Question about Garden
Bolens ht 20
Rear axle locks up
    Champion:
  • 279 Answers
IF THERE ARE NO BRAKE ISSUES- then the gear selector is out of adjustment- or worst case- the transission is going out
Posted on Jun 03, 2014
2009 trailblazer rear drivers side axle won't come out. c clip is out
Special Tools
  • Slide Hammer
  • Axle Remover
Removal Procedure
  1. Raise the vehicle. Refer to Lifting and Jacking the Vehicle.
  2. Remove the tire and wheel assembly. Refer to Tire and Wheel Removal and Installation.
  3. Remove the brake caliper. Refer to Rear Brake Caliper Replacement.
  4. Remove the rear wheel speed sensor. Refer to Rear Wheel Speed Sensor Replacement.
  5. Remove the rear axle housing cover and the gasket. Refer to Rear Axle Housing Cover and Gasket Replacement.
  6. Remove the pinion shaft locking bolt.
  7. On axles without a locking differential, remove the pinion shaft.
  8. On axles with a locking differential, remove the shaft part way. Rotate the case until the pinion shaft touches the housing.
  9. On axles with a locking differential, use a screwdriver, or a similar tool, in order to enter the differential case and rotate the C-lock?(1) until the C-lock aligns with the thrust block?(2).
  10. Push the flange of the axle shaft?(1) toward the differential.
  11. Remove the C-lock from the button end of the axle shaft.
  12. Note: When removing the axle shaft, do not rotate the shaft. Rotating the shaft will misalign the gears. Misaligning the gears will make the installing of the axle shaft difficult.
  13. Remove the axle shaft from the housing.
  14. Hope this helps?
Apr 09, 2018 | Cars & Trucks
How to remove the front tire from a bolens lawn tractor?
Usually there is a spring clip on the axle. These little clips fit in a groove on the axle and are not very noticable. Look up circle clip. A screw driver (fairly large for a mower) can be used to slide them away from the axle. You may have to pull (tap) the wheel to get it off the axle as the last bit of axle sometimes develops some rust and the wheel does not want to slide off freely.
Sep 04, 2014 | Garden
Bolens RIDE ON MOWER wont roll
on the rear of the machine there is a rod you pull out to push it around
Sep 17, 2012 | Garden
I have a chevy 2500 hd when i turn turn the rear wheels skip and bark
Chances are the locking rear differential is staying locked up and causing the tires to chirp/bark.You can try to fix this by changing the rear axle grease and then driving i circles both left and right about 20 times.If it starts to get better then try it for awhile.If not the rear locking DIFFERENTIAL MAY NEED TO BE REBUILT.Some other possible things to check before you go
and teardown the rear axle are-different tire sizes in the rear,the vehicle is in 4wd.
Apr 13, 2011 | Chevrolet 2500 Cars & Trucks
Rear axle removal ? i want to take to replace two broken lug nut bolts
to remove the rear axle you will need to put the rear of the jimmy on jack stands off the ground and remove the wheels
then remove the rear drums or if you have disc brakes the caliper and rotor
next you will need to remove the rear differential cover
once you have removed the rear differential cover you will need to rotate the differential by just turning the rear axle to gain access to the lockbolt
using an 8 mm socket you should be able to fairly easily remove the lock bolt
once you have removed the lock bolt you will need to push the axle in from the side that the wheel gets mouted to and then in the rear differential remove the locking 'c' clip
once the locking 'c' clip is removed you should be able to pull the axle right out
installation is the reverse of the removal
keep in mind that after romoving the lock bolt you must make sure not to rotat the axle if you do you will mess up the allignment with the differential and axle and you will spend loads of time trying to re-allign it again
hope this helps
Aug 13, 2010 | 1996 GMC Jimmy
How to remove gears from differential on a 95 mustang v6
Removal
  1. Raise vehicle and place jackstands under rear frame crossmember. Lower the hoist so that rear axle housing is at suitable working height.
