Question about Sony PlayStation 2 (PS2) Console
How to find bios version - Sony PlayStation 2 (PS2) Console
I can't go through bios setup. On setup utility main menu, only system date and time are highlited with blue color. I can't move the seletion arrows to highlight BIOS version.
Only items that can be modified by the user are highlighted. The BIOS version is just there for informational purposes. If you flash-update the BIOS, when you return to the page you would see the new version.
Jul 16, 2014 | HP Computers & Internet
Bios mod request
F-2 to enter BIOS
ACER has regular updates in BIOS, see acer.com support
May 28, 2014 | Acer Aspire 7741z
HOW TO UPGRADE INTEL 945GCLF MOTHER BOARD BIOS. BIOS VERSION IS "LF94510J.64T.0000.2009.0123.1105" & BIOS SOFTWARE VERSION IS AVAILABLE ON SITE IS " LF94510J.86A.0038.EB " WHEN I...
It seem your current version "LF94510J.64T.0000.2009.0123.1105" doesnt have any BIOS ID's which is required to upgrading. Where '0000' should have any version number.
I recommend using DOS environment when upgrading BIOS, this is the safe way flashing BIOS..so download file LF94510J.86A.0278.BI.ZIP here.
Extract all files on USB flash disk which is bootable flash disk. Run files executable on the command prompt and follow the instructions..
Aug 07, 2011 | Intel Computers & Internet
Just replaced a motherboard on my cx20 this runs my VMware datastores can't see physical or virtual disks where can I find the update to flash the bios
http://majorgeeks.com/BIOS_Finder_d237.html
Searches for newer BIOS for your board
Assists in flash upgrading your system BIOS to a later version. BIOS Finder determines your system BIOS and when run, cross references Flash upgrade BIOS files you have downloaded from the manufactures web site. If a later version match is found this BIOS is placed into a directory for you to upgrade to. Great for Y2K issues and beyond, overcome that greater than 8.4 Gig limitation with your BIOS, resolve those video card glitches. Download, run and your on your way to a later BIOS version! (Award only).
This older version will only work on motherboards with 128K bios files. Most boards these days are supplied with 256 or 512K firmware.
hope this helps
May 09, 2011 | Computers & Internet
I have a p5kpl-amse moth,board . the BIOS is faulty !! how do Iupdate it ?? I have to push reboot several times to get my computer to start.
hope this helps
Apr 21, 2011 | ASUS Computers & Internet
Need update bios
If you want to update you bios first of all you need to check that which is your current version of bios. For that you may do these steps.
  1. Open Start -> Programs -> Accessories -> System Tools -> System Information. Here you will find System Summary on the left and its contents on the right. Find the BIOS Version option and your BIOS flash version displayed.
  2. You can also scan the registry for this information. When Windows loads, it stores the main computer BIOS and video BIOS following information under the HKEY_LOCAL_MACHINE\HARDWAR\EDESCRIPTION\System registry subkey:
    SystemBiosDate
    SystemBiosVersion
    VideoBiosVersion
This information appears in the registry for only informational purposes and changing these values has no effect on the system.
After you got the same version of bios you can download the latest version from the specific vendor of you device and can update it by simply running as you install any software.
Apr 14, 2011 | Computers & Internet
How do I find which bios update to install - (find which motherboard) without opening the pc?
You just need to go to the BIOS page itself and look for the BIOS version. The version that you need relies on the BIOS chip and not on the Motherboard itself. As you know, Different motherboards may have the same BIOS. The BIOS version is usually located on the summary page either on top or at the bottom of the page.
Jun 12, 2010 | HP Compaq Motherboard
Notebook heating problem(urgent help)
You bios versions start at f.03,f.04,f.05, f.07, f.08,,,
The date and version that you posted does not match and bios version for your model.
The only reason you update a bios is if it falls under the problems
listed for the new bios to correct.
Say your lap came with f.05, the only reason you would update to f.07 is because you had a graphic error,that the new update fixed.
The link below is the page for your drivers, if you look at bios,it shows the newest,if you click on version,you will see all the ones
that where made.
You should double check to make sure that you have the right bios version.
http://h10025.www1.hp.com/ewfrf/wc/previousVersions?softwareitem=ob-61399-1&lc=en&dlc=en&cc=us&lang=en&os=2093&product=3646603
Apr 14, 2009 | HP Compaq Presario F750US
Version number?
Bios 7N is for the following
  1. Support up to 137GB HDD and above.
  2. HPT 370 RAID BIOS version 1.11.0402. The RAID function is for KT7-RAID / KT7A-RAID only. This BIOS version is also for non RAID boards and HPT BIOS will be automatically disabled while RAID controller chip not detected.
Version A9 is the last update
  1. Fix nVidia GeForce4 Ti 4x00 AGP card compatible issue with Windows XP.
  2. HPT 37x BIOS version 1.11.0402.The RAID function is for KT7A-RAID only. This BIOS version is also for non-RAID boards and HPT BIOS will be automatically disabled while RAID controller chip not detected.
  3. BIOS Compile Date: 7/11/2002.
LINK
The above link is for the KT7a with Raid, however the standard KT7a also lists the same bios updates, the KT7a Raid ver1 lists different bios that won't be compatible with your board.
Apr 12, 2008 | Abit KT7A Motherboard
Bios
actually u know what beta means? its acutally in testing mode they r still testing n finding the errors they made so when they find all erors n fix then they launch a full version of it so never download a softwares update of such sensitive stuff which r beta version always wait for the full version to arive
Nov 09, 2007 | ASUS P4S800 Motherboard
Sony PlayStation 2 (PS2) Console Logo
135 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
