Question about Panasonic Lumix DMC-LS75 Digital Camera
Lumix closes when turned on from drop
Dropped camera and now it closes when turned on. Also says "please turn camera off and then on again."
    Top Expert:
  • Panasonic Master
  • 6,702 Answers
The message please turn camera off and then on again appears when the camera is not operating properly. So the manual says.
If the message persists you should contact the dealer or nearest service centre. But first you could check if you can see any damage. Check if the lens is not stuck. Remove the battery for a little while before you again try to switch on. Also check if the memory card is still in place and the battery door and memory card door are closed correctly.
If nothing helps you could contact the service centre or think of buying as new camera?
Posted on Jan 02, 2014
SOURCE: Dropped the camera, shutter won't closed, focus keep moving in and out, message "please turn off camera and turn on again"
This recently happened to me and I too got a hefty quote from the company since mine was no longer under warranty. I figured since it was trash anyways, I might as well take it apart and see if I could figure out what was broken. After removing all of the screws and removing the top pin strip from the board (there is a piece of tape on it) and flipping the lens part away from the board, I was able to remove the small gear compartment on the side of the lens housing (held on by one small screw) and the 3 screws on the back of the lens and carefully flip out the digital camera part and push the lens back into it's original closed position. I then carefully reinserted the digital part back into the lens making sure everything was nice and flush and closed it back up. Works like new :D However, if you're nervous about digital machines, I wouldn't reccomend doing this. Luckily for me when my camera fell it simply knocked the digital lens out from the housing and it didn't pop back in right afterwards, causing the lens to not be able to turn completely like it should. If yours is damaged more than this, it may not be such an easy fix. And the camera is difficult to handle as it is connected by those pin strips everywhere. It made me nervous to handle it as I probably could have made it worse, but, I had nothing to lose. Hope this helps out the next person.
Posted on Aug 20, 2007
SOURCE: the camera says please turn
I too have the sam problem but was able to solve it. I called the 1-800-number and was told that this is a very common issue or this camera. They told me to tap the lens when it was extended on a cloth or towel so not to damage it. The point was that there is often a piece of dirt or sand preventing the lens from retracting properly. Guess what, a single grain of sand came out when I tapped the lens and the camera worked perfectly ever since. I looked in the camera case since I keep the camera in it all the time and there were a few grains of sand that had somehow gotten into the lens!
I hope this can help someone else out.
Thanks.
Posted on Dec 18, 2008
bobint17
  • 270 Answers
SOURCE: please turn camera off & then on again
off the camera again and try to open the menu and try to reset it .if the problem persist send it to the survice center
Posted on Feb 03, 2009
  • 11967 Answers
SOURCE: Panasonic Lumix dropped
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Dec 10, 2009
Testimonial: "Thanks so much on the advice on the dropped Panasonic Lumix camera! I went straight to number 7 and twisted the zoom, worked wonders!! thanks a lot!:)"
  • 11967 Answers
SOURCE: Our camera was dropped. It currently turns on and
You have a lens problem. Try these: Fixing a Lens Error on a Digital Camera
Posted on Jul 21, 2010
My pansonic lumix tz3 was dropped and now it won't switch on. The battery is fully charged. Does anyone know of common problems after dropping and what the solutions may be. Of course it may just be...
Dropping a camera can cause any number of different problems that would cause it to not turn on. Only a service center can determine what's wrong but it will be expensive. That's why they put wrist straps on the cameras. You're in a club with the rest of us...we've dropped one once....never again.
Feb 18, 2011 | Panasonic Lumix DMC-TZ3 Digital Camera
My husband dropped our camera, while it was on, face down, forcing the lens back in to it's closed position. It still turns on, but the lens won't extend. Any help?
you may well have striped the lens drive gears off,,,if you can get hold of the lens try pulling on it a little not hard though, it may pop out again,,,but dont hold your breth its going to work again,
Aug 09, 2010 | Panasonic Lumix DMC-LZ7 Digital Camera
Dropped camera which landed on zoom lens.
Have you tried manually trying to pull out the part that is pushed in?
Sep 24, 2009 | Panasonic Lumix DMC-LZ2 Digital Camera
Lumix FS-15 "System error (focus)"
I have the same issue with my 3 month old Lumix DMC FS15 plus it won't focus and gives the error message to "turn camera off and then on" This doesn't fix it.
Bottom line fix: Don't buy this camera again and don't recommend other buy it.
Sep 19, 2009 | Panasonic Lumix DMC-FZ28 Digital Camera
Camera was dropped. Now it will turn on, but after a few seconds, lens begins to move in and out for about 3-5 seconds, then a messag is displayed: Pleaase turn camera off then on again". Doing this r
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
May 17, 2009 | Panasonic Lumix DMC-LZ3 Digital Camera
The camera does not work
Iam sorry iam afraid the barrel is broken(did you dropped it on the lens?
Dec 15, 2008 | Panasonic Lumix DMC-TZ3 Digital Camera
Turn Camera Off error message
hi
I have the same error code if you can help me please let me know
thanks a bunch
Jun 29, 2008 | Panasonic Lumix DMC-FZ30 Digital Camera
Problems with my Panasonic Lumix Digital camera
let me explain to you guys, these cameras are slim line cameras and if dropped or mishandled it is going to give problems. you cant blame the camera if you are not handling it corectly.
Jan 01, 2008 | Panasonic Lumix DMC-FX7 Digital Camera
Panasonic Lumix DMC-LS75 Digital Camera Logo
52 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
