Question about Dishwashers
No hot water heater reads ok checked pressur switches ok. is it possable to get a circuit dia
    Brigadier General:
  • 3,917 Answers
Check the voltage at the water heater. Sounds like the element is burnt out and is tripping the breaker.
If it is more then 5 years old I would check.install a new heating element.
Would also suggest you a answer is to drain the tank and remove it to inspect. Could also be a anode rod peice broke apart and is in contact with the element.
Also check the switch/thermostat. Could be grounded? long shot but don;t have to drain to check
Please find the links bellow which would help you understand the issue:
homerepair.about.com/.../ss/hwh_tank_gas.htm
or
http://home.howstuffworks.com/how-to-repair-a-dishwasher.htm
OR
www.neuservice.co.nz/Help.html
or
www.independentinspectors.org/newsletter2-spr...
Thank You
Posted on May 21, 2009
I discovered Whirlpool hot water heater was displaying E02 error code. Followed directions in manual to possibly correct problem, but E02 code continued to be displayed. What is the remedy for this?
Error E02 indicates that the water temperature exceeded high limit.
Switch off the house circuit breakers dedicated to the water heater and then press the reset button located behind the control panel on the water heater.
Switch house circuit breakers back on.
If error persists, call a service engineer.
good luck
Jan 05, 2018 | Whirlpool Water Heaters
I have a vita spa hot tub i've replaced the circuit board,heater, preasure switch,check the pump reset the top board but keep getting a flashing flo error and will not heat up.Tested current have 115
I believe with some of manufacturers spas, Vita included, the error will occur if the system is reading that the pressure switch has a "CLOSED" circuit. Bypassing the pressure switch, will still be creating this! What this means to the system: The circuit board does a quick system check. If the board says to itself: "Why does the pressure switch tell me the water is flowing (thats what happens when the pump is on and moves water; pressure is created in the plumbing and the switch then closes) when I haven't even sent power to the pump yet?" Then it will send the error message.
Your switch may need to be calibrated to only close when there is water flowing, and then open within a second of the pump or water flow stopping.
Oct 30, 2014 | Pool & Spa
Dishwasher not finishing cycle
A10 4 + 6 Heating circuit Heating element, connections, module,
relay, pressure switch
A10 Open circuit in heating circuit.
• Check the circuit of the heating element (26 ohms).
• Check for an open circuit heater cut-out.
• Check pressure switch open circuit (connections 11-14).
• Check wiring and connections between module card, pressure switch and heater.
• If all above is OK, replace module card.
Sep 18, 2014 | Hotpoint 24 in. FDW60 Free-standing...
Hi there i carnt get miy heater to come on and filter sysyum , bought new pump and curcit board but still same could u help
First make sure that the Pump runs, if water does not flow thru the heater assembly, the heater will not turn on..., else the water would super-heat. If water is flowing thru the heater assembly, check your output from your thermostat if it is working. If not replace thermostat. If it is ok, then check to see if Pressure switch is working by using a meter and see that it is open circuit when the spa is off and a closed circuit when the pumping water. If not, then you may be able to adjust your pressure switch if it has that capability. If not, replace pressure switch. If however, the pressure switch is ok, then you should test the voltage at the heaters element. If there is voltage, then you need a new heater element. If not, then I need a more detailed description of the problem.
Hope this helps,
Dan Osko
Osko Pool n Spa
http://www.oskopoolnspa.com
May 12, 2014 | Pool & Spa
Vailant ecotec plus 837 - Water pressure and temp is too high
Pressure inside the tank will rise along with the water temperature. As the water inside cools the pressure will wane until the heating element turns on and reheats the water with a subsequent rise in pressure. Running the hot water at the same time will draw heat energy from the boiler and lower the internal temp and pressure as well.
Jan 21, 2014 | Water Heaters
I have an ariston 20/24 mffi combi pressure rises when switched to central heating but pressure ok when asking for hot water ? expansion vessel ?
over heat limit stat on central heating circuit ? if hot water is ok and hot to temp when run for 5 minutes the expansion vessel is doing its job.remember hot water is the maximum demand for any boiler ,,heating is secondry?once you establish hot water at maximum rate then the only real problem is on you demand for heating??
Dec 10, 2012 | Water Heaters
Water heater gives out cold water for about 30sec then goes back hot
Pressure is not enough to operate pressure switch due to the several problems.
It needs to open it up and check if diaphram or similar device that operates switch is intact. If the mechanism is ok, than check the water inlet for obstruction or dirt (if there is a filter clean it) same goes for the outlet.
Jul 08, 2009 | Rinnai Water Heaters
Dishwashers Logo
27 people viewed this question
Top Dishwashers Experts
