Question about Sharp 27H-S60 TV
How to change from air to cable sharp tv - Sharp 27H-S60 TV
My sharp tv wont change channels not even on tv buttons
I am going to assume you have auto-programmed the TV. If you haven't, do so and let it finish. Make sure you are in the right mode, e.g. Antenna for over the air and Cable for basic cable.
If you have a set top box or satellite, that box changes the channels, not the TV.
If auto-programmed it and it still won't change channels you have a bad tuner and you will need a new Main board to fix it.
Feb 15, 2015 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
How do I tune my Sharp tv to channel 3 so the cable will work?
Go to the Tuner setup screen and select cable instead of air. Then put the TV on Channel 3 and connect the cable box to the antenna connector on the TV.
Jul 04, 2014 | Sharp LC-26DV24U 26 in. LCD HDTV/DVD Combo
I have a sharp tv/vrc combo without a remote. I'm using a universal remote but wont let me get into the menu. I need to change it from cable to air. Can someone help?
For sharp TV-VCR Combo with universal remore control,
1/ Start by pressing SET & TV at the same time, the LED goes solid RED
2/ Press 009 or whatever code works for your TV.
3/ Confirm that you can now use your control to flip channels..
Then,
4/ Just press the blue button 2-/12. That allows you to change from cable to air and vis-versa. Hope that helps.
Ade
Jul 04, 2010 | Sharp 13VT-R100 13 in. TV/VCR Combo
TV shows no input service
You may have to change / adjust the settings on your tv to use cable vs over the air antenna. When power was lost, this setting may have defaulted back to factory (Air / Antenna).
If the cable tuner is damaged, you don't need to write off the tv just yet. Try connecting a VCR to the AV / Component Video jacks, and feed the cable through the VCR (use the vcr as the tuner). Take a few more steps, but you will still be able to use the tv.
Jun 23, 2010 | Sharp LC-32SB24U 32 in. LCD TV
Error Code E202, no picture, Sharp Aquos LC-45GD1E
Ur tv is not getting a broadcast signal,or ur tv cable or free air signal not getting from air antena,cables or dishes signals,or strong enough comming through.Get a better antena,like a digital antena,or a roof antena for better free air signal,cables or telicoms signals check ur boxes,push the power button OFF/ON to reboot it,to get signal back.
Apr 05, 2010 | Sharp Aquos LC-45GD4U 45 in. LCD HDTV
Can't turn off TV unless unlug the power.
Check ur cable or air tv signal.
Turn off and on agian ur your cable box ,if u have free over the air signal u must ajust ur in door or out door antena.Clean ur off/on on ur tv with a little DW40 on the rag clean the switch.Change ur batteries in ur remote,every year,solve most ur tv remote prob.
Aug 09, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Cannot get to the air/cable button it bypasses. I want to change from air to cable. I have both the manuel and remote.
Once you navigate to the Air/cable setting in the menu (menu - Set up - CH setting) press the Vol + button to access. make selection once again using the CH up or down key.
Feb 25, 2009 | Sharp 25L-M100 25" TV
Air analog 3 message keeps popping up what does that mean?
I bought the 32 inch LCD tv. I contacted Sharp. Here is there response.
Thank you for contacting Sharp Electronics Corporation.
The display will populate on screen any time there is a change to the incoming signal (mono to stereo audio, weak/fluctuating signal strength). Unfortunately there is no way to deactivate the on screen display. If you are able, try using an alternate connection (composite video and analog audio; yellow, red and white cables) from your source device (cable/sat box, if using) to the unit. This will prevent this issue from occurring by providing a more consistent signal. Let me know if you have any other questions!
Jan 02, 2009 | Sharp LC-42D43U 42 in. LCD HDTV
Not to switch from air setting to cable setting
Check the cable company website for an updated code list; they may have developed settings for your model.
Aug 24, 2008 | Sharp 27K-S300 27" TV
Cable/air
you will need to use your factory remote to do this function.
Oct 14, 2007 | Sharp 27H-S60 TV
Televison & Video Logo
16 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
