INK PADS ARE FULL & NEED TO EMPTY & WASH /REPLACE WASTE INK PADS
WHERE ARE THE WASTE INK PADS IN THE RX560 HOW DO I GET TO THEM TO WASH THEM THANKING YOUW
  • NEW DAWN May 22, 2009
    HI SHERLYN HAVE TRIED EPSON BUT ALTHOUGH I`VE GOT THE CLEANER UP THE BLACK STILL WILL NOT WORK ALTHOUGH THE INK LEVEL IS GOING DOWN ON CLEANING BUT NOT PRINTING HAVE YOU ANY IDEAS THANKING YOU
    TRIED THEM FIRST ALL THEY SAY IS UPGRADE & I CAN`T AFFORD THAT AT MOMENT THANKS ANYWAY BYE
    Scholar:
  • 134 Answers
The ink pads are not washable. You have to replace them.
Then log on to epson.com/ipr to get the ink pad reset software. The software runs only on win vista and xp.
Posted on May 21, 2009
  • Sherlyn Cano
    Sherlyn Cano May 22, 2009
    Since this is already a printhead issue, i suggest that you log on to support.epson.com. click on help me find a service center to the right of the page to find an epson certified servicer near your area.
When I turn printer on power light does not light and ink out and paper feed light flash alt slowely
alternating flashing lights on ink and paper could mean that your printer is locked The cause waste ink pads are full Option should be to take the printer to your nearest Service centre and have it diagnosed and new ink pads fitted cost between £50 to £60
Or you could remove the waste ink pads yourself and replace them or wash them out dry them using a hairdryer etc and replace them you will then need to have your prnter reset
What you will need is a service manual for your printer model, and a restet utility you can get the reset utility free of charge from the internet
May I suggest that once you have done this you consider getting an external waste ink jit and fit it
no more stripping the printer and messing with ink pads it only takes five minutes to fit and is very easy to empty
Mar 31, 2010 | Epson R1900 Printer
Waste ink absorber is almost full. How do you empty or replace the waste ink absorber? The printer will no longer print.
if this happens, just turn off the printer plug,then hold the reset\stop button,after that you turn on the plug while pressing the stop reset button, then follow these steps
To reset waste ink counter:
Press Menu-Scan-Copy-Scan to enter service menu.
Use arrow keys to scroll to “Service menu counter access”.
Press OK.
Use arrow keys to scroll to “ABS-M DOT COUNT”
Press Copy.
Use arrow keys to reset count to zero.
Press OK.
Press Stop/Reset.
(optional)
To clean physical pads:
Open cover (as if replacing ink cartridge).
Locate waste ink pads, they are far right under cartridge slider.
Pry up waste ink pads (inky, might want to wear gloves).
Rinse pads in sink or with alcohol, dry.
Replace pads. Make sure pads are fully seated.
Oct 20, 2009 | Canon PIXMA MP130 All-In-One InkJet...
Waste ink absorber is full How do i empty it
You can't empty that one, you need a shop to replace the pads which are under the printer, and they can reset the waste ink counter at the same time.
Sep 29, 2009 | Canon PIXMA MP130 All-In-One InkJet...
My error message says the used ink tank is full. How do I empty it?
You can't empty it, it's a set of pads covering the whole bottom of your printer. They only cost around $10.00 but you need a shop to replace and reset the waste ink counter.
Sep 02, 2009 | Canon BubbleJet i560 InkJet Printer
Printer won't printer as message says parts are
Part are end life cycle : waste ink pad full. Need to reset waste ink counter. SSc ver 4.3 support RX 620 and 640. U can try using printer model RX 640. Menu Protection Counter, Show current value for checking. Reset protection counter. Or Try to find RX630 adjusment at indoreset,blogspot.com. Don't forget to replace or wash the pad. Or extend outlet waste ink pipe to outside.
Jun 28, 2009 | Epson RX620 All-In-One InkJet Photo...
How do you find the waste ink collector on a printer/scanner ?
Inkjet printers have a fibrous pad inside them that collects the waste ink from cleaning the print head. Over time, this pad fills up with ink and can no longer hold any more. When this occurs, the printer indicates a "waste ink tank full" error.
The waste ink absorption pads are inside the printer, in the very bottom. They are usually soaked with ink when full and are very messy.
Replacing the waste ink absorption pads is something an authorized canon service facility can take care of for you.
May 18, 2009 | Canon PIXMA MP170 All-In-One InkJet...
Indicates waste ink absorber is almost full on cannon i9900 print
Inkjet printers have a fibrous pad inside them that collects the waste ink from cleaning the print head. Over time, this pad fills up with ink and can no longer hold any more. When this occurs, the printer indicates a "waste ink full" error.
The waste ink absorption pads cannot be emptied, only replaced.
Replacing the waste ink absorption pads is something an authorized canon service facility can take care of for you. Once they are replaced, it'll be functional again.
May 16, 2009 | Canon i9900 InkJet Photo Printer
The printer is indicating "waste ink near full"
Hey,
The waste ink pads should generally be around the cartridge carrier, or below, possibly at the bottom of the printer.
have a look at this page for instructions on how to reset the counter after the waste ink pads have been cleaned or replaced.
http://www.allthefaqs.net/forum/viewtopic.php?t=3770
Let me know if you need anything else.
Thanks,
Ekse
Mar 06, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Canon Pixma MP780
Yep your printer is nearing service time. This involves changing the waste ink pads and resetting it.
you could reset the printer without changing the wate ink pads but you risk damaging it
What i do is take the pads out wash them and replace them.
the waste ink pads are the pads the cartridge rest on whan itsn in neutral position
THE SERVICE MANUAL FOR YOUR PRINTER *step by step instructions in repairing it) is here
http://www.nodevice.com/manual/Canon/page15.html
and here
http://www.nodevice.com/manual/newmans/1164257699mp750780smpdf/get13922.html
enjoy
Dec 18, 2007 | Canon PIXMA MP780 All-In-One InkJet...
Epson RX560 Waste Ink Full Service Required
i brought software today to fix my rx560 ink pad problems fixed software cost me £40.00 but am willing to pass it on at a cost of £5 software does not run on vista so will need a pc with xp or some thing like that to fix as i say i reset mine today thanks for your time and please contact me if you need this software
Dec 15, 2007 | Epson Printer
626 people viewed this question
jasbo
jasbo
