Question about Craftsman 20 hp 42 in. Deck Yard Tractor
Find whe the oil filter is located
I need to know how to replace the oil filter in my lawn mower trctor model 1000 T
  • Mike McDowell May 11, 2010
    Hello:
    Are you looking for the filter? Or is your question more about how to replace the oil filter?
    Scholar:
  • 138 Answers
Verry carefully. seriously, though, on a briggs engine, it will be on the left side of the engine at the bottom rear - on a kohler it could be in the same position or the left side top rear - on a kawasaki it could be either - get an oil filter wrench and unscrew the filter counterclockwise [if the filter is horizontal, slip some rags under it, there will be a mess], make sure the rubber seal on the old filter does not stick to the engine, if it does, peel it off, put a light coat of oil on the rubber seal of the new filter and screw it on clockwise, tighten about 3/4 turn after contact with the base
Posted on Aug 18, 2009
What type of oil filter do I need for a lawn tractor 24H.P. 46" mower Model #28857
Any good 30 SAE weight is recommended for grass mowers..if used with a snow blower use a good multi viscosity 10-30 or 5-30 ould be fine..good luck..
Jun 27, 2015 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
How do you fill the hydraulic fluid for the craftsman kohler magnum 19.5 lawn trctor
its hydrostatic fluid not hydalic fuid dont put hydralic fluid in it the fill is on the back of tractor on the transmission there is a dip stick do not overfill or you will blow seals
Dec 15, 2014 | Craftsman Garden
Need to know where to find fill plug and drain for john deere lawn trctor lx172.
you can go to home dopot or look in the phone book for a parts place
Aug 17, 2011 | Garden
I don't have an owners manual. I need a new oil filter for Craftsman LT 1000
You need the model number off the engine. With the model number and the brand you can go to the local lawn mower repair parts shop and get the filter for that engine. But if you would like to send me the complete model number and the brand of your engine I will look it up for you to get you the part number so you know what to look for when you go to get it.
Aug 12, 2011 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Changing oil in my mtd lawn tractor!! Was oil should I use? Where is the filter? How do I change it?
Most Mower engines have an oil drain plug located at the base of the oil fill tube or dip stick tube, Most mower engines use a standard 30wt engine oil, however, to stay within the parameters of your warranty, use the manufacturers reccommended oil, this info can be located in your owners manuel.
Apr 14, 2010 | Mtd LAWN MOWER PART # 791-180705 Assembly,...
Lawn Tractor 1000, oil chg
there is no filter. but when you drain the oil. start by adding a 1/4 quart and check the level. if still low keep adding (little at a time) until it reaches the full mark on dipstick...good luck
Apr 03, 2010 | Garden
Hydraulic lift pump not lifting how to replace pump on a L245 kubota trctor
I have a Ford 1700 and the first time this happened I assumed it needed the oil changed (DID NOT read the manual). After changing the hydraulic oil for about $50... it ran no better. Read the manual. Bought the hidden oil filter. Bought new oil. Problem solved. The filter on this tractor sits in the bottom of the rear end housing and collect ever piece of junk. Good! But a pain to change the filter.
Nov 12, 2009 | Garden
Where are the air and oil filters located
I don't think you have an oil filter on your push mower. You can go to www.buymtdonline.com and look under illustrated parts look up then enter your model number of your LAWN MOWER not your motor and it will give you a parts listing for mower and look under the sub categories for the engine and it will show you where the air filter is located and oil filter (IF ONE). Look at the little number by the air filter then scroll down to that number below the diagram and you will get the part number for the filter.
Hope this helps
roundo4
Aug 03, 2009 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Craftsman 20 hp 42 in. Deck Yard Tractor Logo
108 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
