its probably intermittant..
Jan 08, 2014 | Duraflame DFS-550-0 Black Metal Electric...
Does this use a lot of electricity? My bill went up after using this for the first month.
It does use a lot of electricity, all stoves do. You can reduce the amount it uses by turning it off.
Dec 20, 2013 | Duraflame Electric Fireplace Stove DFS-750
My Duraflame heater model dfs-550-0 , heats well but my flames no longer work . is there anything I can do to fix this problem? someone please help!
Actually, it could just be a burnt out light bulb. Open the back. The light bulb is easy to get to and easy to replace.
Aug 27, 2013 | Heating & Cooling
Duraflame heater runs for 5 mins and shuts off
try cleaning off the filter that is on the bottom in the back of the unit. It is a fail safe sensor that in the event the unot overheats it shuts off the heater. Worked for me on mine.
Oct 06, 2012 | Duraflame Colby Indoor Infrared Quartz...
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
