Question about AOC LM742 17" LCD Monitor
I will like my computer screen darken
How 2 darken my computer screen
    Renaissance:
    An user who is expert in 3 categories / brands.
  • AOC Master
  • 848 Answers
I will like my computer screen darken? This trouble maybe power supply or inverter boards is defective.
first you can test the voltage of the multr,and then check which part is defective.From Wisiny.com can find those parts
if you have any question,please let us know email:service@wisiny.com.thanks,we sincerely hope we can help you!
you can also check this boards whether suit you:
2202130701P AOC 6201 7978301421 Power Supply Backlight Inverter
Posted on Feb 27, 2015
  • 106 Answers
Check the setting from there you can or from your keyboard you can also
Posted on Jan 02, 2014
Screen drakens after I clik and allow a program to run, why?
The screen darkening feature is a common setting in windows when a program is asking to change (install) on your hard drive.
If you are responding yes, but the installation is not occurring or is stalling, you may:
1) need to wait longer (especially if your PC is underpowered as compared to the demands of the new program you are installing),
2) need to check the setting on your security/malware program to assure that it is not in conflict with (and blocking) the installation, or
3) learn that the program you are attemping to instal may require a) a different version of your operating system, or b) more resources than your computer has available, in which case additional memory, hard-drive space or processing power may be required.
Jan 26, 2015 | Compaq Presario SR5707C - 24408
The screen occasionally darkens significantly,
Have you tried using a different VGA cable? Or replacing the cable with a new one?
Dec 07, 2012 | ViewSonic Va2431wm LCD Monitor
LOOKING FOR A REPLACEMENT SCREEN
Darken the screen and either move the lid forward or backwards. Laptops have Liquid Crystal Screens and moving the lid backwards or forward will give the screen a different look.
If you need to adjust the brightness of the screen it is controlled by keys on your laptop. Most times to darken the screen you will have to hit the FN, CTRL or ALT key and hold it down while you hit the key that corresponds to the screen darken key. On some computers (even on my laptop) it will be the down arrow key, so i would press FN+the down arrow key. Remember to hold the first key down while you hit the next key. The icon used for most times to denote the brightness or darkness looks like a circular sun or a washer that goes on screws.
Mar 22, 2012 | Computers & Internet
How do I darken my computer on the Dell Inspiron 1525
Hold the "FUNCTION" key down and tap the LEFT ARROW key to darken, tap RIGHT ARROW key to lighten the screen.
Good Luck
Jan 06, 2011 | Dell Inspiron 1525 Laptop Computer PC...
My LG monitor blacks out intermittently when warm, I have tried it on another computer so it is a fault with the monitor. It blacks out every few seconds, sometimes it takes longer. It is 2 years old.
after blackout, check the screen as that. look in to the monitor in side angel,
and if you can see darken live image in that and its working. in that condition, your
LCD panel is working and the problem is no light.
in that case you need to repleace or repair the " inverter unit " in that monitor.
that unit makes the high voltage for back light.
after blackout , you cant see any darken image like as that, and or totally power
goes off , that is different problem. for solve that need advance trouble shooting
and can be need advance repair.
Jan 03, 2011 | LG Flatron W2243SPF Widescreen LCD Monitor
What would cause the calculator not to turn on. I
The batteries may be inserted incorrectly Should be +-+-.
The most common is that the screen is not dark enough: The calculator is on, but the user cannot see anything. The first things someone should verify are the two above.
If one wants to darken the screen one should proceed as follows.
Press the ON button (even if you cannot see the result)
1. Press [2nd] key and release it.
2. Press the [UPArrow] key , the one under [GRAPH], and release it.
3. Repeat Steps 1 and 2 in sequence until the screen darkens. One may have to repeat Step1, Step2, ...several times.
Oct 07, 2009 | Texas Instruments TI-83 Plus Calculator
When i try to graph something on my TI-83 Plus, the screen fades to pitch black and then it says INVALID DIM
Reset the RAM to clear old settings that interfer with your new problem
[2nd][MEM][7:Reset][1:All Ram][2:Reset][ENTER].
Press [CLEAR] to clear the screen.
After a memory reset you may have to adjust screen contrast.
To increase contrast (darken the screen)
2. Press [UpArrow] key and release it.
3. Repeat sequence until screen darkens enough.
To lighten the screen
2. Press [DownArrow] key and release it.
3. Repeat sequence until screen lightens enough.
Hope it helps.
The screen is to bright and wont darken enough
It is likely the video card on the actual unit. If it is under warranty they will likely have you ship it back to them for either 1) repair or 2)replacement
Edwards-Walnut
381 Brea Canyon Road
Walnut, CA 91789
Apr 05, 2009 | ViewSonic VA903B Monitor
Screen darkening from right side
1 lool
change lcd panel ok
Jan 19, 2008 | Lenovo ThinkPad R51
AOC LM742 17" LCD Monitor Logo
91 people viewed this question
Top AOC Computers & Internet Experts
Jerry Umali
Raj Patel
Are you an AOC Computer and Internet Expert? Answer questions, earn points and help others
