Question about Bosch Washing Machines
Bosch Maxx7 water problem
My wasching machine has problems filling up with water. It started earlier today. Instead of a flow of water the machine just sends a spray out. Made a video to show the problem. http://www.youtube.com/watch?v=HJEoGC-0FUg Any ideas?
5 Suggested Answers
  • 1937 Answers
SOURCE: Washer won't agitate, but will drain. Loud cliking sound--VIDEO
This looks like a basic Kenmore / Whirlpool top load, direct drive, neutral drain washer.
Assuming that it won't agitate at all, but will pump, here are a couple of things to consider.
1. There is a motor coupling between the motor and transmission that is used as a fail safe. It has plastic pieces with three prongs on the transmission and motor shafts with a rubber coupling between them. If the rubber piece is broken or damaged, the transmission cannot turn the agitators or tub for spin mode. The pump is directly driven off the motor when is in reverse mode.
See the following Whirlpool document on installation and maintenance with a good troubleshooting guide.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Also see the Sears parts site :
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number and a list of sub-components will come up. Check the section on motor and pump and you'll see the coupler.
2. Beyond the coupler (an easy fix) it could be the agitate cams and gears in the transmission.
If the washer spins I'd look at those or the Neutral Drain assembly in the transmission.
As for the pin, It is one of three shipping pins designed to break off and fall into a plastic cup under the tub when the washer is installed. I'd look under the tub and see if the pin is missing from one of the cups. If it is, it's nothing to be concerned about.
Posted on Sep 22, 2009
blueextc3221
  • 15935 Answers
SOURCE: Causes of washing machine smell. What will remove the stink?
The first thing to do is to CHECK IN AND AROUND THE RUBBER DOOR BOOT (called a bellow) for small articles of clothing (like socks and underwear) that may have gotten lodged in behind the rubber. Pull the rubber back where it meets the wash tub and look behind it. It is common for small items to get stuck here, become forgotten and start to mildew. You should check this area after each wash and clean it periodically to get rid of the formation of soap scum, mold, and mildew. HINT: When you get ready to wash a load of towels, take a dirty towel and clean the door boot thoroughly (including the areas behind the rubber). Immediately place the towel in the wash and run it on a sanitary cycle. This way you eliminate the need for cleaning rags.
PERIODICALLY RUN THE WASHER ON A CLEANING CYCLE. Place the washer on the hottest setting you have (usually a Sanitary cycle) with nothing but bleach in the wash tub. Some newer models actually have a "Clean Cycle" available now just for this purpose. This helps keep the wash tub, drain lines and pump sanitized.
CHECK AND CLEAN THE DRAIN PUMP FILTER. Accumulations of debris in the drain pump filter can also cause odors. HINT: If you own a shop vac, pull the drain hose from the standpipe at the wall and pull a vacuum on the line. This will drain any residual water left in the tub, pump and drain lines BEFORE you remove the drain pump cover. This will prevent a messy clean up later.
LEAVE THE DOOR OPEN IF POSSIBLE. When not in use, leave the door open to allow the tub to air out and to keep mold and mildew from forming on the door bellow. I know this may not be desirable in some households with small children. If too much mildew forms on the rubber and it cannot be removed, replacement of the bellow may be required.
NOTE: This problem is common with front loader style washing machines. The doors on these machines have an air tight/water tight seal that is great for sealing the washer during the wash cycle, but can be terrible for collecting small garments and for not allowing the tub to properly air out when not in use. Following these simple preventive measures can go a long way towards preventing harmful mold and mildew, and towards extending the life of the door bellow and pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 28, 2010
kvhappliance
  • 218 Answers
SOURCE: http://www.youtube.com/watch?v=4PiCHrZ0d50&fea...
your brake/clutch assembly is malfunctioning... Replace the basket drive assembly it also comes with a new clutch/brake pad.
Posted on Nov 13, 2010
caroldon
  • 17130 Answers
SOURCE: hotpoint aquarius wont work, it starts to spin but
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Check this link to replace the inlet valve:
http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the dry spin with the drain valve/pump activated so as to drain off all the water from the clothes during the spin.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help
Thank you for using fixya.
Posted on Sep 27, 2011
Bosch washer over fills with water
If the water flows though the inlet then the flow pressure should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Jan 19, 2013 | Bosch Axxis WFL 2060 Front Load Washer
Have bosch sgs 6312gb it's not filling with water in machine
If it works when water is added the the over flow switch is ok
Here is the diagnostics guide Bosch dishwasher service guide
Nov 23, 2011 | Bosch Dishwashers
Bosch WFMC3301UC washer. The water will not flow into the machine. After a few minutes we see an error msg E02. I had replaced the hot water inlet valve two months ago because it developed a leak. No...
Bosch WFMC3301UC washer. The water will not flow into the machine. This video will show you how to find that leak on any front loading washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
And don't forget to like us on facebook
Aug 12, 2011 | Bosch WFMC 3200 Front Load Washer
Year old Bosch SHU33A0UC won't start. Lights on
Light's on mean you have power.
Initiate the self test program by doing the following -
To start test program, press and hold both POWER SCRUB PLUS and RINSE & HOLD program buttons, then turn unit on
by pressing ON/OFF button. When program buttons are released, lights above them will flash. To end test program, press
ON/OFF button.
To check program indicator lights (POWER SCRUB PLUS, REGULAR WASH and RINSE & HOLD), press and hold each
program button. When REGULAR WASH program button is pressed, CLEAN light also comes on.
To start testing, press both POWER SCRUB PLUS and RINSE & HOLD buttons a second time. When testing has ended
and a fault was detected, the following indicator lights will be lit:
POWER SCRUB PLUS = Heater fault
REGULAR WASH = Water filling fault (over or under filling)
RINSE & HOLD = NTC (temperature sensor) fault – note circulation motor stops shortly after it started
during an NTC fault
To check for heater, high limit or flow switch problems, start testing until heating starts. Using a meter with a current coil,
measure current going into dishwasher. If current is ~ 11 A, then heater, high limit and flow switch are OK. If current stays
at ~ 1.5-2 A, then heater, high limit or flow switch are faulty.
If water level switch (f1) has failed (opened), REGULAR WASH light will come on and unit will continually fill and drain
where testing won't be completed. If flow switch (e5) has failed (opened), water won't heat (to 150ºF) and water won’t stop
circulating. If NTC probe (f2/f4) has failed (opened), RINSE & HOLD light will come on immediately and testing will end
shortly after water has started circulating.
If more than one fault occurs, more than one light will be lit.
Let me know what you figure out. I can repair these boards most of the time.
Dec 18, 2009 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Bosh wasching machine wfr2830 error code 7 Anybody knows wht's the problem? thanks
I am factory authorized Bosch service and parts supplier and love the Bosch products.
Contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service and we will get the correct part out to you asap.
Thanks, Ella
Nov 15, 2009 | Bosch Logixx WFT 2806 Front Load...
Bosch continues to fill when rinsing even when the machine is off
The inlet valve is stuck open most commonly , you can check this by taking the wires off the valve and then turn everything back on , if the water is still flowing replace the inlet valve.
Phil
Apr 14, 2009 | Washing Machines
Bosch
f is fill fault to much or not enough water or water in the sump white plastic base the f code will not go away until you solve the problem when the f code shows up the drain motor will run all of the time
Apr 01, 2006 | Bosch 24 in. SHU6802UC / SHU6806UC...
Washing Machines Logo
16 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
