SOURCE: Dyson all floor vaccum no suction when hand held
You need to replace the belt that drives the brush on the underneath side of the vacuum. To do this, you need to flip the vacuum over and remove cover plate. There you will find the broken, or stretched out belt. Remove the brush and place the new belt on the chrome axle. Then put the brush on, rapping the new belt around the brush as you put the brush back in place.
Jim
SOURCE: no suction on dyson dc24 ball
Well i just fixed my Dyson Ball with the same problem you have. My wife and i found out it was a crumpled receipt in the lower section of the hose at the upright/handheld pivot #3 in diagram and it was catching cat hair and other things. I began by removing the canister and turned on the vacuum to see if the direct access to the fan had suction. Then i moved to #5; i reattached the canister and threw in some cat hair into it from the bottom. i turned on the vaccum to see if it spinned around; it didnt. I then moved to #4, i removed the head and then turned on the vaccum to see if maybe the head had a leak at the top connecter; as i predicted the strength was minimal. I then worked my way to #1 to see if the strength was the same or if there was a difference. no difference for us. Well then it must be #3.. of course the last one i checked. I used a small flashlight and peared in and i didnt see anything... i then used a coathanger very softly as to not puncture the hose. i then noticed some hair being pushed out but the main culprit wasnt showing. my wife gave me needle nose pliers and i pried the hose off of the top connection in #3; so i could get a better look; you may be able to push it off with your hands. and viola! a crumpled reciept for 3 Monster energy drinks.... the same ones....i drink... oops!... hopes this helps. just go through it step by step. youll know its working once stuff begins to spin in the canister. almost regretted throwing that dyson registry junk away.
SOURCE: no suction in the hose on dyson dc24
Hi its Darran at Dyson.
It sounds as though the hose is blocked. I would recommend following the blockage procedure. If this does not resolve the problem, please call our Helpline on 0800 298 0298, between the hours of 7am - 10pm, 7 days a week.
Kind regards
Darran
Dyson Customer Service