  1. Remove axle housing cover from rear axle housing and drain lubricant.
  1. Perform the inspection before disassembly.
  1. Remove rear wheels, rear disc brake calipers and rear disc brake rotors.
  2. Working through cover opening, remove differential pinion shaft lock pin and remove differential pinion shaft and differential pinion gears (4215). 3fdbe2c.gif
NOTE: THIS IS FREE INFORMATION!!!!
  1. Remove rear brake anti-lock sensor . Push axle shaft inward until u-washers at button end of the axle shaft are clear of side gear recess.
  1. stb~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not damage inner wheel bearing oil seals when removing axle shafts from rear axle housing. In addition, axle shafts should be completely removed from rear axle housing.
    Remove u-washers and pull axle shafts out of the rear axle housing. 85189ce.gif
Mar 25, 2010 | 1996 Ford Mustang
I want replace the rear axle bearings on my 1985 suburnban
locking differential jack up and support rear of truck drain and remove rear cover remove lock bolt than slide out pinion shaft have someone push in on axle and remove c-lock do 4 both axles w/c-locks out remove axles carefully pry off oil seals-will need bearing puller and installer most auto stores rent or let u borrow them- reinstall new bearings and oil seal carefully install axles not 2 damage new oil seals reinstall c-locks and pull back on axle to lock in place slide in pinion shaft reinstall locking bolt torque to 25 ft-lbs reinstall cover and fill with gear oil
Sep 26, 2009 | Chevrolet Suburban Cars & Trucks
Cj7 rear
Jeep Axle: AMC 20
Front Axles
Dana 44
Dana 30
Dana 27
Dana 25
Rear Axles
Chrysler 8.25"
Dana 35c
AMC 20
Dana 30
Dana 60
Dana 53
Dana 44
Timken
Dana 41
Dana 23
Jeep Axles
Upgrades
Factory Options
General
-->All AMC 20s have a 8 7/8" R&P and use a 29 spline shafts. The AMC 20 R&P is 3/8" bigger than the Dana 44, but it uses smaller shafts, smaller axle tubes, and the CJ version comes with weaker two piece shafts. The AMC20 uses a 29 spline shaft where as the later Dana 44 uses a 30 spline shaft. The AMC 20 housing tends to flex a lot which can cause breakage. This can be remedied by welding the tubes and/or adding gussets. The reason the AMC 20 flexes more than the Dana 44 is the shorter differential housing and smaller axle tubes. It's other flaw is the CJ version uses the two piece axle made up of a hub and a shaft. The hub end tends to break off under load which has created the market for one piece AMC 20 axle shafts. Unfortunately, the shafts are expensive ($350+ USD) and in some cases a special bearing must be used.
amc20co_.gif -->Identifying the gear ratio of an AMC 20 is a bit tricky. Dana axles normally have a tag on the left of the diff cover with the gear ratio at the time of build. The AMC axles have a code that has to be looked up in a table. The code is stamped on the housing boss to the left of the diff cover right near the axle tube. Good part about the stamp is it tends to stay readable longer than the tag, but you have to know the code. Since there are conflicts between what a code means for a narrow track and what it means for a wide track, don't count solely on the code to identify an axle. Bring a tape measure or know the source of the part. Specs Narrow Track AMC 20 Code Gear Ratio Diff Type AA 2.73 Open DD 2.73 Trac-Lok BB 3.31 Open CC 3.31 Trac-Lok A 3.54 Open N 3.54 Trac-Lok GG 3.73 Open Q 3.73 Trac-Lok L 4.10 Open M 4.10 Trac-Lok Wide Track AMC 20 Code Gear Ratio Diff Type D 2.73 Open DD 2.73 Trac-Lok B 3.31 Open BB 3.31 Trac-Lok A 3.54 Open AA 3.54 Trac-Lok H 3.73 Open HH 3.73 Trac-Lok C 4.10 Open CC 4.10 Trac-LokThe Trac-Lok is a limited slip differential. You may have to scrape away a lot of mud, paint, and rust to uncover the code. If you can't find the code on the rear, check the tag on the front axle. Both axles should be geared the same. The R&P ratio ranges supported by the carriers are 2.73 and 3.31-5.13. The 5.13 gear ratio is not available for the Dana 30 though, so it is rare to see it. 4.56s are the lowest common ratio between the Dana 30 and AMC 20. 5.13s are available for the Dana 44.
