Question about Jenn-Air JSD2789GEB Side by Side Refrigerator
Suspect defrost issues with JSB2789GEB Jenn-Air/Maytag
Noticed some buzzing noise, sometimes when compressor would shut off, could this have been a defrost relay trying to switch on?. This is a side by side, the freezer door got left slightly open a few times, and then fridge side was not as cool as it should be. Looked at coils in freezer and they were frosted up thus no air-flow to fridge. Manually defrosted and was ok again for a while. Now I think the defrost cycle may not be working at all, have not noticed any buzzing like before. Freezer stays well cold, but fridge eventually gets a bit warmer. Please help with what to test/check, etc.
Tim
  • 2 more comments
  • trmay May 24, 2009
    Thanks, the fridge still seems to cycle on & off ok, but when I check behind the panel ( coils ), seem to have quite a build up of frost, think that it gets too much and air-flow can not get to fridge side. How can I make sure defrost cycle is working?
    Other posts seem to think it could be: Adaptive defrost control board
    Is this easy to replace or test?
  • NorseXNW
    NorseXNW May 11, 2010
    As I was afraid, some new units use a printed circuit board and I know of no way to force it into defrost mode. You'd have to take the panel off the evaporator and catch it in the defrost cycle and see if there is heat being generated by the heating element in the evaporator. Perhaps someone with more expertise in the circuit board style defroster can help. Check web sites, youtube included for any helpful information and don't forget the local library. What is the warranty on the fridge? Have you contacted the maker of the unit?
  • NorseXNW
    The buzz may have been the heater melting the ice on the evaporator. You will want to check the defrost timer and see if it is working. Research defrost timer and visit Jenn-Airs web site for a parts breakdown to help you locate it or look at your manual it should have a parts breakdown. Does the fridge run all the time?
SOURCE: fridge wont get cold and freezer gets cold then gets warm
I Had The Same Problem , Went To partselect.com  You Will Find A Solution And Reasonable Priced Repair Parts There
Posted on Apr 18, 2008
  • 1314 Answers
SOURCE: cooling coil in freezer compartment froze up
id say your right the unit should defrost for 30 mins of every 8 hours of compressor runnig time now that's not normal time because the thermostat cuts the unit off and on every now and then . the timer for defrost measures how long the compressor runs and it varies with how often the doors are open im sure parts of your defrost system are inoperative send me an e mail with your model number and i will help b4829@yahoo.com
Posted on May 26, 2008
mikedurland
  • 481 Answers
SOURCE: Re: Refrigator will not stay cold
defrost problems are caused by 3 things
bad: 1) defrost timer/ timer board 2) defrost heater (in freezer) or burnt wire going to the heater 3) bi-metal thermostat (round metal piece attached to the coils with     at least 2 wires going to it)
a good technician can test components without the machine running. all you need is a simple $5 meter any tech that gets angry, show him/her the door!
Posted on Jun 28, 2008
tborn6
  • 700 Answers
SOURCE: freezer is frosting up
check your gasket on the freezer it may not be sealing properly. that is the main cause of the freezer compartment frosting up. also when you defrosted it did you otice if the drain line was clear and the water was going out of the freezer?
Posted on Dec 27, 2008
  • 103 Answers
SOURCE: freezer works but refrig has 60 degree temp .evap coil is caked
Hi: Did you check the defrost heater itself? I checked Jennair and Sears parts to no avail. If you didn't check the heater it will be at the bottom of the freezer behind where you removed the back cover. A glass tube with a coil in it. If the coil or tube is broken replace that insead. I hope I helped, Jeff I found a website with the defrost timer, but not the location of the timer on the fridge. http://www.appliancepartsworldwide.com/store_SearchResults.aspx?S=1131392&ST=PBM
Posted on Jun 01, 2009
Jenn-Air Maytag double wall oven makes loud buzzing noise
There is a cooling fan for upper and lower oven they run at the same time no matter which oven in use it is fed from the oven manager no way to trouble shoot without pulling oven out some models use same fan for both so you could have a blower on hand remove back panels to access fans take a lead off fan to determine which one noisey
Feb 03, 2015 | Jenn-Air Ovens
We have Jenn Air Built In Ref Model# JS48SEFXDA. We had the Power Supply Circuit part# AP4076255 replaced last year. We had a power outage 3 days ago. The fridge and freezer just quit cooling today. The...
