Question about Genius Twin Wheel F1 Vibration Feedback F1 Racing Wheel for PS2 & PC
How to turn off vibration
How do I turn off vibration for this wheel?
WHEN TURNING THE STEERING WHEEL IT VIRBRATES
If you are turning the steering wheel all the way to the "lock" position, you are probably putting too much pressure on your power steering pump and you are most likely getting som drive-belt slippage.
Nov 12, 2011 | 2002 Oldsmobile Bravada
Steering wheel vibration whe I rotate it??????
The vibration and rubbing may be separate issues. There could be many causes for vibration, ranging from low fluid, sticky rack valves, etc., to the tires simply grapping and releasing on the pavement. If it only does it under heavy use, such as when standing still and turning alot, then I suggest not doing that. It is hard on a car to turn the steering wheel when the car is not moving.
May 21, 2010 | 2008 Hyundai Elantra
Subaru 03 Forester - problem in front differential, 3 wheels turn
Thumping noises and vibrations can be something as simple as a tread separation(or a big bubble) on one of your tires.As for the one wheel turning---that's perfectly normal.If you grab the wheel that's turning (not really recommended) and stop it completely,the other wheel will spin.
Mar 01, 2010 | Subaru Impreza WRX STi Cars & Trucks
I have a vibration in the front drivetrain on my Sorento. the vibration starts at about 30-35 mph and gets loudest at about 65-70 mph. The weird thing is that teh Vibration and associated noise completely...
ball joints or bent rim. Does it click or thunk when turning? It may be tie rod as well. You can lift it up and try turning wheel by hand and shake it to see how much play there is.
Check the there is a weight on the rim. Every one is supposed to have one.!!!!
Oct 27, 2009 | 2003 Kia Sorento
Front End noise and vibration
Check the U-joints and axle baerings. But its most likely because the truck is in four wheel drive.
Aug 16, 2008 | 2002 Ford F350 Super Duty DRW Reg. Cab
Vibrates continuously
While Looking at the Sideview of the Main part of the headset, press the center button (Menu) it will read [Call List] in parenthesis just like this. Turn the Volume Wheel Clockwise to [Settings], then push Center of Volume Wheel.1st to appear should be [Vibra Alert], press Center of Vol.Wheel and it will probably have parenthesis on [On] Turn Vol. Wheel to [Off] and Press Center of Vol Wheel to Change it . Shouldn't Vibrate any more. If it Does You've got other Problems .
Jun 11, 2008 | Jabra BT8010 Wireless Headset
Genius Twin Wheel F1 Vibration Feedback F1 Racing Wheel for PS2 & PC Logo
175 people viewed this question
Top Genius Video Game Consoles & Games Experts
James Wishart
Are you a Genius Video Game Console and Game Expert? Answer questions, earn points and help others
