Question about Coleman Heating & Cooling
NEED A WIRING DIAGRAM FOR A DEFROST BOARD ON A COLEMAN HEATPUMP M#EABA-F0303A
NEED A WIRING DIAGRAM FOR DEFROST BOARD
burzerko
  • 254 Answers
SOURCE: HOW TO INSALL A COLEMAN
This is actually a very easy task as long as you get a direct replacment board. If not the key essentials are the reversing valve contacts and the power contacts coming to the board.
As long as the board is a direct replacement you can switch wire to wire form the old board to the new board.
Please re comment me if you have any other questions.
Posted on Aug 28, 2008
TheMobilian
  • 8220 Answers
SOURCE: i need wiring diagram for an old coleman suncutter/whole house a/
yeller cool
red common
white heat
green fan
Posted on Jun 06, 2009
  • 51 Answers
SOURCE: wiring diagram for Rheem rpka-31 jaz heatpump
TURN THE POWER OFF TO THE UNIT. TAKE THE BACK PANEL OF OF THE HEAT PUMP AND LOOK FOR A SQUARE PLASTIC BAG FASTENED TO THE INSIDE OF THE UNIT, IT MAY BE LOCATED BY THE CONTACTS AND SYSTEM WIRING OR ON THE PANEL ITSELF. REMOVE THE PAPER FROM THE PLASTIC AND THIS SHOULD CONTAIN YOUR WIRING DIAGRAM. ALSO LOOK ON THE BACK OF THE PANEL ITSELF FOR THE DIAGRAM. SOMETIMES THE DIGRAM IS PRINTED THERE.
Posted on Apr 13, 2010
SOURCE: Wiring Diagram Coleman Electra Heat Mach EL
I need the motor for a mach EL air conditioner. I can not get a model number of the unit or a number off of the motor. Can someone help me. Its about a 1980 built unit.
Posted on Jul 13, 2010
hvac1960
  • 2133 Answers
SOURCE: 8333B671 Coleman Air Conditioner Wiring Diagram
Normally wires are with RV.
Posted on Aug 18, 2012
How do I wire a Coleman Evcon 3500A916 furnace Model
Wiring Diagram for a Coleman Furnace - RV-Coach Online
www.rv-coach.com > Discussion Forum > RV - Insurance
... Furnace, Mark, 9-12-07. Need wiring diagram for coleman furnace Model # 7700B856 .... Amanda, 11-10-11. I need a wiring diagram for a Coleman evconpresidential model 7956c856 ... Need wireing diagram for coleman 3500a916 ... More results from www.rv-coach.com
FURNACE Diagram & Parts List for Model eb15b Coleman ...
Dec 22, 2015 | Coleman Heating & Cooling
We replaced fan motor on heil heat pump , now the defrost isn't kicking in, is this a wiring problem or unrelated to us replacing the fan motor?
Check low voltage at heatpump need 24voltsat R and C tterminal s if you have 24 volts on defrost board change board .if you dont have 24volts from r and c you have to go to indoor unit and look at low voltage wireing . Check wire nuts or when replace ing motor might have knock some loose check all low voltage. Hope this helps
Feb 27, 2015 | Heating & Cooling
HI-i have a coleman heat pump- on defrost it gives cold air- not normal. thanks
Do you have electric heat strips for auxillary or backup heat? When the heatpump goes into defrost, the electric heat strips or whatever your source of auxillary heat is, should come on to keep you from feeling the cold air. When the heat pump is in defrost it is essentially operating in the A/C mode, that is why you will feel cold air if the auxillary heat isn't working. You need find out why the auxillary heat isn't coming on if it isn't. It could be do to a bad seqencer or a burnt out element.
Mar 11, 2011 | Heating & Cooling
Wiring diagram for Rheem rpka-31 jaz heatpump
Apr 13, 2010 | Heating & Cooling
CHANGED OUT UNIT NEED HELP NEW WIRE
Is this heat pump? Straight A/C? You should have a wiring diagram with a new unit (installation manual) that will give you what you need depending on your model. They generally have a few different configs so they only have to put one manual in every unit. If it's a straight a/c, its simple. You have two wires coming off the outdoor unit. One goes to the y terminal and the other goes to the c terminal. Y is for cool and C is for common. A heatpump is a lot more difficult and I would recommend hiring a professional to wire it up so you don't burn up the defrost board. Also, you may find a wiring diagram on the inside of the outdoor cover. Hopefully this helps.
Apr 09, 2009 | Goodman CLQ36AR49 Air Conditioner
Need wiring diagram
here would be the hook ups that are needed. at the air handler
r-red
g-green
c-common
w1/w2/aux-white (DEPENDS ON WHAT TYPE OF SYSTEM YOIU HAVE)
then these are what goes to the outside unit
y-ylw
o- org/or b-blue
c-white
r-red
personally contact me if yopu still have questions. thanks
Jan 11, 2009 | Coleman Propane Forced Air Heater...
HOW TO INSALL A COLEMAN HEATPUMP DEFROST BOARD
Aug 26, 2008 | Coleman Heating & Cooling
Heating & Cooling Logo
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
