Question about Vacuums
Philips manuals Phillips HTS 3537 manual
Is there a manual for a Philips steam plus 2 in 1 mop . we only have a small book with diagrams in it thanks
this is all Phillips supplied with mop.
http://download.p4c.philips.com/files/f/fc7021_01/fc7021_01_dfu_eng.pdf
Jan 15, 2018 | Philips Vacuums
Philips register product
Contact Philips, the information is in your owner's manual.
Aug 24, 2014 | Vacuums
I have been lent a Philips Baby Monitor 0682 without a manual and don't know how to work it. Can I access a manual on line, if so How, or do I have to buy one,if so How? Grateful your advice, John...
Hi John.
0682 did not correspond to any known Philips baby monitor model...at least nothing came up in Philips support database. I published below the manuals for different Philips baby monitors. Please check if any of them corresponds to your series.
Philips SBCS369
Philips SBCSC469
Here a list comprising the manuals for most Philips baby monitors models.
Regards.
Ginko
Aug 11, 2011 | Vacuums
How do I register my new Philips shaver and get extra 1 year guarentee
I found a number for norelco phillips I am sure they can help you 1-800-243-3050
Mar 16, 2011 | Philips Vacuums
Bought a Philips Voice Tracer LFH0646 and require access to the user manual.
You can download and print the manuals in PDF format by clicking these links.:
User manual
Quick start guide
Adobe PDF Reader is required to view the manuals. Download Adobe Reader
Hope this helps. Kindly let me know if you have any difficulty in downloading the manuals.
Thanks for using FixYa.
Feb 12, 2011 | Philips Vacuums
Where do i put the trash bag in the machine?
I have access to the service manual for this machine if it will help you.
Dec 03, 2009 | Philips Vacuums
How do you chabge the belt in the dirt devil ultra swivel?
Attached is a copy of the link for the manual. I have included the steps here, but the manual has drawings on page 10 of the manual, it will tell you how to change the belt. You will need a phillips screwdriver.
  1. Lay cleaner flat and flip cleaner to expose nozzle base. Base should lay flat end face up. To remove nozzle guard, use Phillips or Flat head screwdriver to remove the 5 screws. Arrows on diagram shows locations of screws.
  2. Lift nozzle gueard off.
  3. Be sure belt is off motor shaft. Lift and remove brushroll. Dispose of old belt.
  4. To Replace belt, Slide belt onto motorshaft
  5. Place new belt in area of brushroll without bristles
  6. With new belt in place, pull end slide brushroll into nozzle making sure that the brushroll end caps are in the correct orientation. Rotate brushroll manually to make sure belt is prperly aligned.
  7. Reattach nozzle guard
  8. Secure by aligning the 3 tabs in the base slots. Replace all 5 screws to secure nozzle guard.
http://www.dirtdevil.com/CustomerService/Manuals/default.aspx?id=23331
Please rate this solution
Jul 31, 2008 | Dirt Devil Vacuums
Vacuums Logo
238 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
