Question about NetGear WGR614 54Mbps Wireless Router (obwgr614_1)
Open block sites
I have a netgear router
and my administrtor is block orkut web
when i want to connect with the same a massege i recive " this service is blocked by netgear firewall"
  • Michael Galve
    Michael Galve May 11, 2010
    Try to use proxy websites instead. If the administrator blocks certain website, you cannot do anything about it but use a proxy site.
  • Shoaib Rais
    Shoaib Rais May 11, 2010
    try proxy sites like
    google Proxy sites and try one of them to browse the appropriate site
    regards
Orkut is bloacked. we cannot access it. we want to open it.our server is windows 2003
Posted on Jan 21, 2010
  • 854 Answers
A. Determining the IP Address and MAC Address of a Computer:
Note: Please use the computer for which the Ports are to be opened:
For Windows 2000/XP users:
1. Please click on Start and select Run.
2. Type in cmd and click on OK.
3. In the Command Prompt, please type ipconfig/all then press Enter or Return key.
4. Please make sure that the Ethernet adapter has an IP Address that is the same range as the router (e.g. 192.168.1.2 for the computer and 192.168.1.1 for the router).
5. Please note down the IP address and Physical address.
B. Reserving an IP Address:
1. Please open any web browser like Internet Explorer or Netscape Navigator.
2. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
3. A window will prompt for a user name and password. The default username is "admin" and the default password is "password".
Note: If it does not take password as the password, you might have changed it when you have run the NETGEAR Setup CD so please try other passwords. If you cannot remember the password, you need to reset the router and run the Setup CD to reconfigure it.
4. When the setup page opens, click on LAN IP Setup under Advanced tab.
5. Click on Add under Address Reservation.
6. Under Address Reservation window, please select the radio button of the computer you wish to add from the Address Reservation Table.
7. If the computer you want is not on the list, please click on the Refresh button to update the table.
8. If the computer is still not on the Address Reservation Table, please type in the IP Address, MAC Address (Physical Address), and Device Name of the computer you wish to add.
9. Click the Add button when done.
C. Enabling DMZ:
1. On the left side of the setup page, click on the WAN Setup under Advanced tab.
2. Check the Default DMZ Server and specify the IP address of your computer.
3. Click on the Apply button.
Posted on May 28, 2009
How do i block facebook
Login to router with web browser
192.168.0.1
user: admin
password: password
Go to Security and add Keyword facebook. Do not add .com. It will block all sites. Figure 5-3.
http://kbserver.netgear.com/pdf/dg834_g_b_manual_v2.pdf
Oct 07, 2012 | NetGear DG834G Router
My facbook site block by netgera so now what shoud i do
How to Disable the Netgear Router Firewall how-to-disable-the-netgear-router-firewall.gif To disable the Netgear Router Firewall, add a new rule that allows all access from the outside to the inside.
To do this, type the router's address (the default is either 192.168.0.1 or 192.168.1.1) in the Web browser
Enter the username and password in the prompt that appears. The default username is admin and the default password is password.
From the main menu, choose Security -> Rules
Add a new rule for Inbound Services with a service name of "ANY" and an action of "ALLOW always."
Then, move the new rule up until it is the first rule in the Inbound Services section.
Finally, make certain that this rule is enabled by checking the Enable column.
The Netgear Router firewall is now disabled and the internal network is now completely unprotected and open to attack from the Internet.
Sep 19, 2011 | Computers & Internet
Web Site Blocked by NETGEAR Firewall
The most common problem for your case is that the settings at the Netgear router block the web site you are trying to visit. Go at the router's settings page, locate the firewall settings and temporary disable the firewall. Check the results. In case this solve your problem, either disable the firewall or modify the existing rule that block the url that you visit. Alternative you can check the block site list at the router settings page (sometimes called parental control) and remove the url from this list.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer. Also clarify me the model of your Netgear router and the site that you have the problem.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Aug 04, 2011 | Computers & Internet
Every time i try to get to my facebook account it says Web Site Blocked by NETGEAR Firewall
Usually this refers to the netgear network router that is used where you are trying to connect to facebook. Whomever owns the network equipment is likely blocking facebook. If you are the one who owns the equipment I would recommend logging into the web interface of the Netgear router, going into the Block Site option on the left hand side (see pic below) and unblock the reference to Facebook.
The web interface, by default, is http://192.168.1.1 and is protected my a username (admin) and password which you would have set when you first configured the device. If you don't know the password you will need to reset the router using the instructions provided by netgear on their website (http://www.netgear.com) under support.
I hope this helps!
Here's the pic of this web interace window:
Mar 17, 2011 | Facebook Social Network
Orkut site not opening
Where does the problem lye in Home or in Office ?
In office those sites might be blocked.
If it is in home then login into the router and check if the site is blocked in ACL and enable the site.
Oct 25, 2010 | Computers & Internet
In my college netgear fire wall block some sites like orkut .i want to access that sites
If the IT dept have blocked such website, you will not be able to bypass them, however you can try using OPERA Browser and try opening the website. it should work.
Jul 03, 2010 | Computers & Internet
I have firewalled wireless router of netgear at my collage. it has blocked the orkut. neither the proxy nor any method is working to browse orkut. pls give some technical help
You can download Ultrasurf (it is like proxy)and install in your computer,and use this brouser to access orkut.
link for ultrasurf
http://www.ultrareach.com/
Hope it resolved your this issue
Happy to help
Thanks for using Fixya
Feb 09, 2010 | NetGear ProSafe FVG318 (606449041668)...
How to open orkut if it is blocked
you can download ultrasurf from 4shared.com and search for ultrasurf 9.5
you should download and click the program after installation and it will load and it will say that connected sucessully and then go to your internet explorer or browser and then go to orkut you will find it unlocked
Jul 18, 2009 | Nokia IP 350 Firewall
How to disable content filter applied by administrator
Go to www.mylinktrain.com or proxshare.com. That's a list of web proxies to bypass your firewall or the web filter. You may need to try several sites to find a web proxy that can play videos on youtube.
Jun 10, 2009 | NetGear RangeMax NEXT WNR834B Wireless...
Netgear wireless router WGT 624v4 not accessing some websites
if the router was the problem, then no site would be accessible from either of the problem pc's.
unless the webkinz site is being blocked because it contains active scripts. check the configuration page for the router (usually 192.168.1.1) and switch off any active firewall / security applications running on the router.
May 30, 2008 | NetGear WGR614 Wireless Router
NetGear WGR614 54Mbps Wireless Router (obwgr614_1) Logo
509 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
