Question about GE Refrigerators
Ge smart water heater
Can I get age by serial no? mine is model no. PG40T9XA serial no. GELN 0101164067
  • 2692 Answers
SOURCE: dripping from drain spout
If you are refering to the "Dripping coming from the preasure tempature valve,Then just turn off the valve where the water goes into the heater and open the P/T valve with a bucket below it draining only emought water to get below the level where it reaches.     Normally the drain valves are plastic with a Male hosebib attached.  Attach a  garden hose to the rain and run it out to a point lower that the vaslve in order for gravity to drain the tank.The valve opens counter clock wise. If the valve is stuck or does not drain,and you have a foor drain handy,remove the whole valve and replace it with a boiler drain valve.  If The tank is located below the drain level then you will have to either pump or carry the drain water to the higher level.     Replace the P/T valve  and reinstall the associated associated piping. I would use tefelon tape on the P/T pipe theads.    You may have to open a hot water faucet in order for the air to replace the water in the tank ,in order to drain.
Posted on Jan 31, 2009
Sea Breeze
  • 4655 Answers
SOURCE: My GE fridge makes Ice but can't get any water?
He is saying the heater in the ice tray located on the bottom that helps loosen the ice before it is dispensed to the ice pan.
A new ice maker for your fridge can be purchase for less and you can install it yourself. Below is my site link, just put your model number in the search feature or the part number WR30X10093 of the ice maker. We also offer free help and assistance, Thanks, Sea Breeze
http://servicepartstec.blogspot.com/
Posted on Mar 28, 2009
woodchuck789
  • 4070 Answers
SOURCE: GE side by side; model # TFX25JRYD Serial #
So the dispenser is getting water. Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
If the valves clicks but water doesn't get to ice maker the fill tube can be stopped up with ice.The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn’t take much to eventually block the fill tube.
Posted on Jul 12, 2009
aasc
  • 1606 Answers
SOURCE: I have a water softner in my house do I need the
If your using the correct bypass plug which came with the refrigerator , the water dispensor should still work . Make sure the plug is very snuggly , tight in place .
Posted on Aug 26, 2009
co7196
  • 3433 Answers
SOURCE: GE Smart Water Heater - Model #GE40M06AAG - 40
There should be a faucet on the side . you hook up a garden hose and drain it.
Posted on Nov 18, 2009
Ge smart water heater model SE80T1ZTAH
Try this:
1. Turn off the power to the water heater.
2. Press the reset button.
3. Replace the insulation and jacket access panel(s) before turning on the power to the water heater.
Please let us know if this works!
Nov 04, 2013 | Water Heaters
Date of manufacture 81v400, serial r1194849014
1) Rheem 81V40 electric water heater ... manufactured pre 2009 ... posted serial number does not match manufacturer
http://waterheatertimer.org/pdf/Find-Age-of-water-heater.pdf
http://waterheatertimer.org/pdf/Rheem-Ruud-2009-water-heater-parts-by-model-number.pdf page 5
2) Possible date of manufacture 11-1994
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Mar 05, 2013 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Troubleshooting whirlpool ee2h50rd045v water heater
1) Copy following links for whirlpool energy smart resources:
http://waterheatertimer.org/pdf/Energy-Smart-troubleshooting-guide.pdf
http://waterheatertimer.org/Whirlpool-Energy-Smart-electric.html
2) Control box is probably bad.
There are 2 types of control boxes for older-style energy smart water heaters.
You will need model number and serial number from label on side of tank to order from Whirlpool.
3) This older-type energy smart water heater is probably discontinued by AO-Smith, American, State, Craftmaster, Reliance water heater group that makes Whirlpool and Kenmore water heaters.
New generation energy smart offers interface with home automation and/or non-existent smart grid.
Older energy smart only offered potential interface with non-existent smart grid.
Dec 23, 2012 | Whirlpool Water Heaters
I purchased a hot water heater about two years ago from home depot and lost the reciept. I need to track the purchase by the serial number can that be done
1) Look for brand name of your heater on following .pdf file:
2) Home Depot sells GE heaters made by Rheem.
I am assuming that serial number starts with 1209, and that year of manufacture is 09 for 2009.
3) These water heaters have glass vial that breaks when combustion chamber experiences overheating due to dirty combustion parts, clogged air intake, exposure to flammable vapor.
http://waterheatertimer.org/How-to-repair-Rheem-TRD.html
4) Water heater warranties are usually first-year: full parts, labor and tank. After first year: parts and tank but no labor.
Warranty may be pro-rated and the value diminishes as water heater ages.
http://waterheatertimer.org/How-to-maintain-water-heater.html
5) Warranty may not apply is customer has not followed installation and maintenance as shown in product manual, such as checking anode rod, and yearly service by trained technician.
Dec 06, 2012 | Water Heaters
What is the age of my water heater?
2010? American
1982? Rheem
Depends on brand of water heater
http://waterheatertimer.org/pdf/WaterHeaterSerialNumberDecoder.pdf
Oct 01, 2012 | Water Heaters
My water heater error code 1 model ee3250rd055v what does this mean
Water heater is not 100% identified.
Unknown if this is gas or electric heater.
Problem posted under Whirlpool water heaters typically made by American water heater company.
Call Whirlpool 877-817-6750.
They will ask for model number and serial number located on label on side of tank.
Call is answered in USA by trained person who can answer specifics about that model, including warranty, age, regular maintenance, error codes, and possible solution for that specific model and serial number.
I have found these folks to be helpful.
Whirlpool manuals do not show that specific model:
http://www.whirlpoolwaterheaters.com/support/manuals.aspx
If you have the energy smart electric water heater with electronic control board, then error code explanation shows on the control board. Error 1 or a single flash, is start-up failure and requires tank to be full of water. Read page 10 of manual. Make sure water heater is full of water and water is coming full stream out of tub spout before turning on power. Also disconnect power from unit, make sure water heater is full, and then reconnect power to see if unit resets.
http://www.whirlpoolwaterheaters.com/downloads/6510306.pdf
Sep 12, 2011 | Whirlpool Water Heaters
I have a 40 galon GE Smart shield water heater, Model: SH40T12AVH00, Serial # GELN0805V13908. The pilot light is lit but the burner will not stay on for more than 2 secods and then shuts-off.
I believe this unit does not have a standing pilot light and lights each time? Have you reinstalled all doors back into the heater? It sounds like the main burner is blowing the pilot off the thermocouple. You might try replacing the thermocouple. You can download a manual here: http://products.geappliances.com/ApplProducts/Dispatcher?REQUEST=SpecPage&Sku=SG40T12AVH00
Aug 02, 2010 | General Electric GE SmartWater Household...
Refrigerators Logo
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