CJ AMC 20 The CJs used two versions of the AMC 20, the narrow track from '76-'81 and the wide track from '82-'86. Both versions use keyed, two piece shaft/hub design and 5 on 5.5" wheel bolt pattern. Supplies of AMC 20s were exhausted in 1986 and some Dana 44s were used instead in the last of the CJ-7s.
From 1976-1978 a larger 11x2" drum brakes was used on the AMC 20. After 1978, a 10x1.75" drum was used.
SJ AMC 20 The Wagoneer and full size Cherokee also used a narrow and wide track version of the AMC 20. Both SJ versions used once piece shafts and 6 on 5.5" wheel bolt pattern. Since the length and bolt pattern is different from the CJ version, the SJ shafts are not compatible without resplining and redrilling. I've never heard of anyone going to the trouble.
Model/Version Spring Pads Wheel to Wheel Years AMC 20/CJ Narrow Track 36" 50.5" '76-'81 AMC 20/CJ Wide Track 36" 54.5" '82-'86 AMC 20/SJ Narrow Track AMC 20/SJ Wide Track Last modified Friday, 03-Dec-1999 21:48:34 MST
[ Jeep Tech Main Page | Terry's Jeep Page ]
Copyright © 2001, 2000, 1999, 1998 JEEPTECH.COM
All Rights Reserved, All content with exception of private works and
corporate trademarked logos are property of Jeeptech.com
Jun 06, 2009 | 1985 Jeep CJ7
How do you remove right rear axle on a 2004 ford crown vic to replace seal on wheel?
Section 05-02A: Axle, Integral Carrier — 8.8-Inch Ring Gear 1994 Town Car, Crown Victoria/Grand Marquis. Workshop Manual REMOVAL AND INSTALLATION Axle Shaft NOTE: Whenever replacing the rear axle lubricant, use Rear Axle Lubricant XY-90-QL (ESP-M2C154-A) or equivalent.
Removal
sra~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: The rear brake anti-lock sensor must be removed before the axle shafts are removed. The rear brake anti-lock sensor is bolted on the rear disc brake caliper anchor plate.
  1. Raise vehicle to desired working height. Refer to Section 00-02 . Remove rear wheel (1007) and tire assembly. Remove rear disc brake calipers (2552) and rear disc brake rotors (2C026) .
  1. Clean all dirt from area of axle housing cover with a wire brush and/or cloth.
  1. Drain rear axle lubricant by removing the axle housing cover .
  1. Remove differential pinion shaft lock pin and differential pinion shaft .
  1. Push flanged end of the axle shafts toward the center of the vehicle and remove the rear axle shaft retaining u-washer from the button end of the axle shaft .
  1. Remove axle shaft from the rear axle housing , being careful not to damage the inner wheel bearing oil seal (1177) and rear brake anti-lock sensor ring.
Installation
NOTE: Check for presence of rear axle shaft o-ring (4A332) on the spline end of the shaft and install if not present.
sra~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Care must be taken not to let axle shaft splines damage oil seal or bearing assembly.
  1. Carefully slide axle shaft into rear axle housing without damaging rear wheel bearing (1225) or rear brake anti-lock sensor indicator (2C189) . Start splines into side gear and push firmly until the button end of axle shaft can be seen in the differential case .