The newest defrost feature in modern fridges is the electronic adaptive defrost control board. Maytag/Jenn Air has one version, see diagram...to put this adaptive defrost style of fridge into defrost, short with a small screwdriver between L1 and test on the adaptive defrost board, wait 3 seconds and you should hear a "click" noise from the relay and the fridge will shut off and go through a defrost cycle.
Jul 24, 2011 | Jenn-Air Refrigerators
Buzzing/humming noise with jenn-air bottom freezer
i have this problem too on my GE Profile. A youtube video seems to suggest a compressor problem. Turn off the fridge for a while and let it cool down and try again? I tried but to no avail. Would someone answer this? Please :)
Mar 21, 2010 | Jenn-Air Refrigerators
Jenn Air JSD2789GEW side by side Refrigerator not cold
If the adaptive defrost timer is out (hidden circuit board at top of fridge behind light panel), the freezer coils will ice over & prevent the air from circulating over to the fridge side. If the defroster coil or temp sensor is out (lower freezer side behind large panel), it will cause the same effect. If the "start relay" on the compressor is going bad, it may not allow the compressor to come on when its supposed to. My unit suffered from this. It still cooled, but not nearly as well as it was right after I replaced the adaptive defrost timer. I noticed I heard clicking for around 15 seconds.. this was the relay trying to function & activate the compressor. Perhaps the faulty adaptive defrost timer caused the compressor relay to go bad? Regardless, those are the usual suspects I'd tackle first. They can all be tested to prevent the expense of "part changing" Adaptive defrost timer is ranging from $35-$79 online..your loca maytag/jenn air dealer will have these in stock as they are the most common culprit. Relay is $10.50, defrost heating element around $50. These are all very simple & easy to replace. Pretty much just a philips screwdriver & removing a few panels. Remember, ALWAYS make sure any electrical device is unplugged before servicing, also, some capacitors (i.e.,around compressor) will hold a charge like a battery & will zap you. Always test the wire with a meter before touching. The real expense is having somebody do the work for you. Good luck.
Oct 01, 2009 | Jenn-Air JSD2789GEW Side by Side...
Buzzing and clicking sound every few minutes
Compressor start relay - white plastic part - sitting right on the compressor, disconnect it shake it - u'll here it if it's damaged. :)
Oct 01, 2009 | Jenn-Air JCD2389G Side by Side...
Amana/Maytag ACD2234HRS sometime not working
If your compressor is running with the noise you described, I would make sure the parts that were replace on compressor are working properly. Also use a amp meter and get a reading on amp draw while it is humming. Anything that is above normal readings for the compressor would indicate compressor is bad or the relay and starter are not working properly. I need a series number also like a number 15 before the model number, Thanks, Sea Breeze
Mar 21, 2009 | Maytag MZD2766GES Side by Side...
Clicking noise from JCD2295HES side-by-side refrigerator
sounds like a compressor relay check with maytag mightr be one of the recall ones
Mar 17, 2009 | Jenn-Air JCD2295HES Side by Side...
JBR2086HES - Jenn-Air
If it was buzzing then click, the click would mean that the thermal overload has activated. This would happen if the compressor is drawing high amperage due to a breakdown of insulation on one of the starter or run windings. What he says is very possible.
Mar 03, 2009 | Jenn-Air JBR2086HES Stainless Steel Bottom...
Maytag refrigerator clicking noise and stopped working
How long a period of time have you noticed this noise? If it just started and the refrigerator just stopped it could have entered its defrost cycle. When the defrost heaters come on you may hear the heat causing some expansion. After a few minutes(18-22) the defrost cycle ends and the refrigerator will restart.
May 30, 2008 | Jenn-Air JCD2389G Side by Side...
Freezer/Fridge work SOMETIMES
Sounds like you have a bad relay on the compressor or a bad compressor. If the compressor is a Tecumpseh brand then it is most likely the problem.
Oct 04, 2007 | Jenn-Air JCD2290HES Side by Side...
Jenn-Air JSD2789GEB Side by Side Refrigerator Logo
111 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
