Question about Craftsman Gas Mini - Tiller/Edger
Can't remove the nut holding blade on. Which way do I remove
Craftman edger model #536-796526 which way does nut remove?
  • 10,865 Answers
Get some WD-40 and spray the area around the nut then let it sit for a few hours. This will get into the threads and loosen any rust that is compounding your problem. Now get a good wrench and look directly at the nut. Left is loose and Right is tight.
Posted on May 21, 2009
LT2000 craftman mower bolt and nut that tightens blades keep coming loose
Get some red lock tight and put it on the spindle shaft threads. Sounds like the threads are worn down and just won't hold the spindle nut tight any longer.
Jul 02, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman edger model 358.796480 blade not cutting. Am I doing something wrong? Seems like looks OK but still not cutting.
Assuming the obvious that the motor is turning, the only thing that would keep it from cutting is that the nut holding the blade is not tight enough or the sping washer between the nut and the blade is missing or on backwards. The correct orientation of the spring washer is so the inside surface around the hole contacts the nut, and the outside circumfrance of the washer contacts the blade. P.S. the nut is tightened very tight.
May 18, 2014 | Garden
Replacing husqvarna edger blade
Always try to use genuine parts as cheaper parts can be very poor quailiy and some times dangerous.
Jun 02, 2017 | Husqvarna Garden
Change an edger blade
Start here to find User's Manual. Sometimes the nut/bolt holding the blade on is a Left Hand thread and requires CW turning to loosen and remove. Not sure on this model.
Aug 12, 2012 | Poulan Pp1000e 7-inch Pro Lawn Edger...
How do I change the blade?
hold the blade and screw off the nut holding the blade on the motor shaft
May 28, 2011 | Yard Machines Red Edger
It's impossible to change a blade on a craftman edger. There is no way loosen the bolt holding the blade
Can you grip the blade and hold it still with say a pair of Vise Grips and remove the bolt that way? Lock the grips on the blade and then when it turns will it jam itself against the blade guard allowing removal. What type of bolt actually holds the blade on? Post back with more details.
Aug 16, 2010 | Craftsman Garden
Replacing belt on troybilt TBE515 edger . After replacing belt blade will not spin when engaged. If i remove the blade the shaft does rotate.
Use a 15/16 open end wrench an correct size allen wrench. Loosen nut (15/16) ccw while holding allen. Geez how dumb are yawl?!
Apr 24, 2010 | Troy Garden
We need a new blade for our craftsman edger
Go to www.searspartsdirect.com. Put your model number in of your edger.
It will show you a parts list , which will include your blade.
Hope that helps.
Good day.
Oct 23, 2009 | Craftsman Gas Mini - Tiller/Edger
Can't get the nut off.. is there a secret to blade removal
Hi these are usually the opposite way to which the blade turns but you may have to use a rattle gun to remove this. If you have a look at the thread you should be able to determine which way it comes off. Just remember to fix the blade so it wont turn and take your fingers off.
Aug 03, 2009 | Garden
Craftsman Gas Mini - Tiller/Edger Logo
461 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