  1. Install the rear axle shaft retaining u-washer on the button end of the axle shaft splines, then pull the shaft outboard until the shaft splines engage and the rear axle shaft retaining u-washer seats in the counterbore of the differential side gear .
  1. Position the differential pinion shaft through the differential case and differential pinion gears , aligning the hole in the differential pinion shaft with the lock bolt hole. Apply Rear Axle Lubricant to differential pinion shaft lock pin . Install differential pinion shaft lock pin and tighten to 20-41 Nm (15-30 lb-ft). sra~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Differential pinion shaft lock pin must be tightened to specification using Stud and Bearing Mount E0AZ-19554-BA (WSK-M2G349-A1) or equivalent.
    NOTE: Axle housing cover must be installed within 15 minutes of application of the silicone rubber or new silicone rubber must be applied.
    sra~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Make sure machined surfaces on both axle housing cover and rear axle housing are clean before installing the new silicone sealant. Inside of axle must be covered when cleaning the machined surface to prevent axle contamination. Tighten the cover bolts in a crosswise pattern to ensure uniform draw on axle housing cover .
  1. Apply Silicone Rubber D6AZ-19562-AA or BA (ESB-M4G92-A or ESE-M4G195-A) or equivalent. Install axle housing cover and tighten retaining bolts to 28-38 Nm (38-52 lb-ft).
  1. Add Motorcraft Rear Axle Lubricant XY-90-QL or KL (ESP-M2C154-A) or equivalent until it is 6-14mm (1/4-9/16 inch) below bottom of fill hole. Add 118.3 mL (4 oz) of Ford Additive Friction Modifier C8AZ-19B546-A (EST-M2C118-A) or equivalent to Traction-Lok axles. Install fill plug and tighten to 20-41 Nm (15-30 lb-ft).
  1. Install rear brake anti-lock sensor indicator . Tighten retaining bolt to 4.5-6.8 Nm (40-60 lb-in).
  1. Install rear disc brake caliper and rear disc brake rotor .
  1. Install wheels and tires.
  1. Insert Rear Bearing Remover T85L-1225-AH in bore and position it behind bearing so tangs on tool engage bearing outer race. Remove rear wheel bearing and inner wheel bearing oil seal as a unit, using Impact Slide Hammer T50T-100-A.
    Rear Disc Brake Caliper Anchor Plate
  1. Lubricate the rear wheel bearing with Rear Axle Lubricant.
  1. Install rear wheel bearing into the housing bore using Axle Tube Bearing Replacer T78P-1225-A.
    sra~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Installation of rear wheel bearing or inner wheel bearing oil seal assembly without proper tool may result in an early bearing or seal failure. If inner wheel bearing oil seal becomes cocked in bore during installation, remove it and install a new one.
  1. Install the inner wheel bearing oil seal using Axle Tube Seal Replacer T78P-1177-A. Use Premium Long-Life Grease XG-1-C or K (ESA-M1C75-B) or equivalent between the lips of the inner wheel bearing oil seal .
  1. Install axle shafts as outlined.
May 13, 2009 | 2004 Ford Crown Victoria
Bird Rear-end Size
Hi meduck4,heres what you need brother as I cant see your diff, 3 ways to tell what you have:
#1 The first is the driver's door tag; there will be a one-letter or one-numeral axle code listed there. You can then compare it to the chart below: CODE Rear Axle Ratio Conventional Locking 8 M 2.73 Y Z 3.08 F R 3.45 5 E 3.27 6 W 3.73
#2 The second is the axle tag, attached to the lower lefthand bolt on the rear axle itself. The bottom left line will give you the gear ratio, and the type of rear end (S for limited slip non-locking, and L for locking).
#3 The 7.5" rear axle height is shorter than the width and the shape appears "oval".
The 8.8" rear axle
dimensions are equal and the shape appears "round".
This will tell you what you have my friend,good luck
Nov 13, 2008 | 1985 Ford Thunderbird
Garden Logo
23 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
