Question about Lomo Photography
Wasted/unexposed film between exposures
Hello there, I have a supersampler and have just developed 2 rolls. Both rolls seem to have the same problem -a lot of unexposed film between pictures (sometimes 5-6 inch gaps) causing me to only be able to get 10 or less pictures per roll. Is this a problem with the advancing mechanism, the way I'm loading the film, the way I'm advancing the film, or something else entirely? Thanks ever so much!
  • 40 Answers
SOURCE: Film won't advance
Perhaps you've already solved the mystery. There are 2 parts to the back of that camera, the film back + the part that it slips onto. And they have little safety latches/pins that couple in order to advance the film & release the shutter. I'm sure those just aren't in the right place. Here in Los Angeles you could take it to any major camera store or repair shop & they've help you out.
Posted on May 10, 2007
  • 619 Answers
SOURCE: Minolta X370 film loading problem.
Hi, check the camera set in auto /manually in auto function, check battery might drain the current , dis engage camera to lense to release the mirror by pressing button beside lense , turn lense in left or right .
Posted on Feb 19, 2008
SOURCE: Film will not load
Took out the battery, then put it back in. The film then loaded properly.
Posted on Jul 23, 2008
  • 185 Answers
SOURCE: I OWN A PENTAX ME CAMERA. I HAD LOADED A 24
you most likely broke the tab off the rewind shaft or striped a gear. there are no new parts for this camera, so if you think you can do it buy another ME for parts ( not working do to electronics ) and replace the needed parts. study the mechanism after the top and bottom cover is off the parts camera.
Posted on Jul 16, 2009
SOURCE: 35mm film developed with streaks
I take it the streak is a hot streak of light. If you're shooting negative, look at the negative and see if it's one long streak. If so the light leak could be anywhere between the film roll and the take up roll. I would open up the back, go into a closet and shine a bright light on the front of the camera and see if you can find the leak and tape it up. Otherwise, 35mm SLR's are very cheap these days. I'd recommend a Canon A-1 for your daughter, but you can't go wrong with any Canon or Nikon.
Posted on Sep 03, 2009
X ray film
Not quite sure what you are asking, but: any unexposed or undeveloped photograhic film ie spool or film cartridge will react to exposure by x-rays. X-ray film as such is more sensitive to X-radiation and captures an image faster. If you are looking for film to take "X-ray" photos - It don't exist. It is the radioactive source that creates the x-rays not the film.
Oct 12, 2014 | Kodak Office Equipment & Supplies
Two rolls of film developed at CVS - apparently not exposed???
it is not unknown for film developing sites to with hold good photos so take another practice roll and have it developed somewhere else
That will prove either the camera or the developer
Apr 23, 2017 | Pentax K1000 35mm SLR Camera
I have taken 2 rolls of film to be developed and neither roll had any pictures on them.
Hi Carrie,
A number of things could be the cause, camera and processing. If it is C41, negative film, we will rule out processing.
Another thing is your camera may not be setting the exposure correctly. Are you setting the exposure manually or automatically? With the camera in automatic exposure open the back, point to a bright spot press the shutter, do you see light? Then Set the camera to one second, and at the widest aperture, say f2.8, open the back press the shutter, now do you see light?
Depending on the results you will need to decide if the camera is worth repairing or a new/used one is in your future.
Cordially
Aug 16, 2013 | Nikon FM10 35mm SLR Camera
My Mamiya RB67 triggers and shutter lease lever works but film advance lever doesn't move. Trigger button fired several times but film advance still showing 1.
This is not the best solution as it indicates a faulty film back. The film should advance without resorting to activating the film-wind release lever. That is only for intentionally advancing a partially exposed roll of film. Make sure the multi-exposure lever is not engaged and that the counter does advance and the red mark disappears as you advance to an unexposed frame.
Nov 09, 2009 | Mamiya RB67 Pro SD Medium Format Camera
Hasselblad 500CM. Film is blank when developped.Shutters seem to work and slide is removed before shooting.
The only possibilities are that the shutter is not working when the lens is mounted on the body, that the film is being inserted incorrectly with the backing paper facing forwards, or the film processing is completely wrong.
I haven't suggested that the film isn't winding through the camera as I'm assuming that when you remove it the film has all transferred to the previously empty spool. I've also assumed that when you describe the processed film as "blank" that you mean it is completely unexposed (clear) as opposed to completely exposed and washed out (opaque).
Jul 09, 2009 | Photography
I may have loaded film roll that has already been taken?
Usually when you finish exposing a roll of film, you rewind it until you are sure it is all wound into the cassette. There is a change in the sound as the end of the roll leaves the camera. An exposed roll would have no film sticking out of the cassette. A new unexposed roll will have a bit of film sticking out of the cassette to pull across the ack to the take up roll.
May 26, 2009 | Canon Elph LT APS Point and Shoot Camera
Pentax SF10 Camera -- double exposure
If you press the film release button like you are going to rewind exposed film you may be able to activate the film advance lever to cock the camera so you can take another picture, and the film should stay on the first exposure allowing you to re - expose it. I would underexpose each image 1 F stop because.you are exposing the same film twice. Double exposures are always an iffy proposition and anything can happen. After the second exposure cocking the film advance should allow the film to advance once again. You might test this on the final pictures on a roll in case the camera won't start advancing the film after you try it. This way you won't blow a whole roll worth of pictures testing it.
Apr 12, 2009 | Pentax PZ-70 QD 35mm SLR Camera
2 rolls out of a 3-pack ruined.
I would suggest you buy an off-brand roll of 12 or 24 exposures. Run it through the camera taking snaps of anything -- but make sure you vary the lighting, ISO, shutter speed, aperture, etc. as you snap the pics. Don't worry too much about composition. This roll is a quick test, NOT for photos to keep.
Have the film developed and then follow-up with comments on the results. I'll gladly assist you further at that time.
Char1ieJ
Nov 11, 2008 | Nikon N65 35mm SLR Camera
Film Advance
You rewound the roll to fix the camera and now you want to advance over the exposed film to get to the unexposed part? Not a problem, just put the camera to full manual and load up the film, now cover the lens with the lens cover and go into a dark closet and start shooting and advancing until you get to the unexposed portion of the film, there you go. You know you can get 24 exposures of 35mm film for 99 cents and the 99cent store?
Feb 15, 2008 | Konica Minolta Maxxum 4 / Dynax 4 QD 35mm...
Konica Minolta X-370 Wont develop
Two possibilities : 1 ) your film was not properly loaded into the pick up spool and hence it was transported or exposed ; what you took to the lab was unexposed film. 2) the shutter is not opening and again no exposure takes place. To check this open back , set to slow speed like 8th of a second, and see if the shutter opens and closes properly. If the shutter does not open then it will have to go in, unfortunately. Cost ? If it is just an adjustment ( as I suspect is the case ) you should not pay more than $ 100.
Nov 01, 2007 | Minolta X-370S 35mm SLR Camera
Photography Logo
Top Lomo Photography Experts
Hashim Khan
Hashim Khan
Tony Parsons
Tony Parsons
Are you a Lomo Photography Expert? Answer questions, earn points and help others
