Question about Samsung S6800 GALAXY ACE ADVANCE QUADBAND UNLOCKED GSM PHONE: BLACK
Ockown error if i upgrade
I whant to upgrade my firmwere but gifs a error
Canon ir 2016j display "download standby"
thats a comon problem, u just change mfc bord or upgrade your firmwere using service support tool
Dec 12, 2013 | Office Equipment & Supplies
49,2f9d how to slove this problem this is hardware problem or softwware problem
This is a firmwere error for firmwere go www.hp.com/support/ljp3005 for letest firmwere download & install.
If problem persists then replace the formatter card.
thanks.
Sep 25, 2010 | HP LaserJet P3005 Printer
Error code 81.0180 eio 1
upgrade the firmwere of jet direct card your problem will be resolved
Aug 31, 2010 | HP LaserJet P3005D Monochrome Laser 35...
I'm upgrading firmware of the 3com 7760. I'm get from 3com.com and i download a file .img, but in the 3com web interface say "Please Input Address Path for Upload". I selected the file .img. Excuse me...
i know this was from a while ago but 3com 7760's have a problem when uploading it files either firmwere or setting backup files you have to use internet explorer or you will get the "please input address path" error
Aug 04, 2010 | 3Com 7760 (3CRWE776075US) 802.11a/b/g...
Problems printing excel worksheet, does not acknowledge the worksheet, printing icon shows up at bottom but indicates 0 jobs pending
hi....this problem due to your formater card upgrade the firmwere of your printer by taking the test page you will be find there current firmwere verson then go to hp web site & find the upgrade firmwere there & install.it is the known issue of this printer if problem persists pls contact hp
Jul 01, 2010 | HP LASERJET P1005 Printer
Not connecting
reset the router and then upgrade the firmwere.
-tg
Jan 08, 2009 | Linksys Wireless-G WRT54G Router
Error (-48)
Error(-48) is somekind of hardware communication error. The easiest way to fix it will be to flash the firmware. Here's how to do it.. It will take a while(around half an hour) but its worth it and will also improve the sound clarity of your phone.
What u need :
1) Motorola Driver
2) RSD Lite or Flash&Backup 3
3) Monster Pack(Flash update for(Lseries including SLVR)
Firstly you need to backup all your files that stored on phone memory because it will delete everything in your phone when you flashing.
Start RSD Lite and let it connect to your phone. If your phone is not detected (and you are certain you have everything installed), disconnect the data cable, then shut your phone off, and manually put it into bootloader mode. You do this by pressing and holding down the "*" and "#" keys while pressing and holding down the on button until you see text display on your screen. Now connect the phone back to the data cable. Now click the button labeled "...".
http://www.hackthel7.com/gif/flash1.gif
This will bring up the open file dialog box. Find the file you want to use (in this case select your monster pack file) and then click the button labeled "Open".
http://www.hackthel7.com/gif/flash2.gif
Click the "Start" button. Now you should see various messages displayed on the screen as the program processes each code group and does various other things.
http://www.hackthel7.com/gif/flash3.gif
This is what the phone will display during a flash:
http://www.hackthel7.com/jpg/upgrade.jpg
After it's finished and your phone has given you a confirmation tone, you can click "Close" and disconnect your phone from the cable and check out your changes.
If you should get a message like this where the program seems to hang:
http://www.hackthel7.com/gif/flashstuck.gif
OR
http://www.hackthel7.com/gif/flash4.gif
Don't panic. Just close the program, chance are your phone is just fine. Sometimes this happens. This is usually caused by a checksum error. There could be more serious cases where you phone appears dead. In this case try to reflash your file again. You could also try reflashing another file.
Sep 30, 2008 | Motorola Mobility SLVR L7 Cellular Phone
Netgear SC101 Firmwere failed upload
Check your password, when i first did it I used what i thought was my password and the password check passed but i couldn't do a manual or automatic update. I retried with the system default password and the automatic update worked.
Oct 06, 2007 | NetGear SC101 (SC101500) 250 GB Network...
Samsung S6800 GALAXY ACE ADVANCE QUADBAND UNLOCKED GSM PHONE: BLACK Logo
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
