Question about Admiral ATW4475XQ
Admiral model atw4475xq0 will not go into rinse / spin cycle
Top loading washing machine will not go from wash cycle to rinse cycle. It will just set there and nothing happens.
SOURCE: loud noise while agitating in wash cycle
If you begin dissassembly from the tub down, you wil come to the transmission with the spindle sticking out of it. If you undo the bendable tabs all around the transmission it comes apart in two halves. Careful, its full of oil. The spindle has a plastic gear bolted to the bottom of it. It meshes with other gears in the tranny. It has sheered teath and is making the noise.
Posted on Feb 11, 2008
SearsTechToo
  • 261 Answers
SOURCE: Top load washer Admiral # AAV7000AWW
I would replace the belt part # 21352320 which cost about 20 bucks. Tilt the machine back when off and empty and look for a glazed belt with maybe some cracking and wear.
Posted on Oct 04, 2008
rylee_smith
  • 8619 Answers
SOURCE: washing machine does not spin.
Hi
Thanks for using FixYa. If your washer pumps out the water but doesn't spin, check these:
The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. The motor coupler may be broken. Many washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. A belt may be broken. The clutch may be worn. It may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor. The transmission may not be shifting properly. The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Replace whichever part has gone bad. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on May 08, 2010
SOURCE: Admiral Mega 22 Plus-Heavy Duty-2 speed Washing Machine
After spinning it does not release the water
Posted on Aug 04, 2010
SOURCE: Admiral Washing Machine not spinning
y Admiral washing Machine modle # lnc6760b71 will fill with water and agitate. But when it come time for the spin cycle it wont spin. I can hear the motor making noise. and now stop and it does not work, does not smell to burned What should I do??
Posted on Jan 12, 2011
I have a admiral washing maching, model LNC6766B71, it is top load. It makes a load noise in spin mode.
if noise is constant maybe bearings? Is the load even? Not totally familiar with item but the I think the two possibilities above are worth considering. Do an spin on empty. NOISE??? I would guess bearings.
Jan 02, 2016 | Admiral Washing Machines
I set my washing machine to run when I went to work. When I got home the dial looked as though it had run through the settings but the machine was still filled with water. Then I tried setting the dial...
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 24, 2011 | Admiral Washing Machines
Won't rinse/spin
heatman101
May 06, 2011 | Admiral AAV7000A
Does washer drain before the spin cycle starts?
Normally yes. There are around 12 to 20 gallons of water in the tub after the wash cycle, which will be anywhere from 63 to 110 pounds of weight in addition to the weight of the clothes. For the machine to start the spin cycle to remove this water would place a heavy load on the motor, gearcase, pullys, belts, gears, ect. With the water drained, the load is lighter, and much easier to start spinning the excess water out of the clothes. The normal cycles are: Fill, Agitate, Drain, Spin, Rinse Fill, Agitate for rinse, Drain, Spin Cycle and off. Imagine trying to spin a 5 gallon bucket of water over your head, full of water, and then empty. Which one do you think would be easier to do? And safer for you.
Sep 26, 2009 | Admiral AW22 Top Load Washer
Sep 01, 2008 | Admiral AAV7000A
Admiral Leaking
Possibly rinsing with cold water, washing with hot.
Check inlet valves for leaks, especially cold (rinse)
Lift the top panel by inserting a flat blade approx 4" from each side at the front to release clips, then top will hinge backwards.
You can see the valves at the rear behind the drum..
You can run the machine with top lifted to see any more leaks.
Also remove front panel via 2 small screws to gain better view.
Jul 12, 2008 | Admiral AW22 Top Load Washer
Estate by Whirlpool washing machine will not drain or go into spin mode in any cycle.
I would try and check voltage at the overload on the motor
when in spin cycle and see if you have power there..
 that should tell ya if your at least getting power from the timmer or not in the spin cycle to the motor
Sep 04, 2007 | Admiral AW22 Top Load Washer
Admiral washing machine MOdel AAV7000AWW On any spin will not drain 1st time through
is this machine induction motor or carbon brush if it is the inductin you need to be looking at the capacitor and if it is carbon brush then change them you will find them mounted each side of the motor and the capacitor will be @ the top under the lid near the pressure switch good luck
Jul 24, 2007 | Admiral AW22 Top Load Washer
Admiral ATW4475XQ Logo
111 people viewed this question
Top Admiral Washing Machines Experts
Dan Webster
Dan Webster
Sal DeAngelo
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
