Question about Symbol PDT 3110 Portable Terminal
What is the key sequence to reboot a Symbol PDT3110?
It froze and all the screen is showing is the usb symbol and 1 out of 4 bars of battery plus i have the go pro where its water proof and you cant take the battery out of back off
there is usually a soft reset sequence for phones that you cant take the battery out of, gogle it or ask your provider how to do it, it pays to power off smart phones at least once a week to clear & reboot them.
Jul 11, 2015 | Symbol Cell Phones
HOW TO REBOOT
Click on the windows symbol, normall on the bottom left, then click on SHUT DOWN or RESTART symbol on that menu that just popped up. It is normally on the bottom right of that menu.
Mar 31, 2013 | ASUS Computers & Internet
Cisco 7945G keeps rebooting after factory reset
If you used the traditional keypress sequence where you hold down the * key, reboot the phone, and then press the keys in sequence, you may be stuck in a boot loop. You might need to connect your phone to a network if your phone is trying to reach a TFTP server to fetch a firmware or config file update. If you need a power supply, you might try CiscoPowerCube.com they sell a cross compatible version of the CP-PWR-CUBE3 which includes the cord.
Aug 28, 2012 | Cisco 7945G IP Phone
I have acer aspire 3000+ and cant change bios setup to boot first from cd rom and erecovery doesnt work
Why can't you change the bios setup to change the boot order or boot sequence?
Also you can change the boot order or boot sequence temporarily by just rebooting the laptop then watch the screen for which key it says to hit to change the boot sequence or boot order, then hit that key when you see the message.
May 08, 2012 | Computers & Internet
Greater than symbol? in keyboard?
Dell QWERTY keyboards greater-than symol is produced by the key sequence
SHIFT-. (shift period), like any other QWERTY keyboard. Your greater-than symbol probably wore off.
The Less-than symbol is produced by SHIFT-, (shift comma).
Aug 03, 2011 | Dell 0Y3740 Keyboard
How do I get from degrees to radians? For some reason my TI-84 will not convert degrees to radians.
Press the [MODE] key to access the mode comfiguration screen .
Set angle unit to to radian (see above)
Enter angle value in Decimal degrees only, use the [2nd][ANGLE] key sequence to have access to the degree symbol. The degree symbol must imperatively appear at the end of the angle value.
Here are some examples
If you use angle values in DMS, it will not be converted to radians, but to decimal degrees.
If you omit the degree symbol there is no conversion.
A general formula is Pi radians =180 degrees
Feb 10, 2010 | Texas Instruments TI-84 Plus Calculator
How to do nPr or nCr on TI-30x Solar (scientific calc.)
If you have an older version on the TI30x Solar (not TI30Xa or newer) then you must use a different key sequence for nPr/nCr.
52 [2nd][x/y] 5 [2nd][nCr] gives 2598960 (the x/y button is above the Pi symbol on my version).
8 [2nd][x/y] 3 [2nd][nPr] gives 336
This took me forever to find out, so hopefully it will help someone!
Jan 27, 2010 | Texas Instruments TI-84 Plus Silver...
Oven failer
You have reset the timer from the auto function, to the manual function.
You should see a hand symbol showing for manual operation.
It is a question of pressing the buttons in the correct sequence., or if it is a anologue timer, turning the knob until you see the hand symbol showing.
Hope this helps.
Dec 24, 2009 | Zanussi ZBF360X Electric Single Oven
Lenovo N500 lap top - mouse is inactive. Need
Some laptops have a key sequence to activate or disable the onboard touchpad.
Look for Fn+F8(or another combination) the key should have a mouse symbol on it.
May 11, 2009 | Computers & Internet
Symbol PDT 3110 Portable Terminal Logo
62 people viewed this question
Top Symbol Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Greg Cann
Greg Cann
pkwc
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
