Question about Electrolux Central Vacuum
Burning smell Electrolux hoover won't stay on and burning smell if you keep you r foot on the on pedal. Belt was broken and have replaced it but no change. Checked for blockages and cleaned the filter. Suggestions please
  • Electrolux Master
  • 1,284 Answers
Something may be keeping the brush roll from spinning freely which may have caused the belt to break.
Posted on Jan 29, 2014
LizDahl
  • 75 Answers
SOURCE: Electrolux Bagless Canister Vacuum w/Self-CleanHEPA Filter - weak suction
Unfortunately alot of people buy this model because of the electrolux name, but it is actually made by eureeka. Aerus-Electrolux is the manufacturer of the high quality machines of our parents day.
Posted on Jan 28, 2008
  • 55 Answers
SOURCE: Electrolux Hi-light
Burnt smell is probably the belt slipping. Even though it looks OK, either the belt needs replacement and/or the roller needs cleaning and/or lubrication at the ends. Try cleaning the roller ends first and then light lubrication with WD40. If belt works, you are done. If not, replace belt.
Posted on Feb 19, 2008
chris321918
  • 32 Answers
SOURCE: NO SUCTION
If you have no suction, there are only a couple of things that could cause it. As you have checked for blockage, and changed your filters, you may have a vacuum motor with bad bearings, or broken fan blades (inside/on the vacuum motor). Either symptom points towards a vacuum motor being bad and needing replaced.
Posted on Jan 21, 2009
  • 694 Answers
SOURCE: my powerhead drive belt to
Turn the PN bottom up. With a Phillips screwdriver, remove the six screws in the base. Turn PN over and lift back of cover, then gently manipulate it until it comes off.
Slide the belt off motor shaft, if necessary. Remove the screws on each end of the brush and lift the end of the brush so you can remove the belt, if necessary. Place new belt on brush and place brush into slot. Replace screws and tighten. Pull belt back to motor shaft and slip on. Check belt for tautness. There should be a little play, but not much. Make sure belt is placed correctly and rotate brush a few turns.
I recommend cleaning the inside of the PN while you have it apart. Use the dust brush to vacuum as much as possible out.
Make sure the light cover is in the correct position. Carefully place front lip of PN cover into slot in front.of the PN. Carefully settle cover in place. Check around the PN to ensure cover and base are correctly placed. Turn PN over and replace screws, short one in front.
I do recommend letting a trained Aerus Electrolux tech do this, especially since the belt will have a one year warranty if he/she does it. Of course the belt should last longer than that, anyway.
Posted on Mar 09, 2011
chesterpendi
  • 195 Answers
SOURCE: Electrolux EL7020 SHUTS OFF Constantly!
That problem have 2 causes..#1 is loose electrical connection inside or on the power cord..#2 is worn out carbon brush inside of vacuum motor..
Carbon brush is the one of the most serviceable parts of a vacuum cleaner because our vacuum cleaner motor is very hard working parts so the brush inside will possible worn or not connected to the armature of rotor...
Posted on Jan 12, 2012
Hoover model 70930 vacuum. System check indicator stays red.
If the smoking at the base smells like burned rubber it's probably your belt. If it smells electrical it's probably your motor or an electrical problem.
Mar 08, 2017 | Hoover Vacuums
Making a burning smell...not working as it should
remove the brush roll clean the brush end bushings and replace with a new belt
Sep 29, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Burning smell
the belt needs changed. its slipping. make sure its not clogged with carpet or string ect. first. if not buy a belt at walmart. in stock...
Sep 08, 2009 | Hoover Tempo Widepath Upright Vacuum -...
Burning smell coming from vacuum
use a penny to turn the 2 screws on top a quater turn then fold down the vacuum and lift up the cover and you will have access to the belt. Clean the small hepa filter with soapy water. their may be 2 of them. The cannnister filters need to be shaken but not washed. Good luck.
Apr 09, 2009 | Hoover U5753-900 WindTunnel Bagless...
Vacuum smells like burning rubber when on, no suction, leaving black marks on carpet
Usually when my vacuum smells like burning rubber, the belt needs to be changed and that is very easy to do. You just need to remove the the screws that hold in the rotator and put in a new belt. When the belt needs to be changed the vacuum will not pick up anything and this could make it seem like there is no suction. I hope this helps!
Nov 25, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover mach 4 burning smell
There are two reason you could be smelling a burning smell-
1. The belt is too stretched out and needs to be replaced. This causes it to slip when the vacuum is on and will create that type smell. You can avoid stretching and having to replace the belt to often by releasing the belt after each vacuum.
2. There may be hair or other debris stuck around the rod that the belt is attached to. Can be avoided by checking after vacuuming.
Hope this helps
Nov 12, 2008 | Hoover Vacuums
Self propel not working, burning smell
Flip the vacuum cleaner over and check the roller brush. Is it full of string and hair? If so, unscrew the four phillips-head screws holding the plate on that covers the roller brush; pull out the brush, and cut off/clean off all the hair and string. Replace everything and try running the vacuum. Alternate solution: perhaps the belt that makes the brush go around is broken. If so, follow the above steps to remove the roller brush, then replace the belt.
Oct 11, 2008 | Hoover Ultra U6430-900 WindTunnel Bagged...
Drive went out on my Hoover Steam Vac Shampooer and brushes won't turn plus there's a burning smell coming from it. Only used it 6 times - bought it in March - 2008.
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=761326
Generic problem for all Vacuums
Posted by buster_lls on Jul 09, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. It sounds to me like you have multiple problems with your power drive; a burning smell and the brushes don’t turn, and the dop is on March, 2008 – the Hoover Steam Vac Shampooer has a one year factory warranty and it could be a broken part for the brushes won’t turn or a belt would cause the burning smell. If it is not the belt or broken part it probably is the motor of which you should take it to a authorized Hoover vacuum cleaner dealer in your area or to contact the Hoover factory cust serv listed below or the Hoover website for information. If it is the motor the factory authorized dealer will replace the part for the motor and the broken part for the brushes, if it is the belt that would be an out of pocket expense. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 09, 2008 | Vacuums
Rubber smell, Hoover
Well it sound like you do need a new belt because of how the smell is you might want to stop using it because the smell comes from the burning and over heated belt my solution would be to get a new belt and that should fix it if you need anything else you know whre to find me.
Jun 30, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Electrolux Hi-light
Feb 15, 2008 | Electrolux Central Vacuum
Vacuums Logo
97 people viewed this question
Top Electrolux Vacuums Experts
Mack Baxter
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
