Question about Canon ES Video Cameras
Canon e57a camcorder - ES Canon Video Cameras
Can I hook up to the DW 100 Canon burner with my ZR200 to burn mini tapes on DVD?
No. The Canon USA web site says the Canon DW-100 has a USB terminal and works with "USB 2.0 Hi-Speed (with compatible Canon camcorders only)." In other words, the Canon DW-100 burner works only with Canon's USB 2.0 camcorders. I have a Canon ZR200. The ZR200 has Firewire 400 digital video output, not USB 2.0 output. The USB port on the ZR200 is ONLY for still images. Video will not and cannot be output through the USB port on the ZR200. (Page 121 in the ZR200 manual mentions using the USB port on your camcorder for transferring still JPEG images to your computer.) You need a DVD burner with "DV Input" (also called Firewire 400 or IEEE 1394) to hook up your camcorder to burn Mini-DV tapes onto DVD. The Sony VRDMC10 Stand Alone DVD Recorder/Player has DV Input. The ZR200 camcorder did not come with a Firewire cable, but you can buy one at any electronics store or at a cheaper price online. Make sure that you get the right kind of Firewire cable, 4-pin to 4-pin or 4-pin to 6-pin, whatever the DVD burner you choose requires. (Your ZR200 has a 4-pin DV port on the camera's end.) USB 2.0 Hi-Speed (with compatible Canon camcorders only)
Mar 15, 2011 | Canon ZR200 Mini DV Digital Camcorder
Tip
Canon GL2 Manual Download
Download Canon GL2 Camcorder Manual
Have you misplaced your Canon GL2 Camcorder Manual?
Would you like a digital, searchable, pdf version of the Canon GL2 Camcorder Guide?
Follow this link (& click FREE) to download a pdf version of the Canon GL2 Camcorder documentation.
I hope that helps.
__________________________________
on May 08, 2010 | Video Cameras
Tip
I hope that helps.
on May 08, 2010 | Canon GL2 Mini DV Digital Camcorder
How do I get a canon gl2 to work in skype?
Connect your Canon camcorder to your computer using the firewire cable.
Allow your computer to recognize the device and automatically set the appropriate configurations. If your operating system does not automatically install the drivers for the camcorder, then you must install them manually, using the CD that came with your camcorder.
Open Skype and navigate to the "Preferences" menu under "File" or "Skype" -- depending on which operating system your computer uses.
Select "Video" from the preferences menu and click on the drop-down menu next to "Camera."
5
Select your Canon camcorder device name from the list of available options in the "Camera" drop-down menu.
6
Close the preferences menu to save the new camera settings and begin using your Canon camcorder as the video source.
Feb 04, 2011 | Canon GL2 Mini DV Digital Camcorder
Canon camcorder zr60 manual
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=326&modelid=8621
Aug 16, 2009 | Canon ZR60 Mini DV Digital Camcorder
Ask the replacement for Canon Elura 50 camcorder
ur camcorder all related software/drivers/manuals
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=326&modelid=9037
Technical Support Call
+18008284040
pls rate me Fixya for help or u can ask more if u like
Mar 21, 2009 | Canon Video Cameras
CANON DC210 CAMCORDER DRIVER CD LOST
I HAVE LOST MY INSTALLATION DISK FOR MY CANON DVD CAMCORDER DC210...CAN U HELP ME IN FINDING AND INSTALLING THE SOFTWARE FOR THIS CAMCORDER SO THAT I CAN SEE MY RECORDINGS ON MY COMPUTER
May 04, 2008 | Canon DC210 DVD Camcorder
Video Cameras Logo
32 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
