The pipes in my house vibrate whenever we run the water, hot or cold
SOURCE: noisy pipes with hot water baseboard heat
The natural expansion and contraction of the pipes due to the hot and cold water is what makes the pipes sing. I'm not aware of a fix without repiping.
SOURCE: When hot water is turned on the pipes make this
There is a loose washer in the faucet...this flaps as the water goes through it and makes the vibration...
You either need to replace the faucet or the cartridge (washer) in the faucet that valves the water...
This will stop that vibration and hammering sound
heatman101
SOURCE: mains cold water pipe to kitchen tap is vibrating
You probably have a loose washer in the faucet itself or a loose bib washer at the shutoff valve under your cabinet
