Question about Genius Twin Wheel F1 Vibration Feedback F1 Racing Wheel for PS2 & PC
How to turn off vibration for this wheel?
How do I turn off vibration for this gaming wheel connected to my PC?
Logitech Formula Vibration Feedback centering
It can be the wheel's problem, just took mine apart today. Don't be afraid, it's very simple on the inside. Just take out the screws on the bottom and there are two on the wings (open state, not closed) - now the whole bottom comes off, the wings stay on the bottom part and everything else is inside the top. Now you will see the axle with the two springs connected to it (I removed the springs from mine, feels much nicer). On the very end of that axle is a small piece of electronic, a potmeter with three wires hanging out of it. Now connect your wheel to the PC and fire up some tool that shows the exact wheel position (Windows' usb game controller utility does the trick, but I'd recommend some SimBin title, Volvo The Game is available for free, the advanced settings offer a much more precise bar for calibrating). When connected, try moving the potmeter instead of the wheel itself. You'll notice that the PC sees the movement. Now manually find the point where it's centered and fix the potmeter in that position with something - e. g. duct tape or something more professional.
Hope this helps someone goofing around here looking for a solution. :)
EDIT: I took off the white part that keeps the main axle in place and tried to fix the position of the sensor with a small piece of paper, turned out to be rubbish, so I kept going and had a way better idea.
I took out the wiring from the sensor and put a rubber band on it, then I put the wiring back in and hanged it on the left side of the plastic - on the photos this is the yellow one with many twists. For extra stability I added two more bands after that (the other yellow and the red one), this keeps the sensor straigt on the y axis (causing less tearing), but in the x axis it's tilted to the left, so it is pretty much centered. Also, the twisted yellow band is between the other two! With this you can make sure it will keep its position and won't move downwards and lose effect. This whole setup won't stick forever, and may kill the sensor eventually, but it is a working and pretty stable solution. Also, it brings back and otherwise useless piece of tech to life. You have to find the right strength of the bands yourself though (adding twists will increase it) depending on the current position of your sensor.
(The whole wheel isn't an engineering marvel and even the centered sensors wobble around causing craziness, so you can do this on both sides, just to make sure it's precise.)bb9b28ec-8ec0-42c8-a85a-efa16d0cf493.pnglogitech-formula-vibration-feedback-ma0a5zuwaz1yymg3pjh0mf1t-1-2.pnglogitech-formula-vibration-feedback-ma0a5zuwaz1yymg3pjh0mf1t-1-3.pnglogitech-formula-vibration-feedback-ma0a5zuwaz1yymg3pjh0mf1t-1-4.png
Feb 09, 2014 | Logitech Formula Vibration Feedback...
Vibration is not working when i play game plz help
just activate the vibration in the option of the game or console and if its still not working then the problem is in your controller and should get a new one or if the controller is still in warranty and you should go back to the store where you bought it and make them fix or replace it
Mar 17, 2011 | Video Game Consoles & Games
Will not vibration
try logitec for drivers and compatability
also check game options for vibration
make sure it actually vibrates.
May 08, 2010 | Logitech DRIVING FORCE FEEDBACK STEERING...
When i ride a car with my GENIUS SPEED WHEEL 3 the car goes to left side continuously but when i ride with the keyboard thats straight
Try unplugging the wheel then plug it in again. It sometimes happens when you, while plugging in the controller, turn the wheel. Then the wheel sets that as neutral position.
If that doesn't work, or the problem happens all the time, then take it to the store you got it from.
If you brought it on eBay, then I have no other ideas...
Mar 31, 2010 | Genius Speed Wheel 3 Vibration, USB, PC...
Nonlinearity
Hi, The non linearity is the options that allow you to experiment driving experience in game, such as: In NFS you have a damaged wheel, the car will go itself on the left/right then the Formula Vibration will reproduce the car behavior and adapt game related feedback into the gameplay . This feature depend of the game support. Thanks and have a nice day J -
Mar 25, 2010 | Logitech Formula Vibration Feedback...
I have a LOgitech Formula Vibration Feedback wheel, and I have some problems with it....... A few days I reinstalled my Windows (Windows Vista x32), and after that it doesn't recognize it in games. Yes I...
make sure you have the latest service pack if vista can see the controller in the control panel>gamecontrollers>properties and it tests fine then it is not the wheel. it just the game
turn off your antivirus temporarily and start the game again.if it still does not work in the games you mentioned look for patches on the games web sights.
Jul 20, 2009 | Logitech Formula Vibration Feedback...
Any way to turn off annoying engine vibration on the Logitech g25
nope, it's an iracing thing. Call their technical support, let us know how that goes.
Feb 22, 2009 | Logitech G25 Racing Wheel
LOGITECH FORMULA VIBRATION FEEDBACK WHEEL FOR MAC
Hey i need help. My wheel don´t work on my windows
Jun 06, 2008 | Logitech WingMan Formula Force GP...
Genius Twin Wheel F1 Vibration Feedback F1 Racing Wheel for PS2 & PC Logo
85 people viewed this question
Top Genius Video Game Consoles & Games Experts
James Wishart
Josh Whitehead
Josh Whitehead
Are you a Genius Video Game Console and Game Expert? Answer questions, earn points and help others
