Question about Whirlpool 800 Series Undercounter Trash Compactor TU800SPP
How to remove whirlpool trash compacter
CAN NOT FIND RETAINERS TO REMOVE FROM UNDER COUNTER
  • Official Brand Answer
  • 401 Answers
Hi Larry, you can download the installation manual from the link below which should also have some instructions for removing the compactor. We hope this helps!
http://bit.ly/112Lu7q
Posted on Feb 07, 2014
How to thread the belt on the idle wheel and pulley without it coming off
Sheryl
should be doable as long as it does not have welded belt retainers,
if it has removable bolts or guards which help keep belt from falling off, remove these first. good luck
press the helpful button
the link below shows how to do it, but is not your model, hope it helps Dryer Not Spinning Whirlpool Kenmore Electric Dryer Repair Part 341241
Jan 18, 2016 | sonya Portable Compact Small Laundry Dryer...
How remove stuck compactor from under counter?
Thee should be two screws from the compactor going into thE countertop. (You have to get a light, then shine straight up under the countertop. Remove the screws, then you can slowly work the compactor out of the hole so you can work on it.
Jul 03, 2014 | GE Profile GCG1580LSS 15" Built-In Trash...
Compactor ram stuck partially down & door open 2 inches. How do I get the ram to go back up & get the door closed?
We just had this same problem. Your problem is most likely abroken plastic gear found at underneeath the bottom of the compactor. Pull out the compactor and turn it upside down. Remove the bottom panel and that is where we found the broken gear. We were able to retract the ram and open the drawer by manually turning the drive chain using an ajustable wrench. Clockwise is compact, counter clockwise is retract.
Feb 03, 2010 | GE Profile GCG1580LSS 15" Built-In Trash...
Replacing door gaskets on model EF19MKXSN00
The gasket is held in place by metal strips on all 4 sides with a lot of screws. Loosen do not remove the screws and pull the gasket out from under it, Warm the new gasket in some hot water and tuck back under the retainers. Tighten the screws snug not overly tight. Use a heat gun or hair dryer to seat the new gasket and remove the wrinkles. Careful not to overheat and melt it.
Eric
Oct 21, 2009 | Whirlpool Refrigerators
GE Profile trash compactor is stuck
This has happened a couple times to me and the fix is fairly simple. The problem is the trash ram is pushing down on the edge of the metal of the trash compartment because the door is partially open. The solution is to back-up the ram the the door will close.
To back-up the ram, you will need to pull the compactor out from under your cabinets and unplug it. Turn the compactor on it's side to expose the bottom. There is a plate on the bottom that covers the motor gears. Remove the plate and turn the large gear counter-clockwise to back-up the ram screws (at least this is how it works on my model works). The gears are a little greasy so you may need to add some after messing with the gears.
Good luck.
Oct 21, 2008 | GE Profile GCG1580LSS 15" Built-In Trash...
Jenn-aire compacter can't close
Hi marigf5,
I'm Harvey the Master Plumber.
Your problem is: you cannot get your compacter to close.
First, don't force it. Chances are something has fallen behind the drawer and is in the way. Just remove the drawer and clear it. If something is broken, you still have to remove the drawer to see and repair it. If you run into trouble you might consider utilizing the Repair Directory to find a repairman.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 14, 2008 | KitchenAid P Series Trash Compactor -...
Trash Compactor Removal
I noticed that my compactor attached to the countertop above it at the front, but that it is also possible to do the same at the back. Can you get access under the cabinet at the back of the compactor and check it out?
Jul 13, 2008 | GE Profile GCG1580LSS 15" Built-In Trash...
Whirlpool 800 Series Undercounter Trash Compactor TU800SPP Logo
228 people viewed this question
Top Whirlpool Kitchen Appliances - Others Experts
richie46
Are you a Whirlpool Kitchen Appliances - Other Expert? Answer questions, earn points and help others
