Question about Bushnell Tour V2 Pinseeker Laser Rangefinder
Battery only last for 2 - 3 rounds of golf
I have put in several new batteries and the only last about 2 - 3 rounds of golf when I first bought the product the batteries lasted much longer. Seems as if the batteries are constantly being drained??
3 Suggested Answers
  • 115 Answers
SOURCE: The battery life last for only a few photos, what's up?
try not using the flip up screen on this it will extend the battery life.
Posted on Feb 04, 2009
  • 38 Answers
SOURCE: My bushnell 119426 trail cam took 2200 pics in 24 hours of which 540 were listed as invalid image. What is wrong? The New batteries Energizer Lithium were 2 months old and were down to .7 volts.
check the hdd, flash memory or sd card, or the system that it uses to record the photo
Posted on Dec 16, 2014
Testimonial: "The SD card works fine in one of the other Trail Cams. It was an 8gb card and not full. Put in new batteries and it seems to work fine. Not sure why the batteries failed so quickly. The lithium have lasted over 2 yrs in the other 2 trail cams."
Need help putting new batteries in 1980 club car can't figure out how to connect wiring to new batteries
https://www.golfcarcatalog.com/golf-cart-blog/golf-cart-battery-bank-wiring-in-series/
This should solve your problem.
Next time you want to take something apart, be sure to take a picture or 2, before you disconnect anything. That will help you put it back like it was.
Jun 16, 2017 | Cars & Trucks
I have a golf buddy that lose it charge after about 11 holes can I replace the batteries?
I also had the same problem of the battery not lasting a whole round. I found out that if the unit was left for any length of time after it had been fully charged, it would start to discharge even though it was turned off. I now make sure that if I'm playing golf the next day I will put it back on charge overnight.
this has worked successfully for the last 5 months approx
i also looked to find a replacement battery but without success
hope this helps
Feb 22, 2015 | GolfBuddy Golf Buddy VOICE GPS
Intermitantly working v2 rangefinder
Had the same problem with my first Bushnell V2 (Slope). Worked intermittently and sometimes just quit altogether. Finally had to send it back to them. They sent it back and said nothing was wrong with it. I called them and told them they were wrong and I was sending it back and they should take more time in testing it. This time they acknowledged problem, said it was fixed and sent it back to me. I wound up getting a real good deal on the V2 without the slope calculator (necessary if you want to use it in championships). Used this one for some time with no problem, but now it just went dead again. Battery tests well into green area on meter, but I'm going to try a brand new one and see what happens. From all the things I've read about the V2 and battery life, it looks like you might need pretty fresh batteries to keep it going.
Jul 22, 2012 | Bushnell Tour V2 Pinseeker Laser...
Where can I buy a battery for the DX-902 Lil Driver golf cart? My golf cart doesn't work, so the first thing I think might be wrong is that the battery doesn't work. The golf cart sat in our...
Dear kimbroberg2
My husband and I did the exact same thing for our grandson when he was 8 months old. We pulled the car out of the attic last night and the battery did not work. My husband called the manufacturer customer service at 714-256-9888. He was told that the batter was too old and would have to purchase a new one. My husband called around for the item description that they suggested and found a comparable battery at Interstate Battery in our hometown. Good luck. I know we were very disappointed when this happened, but there is hope. Hope this helps.
Jun 28, 2011 | Dexton Kid Racer Battery Operated Ride On...
This scooter has not been used for 18 months,it has 2 gel batteries and showed a full charge after o'night charge(greeen light) showing. How many kilometres should i get from it ?.it is a victory...
hi.
with good batteries, and under ideal conditions (flat smooth surface) this scooter should be good for up to 30 km.
this is highly dependant on the surface, slopes, rider weight, and battery condition, but with good batteries you should easily be able to do a round of golf.
the biggest problem you may have will be the batteries themselves.
after 18 months without use, the batteries may have suffered from a sulphur build up on the lead plates in the battery. this can mean that the batteries will show fully charged, but will not put out the full power. the best way to test this is to take the batteries down to your local car garage and ask them to do a "load test" sometimes called a "drop test" on the batteries. they will usually do this free of charge and it only takes a few minutes. a 100amp load test for 8 seconds should tell you the condition of the batteries.
if the batteries test ok, then you should not have any problems using the scooter for a round of golf.
hope this helps
Jun 21, 2011 | Pride Mobility Victory 3 Wheel Electric...
My vw golf has to be jumped to start
you might need a new battery. most places do free battery checks. and for inexpensive batteries that last, i reccomend walmart.
Dec 17, 2010 | 1993 Volkswagen Golf
1997 vw golf 2.0 5speed start
Check body to motor ground wire and battery to motor and body ground.
Jul 23, 2010 | 1997 Volkswagen Golf
I have bought a new DS lite and charge it up but
sue it could be the way the battery responds to our power usa puts out 30 v more through the wall then the west
you could buy a american battery its possible that there batteries dont last as long
see if it works
Oct 19, 2009 | Nintendo DS Lite Console
VW polo alternator light stays on
Yes, by connecting the charger the wrong way round you have damaged the rectifier in the alternator, now needs a replacement
Aug 28, 2008 | 1999 Volkswagen Golf
Battery problem
Remove batteries and clean contacts of battery's host (include cover). Check as well that contacts are not bended and didn't lost their springiness. Good luck!
Aug 04, 2007 | Canon PowerShot A560 Digital Camera
Bushnell Tour V2 Pinseeker Laser Rangefinder Logo
43 people viewed this question
Top Bushnell Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Greg Cann
Greg Cann
Mark Campeau
Level 1 Expert
Are you a Bushnell Optic Expert? Answer questions, earn points and help others
