Question about Stairmaster Stepmill 7000 Pt
Level starts at 19 - Stairmaster Stepmill 7000 Pt
  • Stairmaster Master
  • 914 Answers
About This Video
This video covers the electronic troubleshooting for a complaint of No Resistance on the Stairmaster Stepmill 916. Tools Needed: Multi Meter, Assistant for Testing Purposes
It is necessary to begin by removing the user's right side cover to gain access to lower control board and alternator for testing purposes.
  • Using your multi meter on the volts setting, you will place your black meter lead to the Ground test point on the lower board and place your red meter lead into the back of the cable connector where the brown wire is located. Have your assistant step onto the steps. Voltage should be present. If no voltage is present, check all cables. If cables check out, the console should be replaced. If voltage was present, it is time to move to the next test point.
  • Place your black meter lead to the Ground test point and the red meter lead to the Tach test point. Have your assistant step onto the steps. Voltage should be present. If no voltage is present, the alternator brushes should be replaced. If voltage was present, it is time to move to the next test point.
  • Next component to test for a no resistance issue is the load resistor. You will be testing for .5 -.7 ohms. Place the red meter lead to the white wire connected to the load resistor and the black meter lead to the black wire. If the proper value is not found when the load resistor is tested, it should be replaced.
You have now tested the entire electrical circuit. If the problem still exists, you have a mechanical failure or you should verify the results of your testing.
Posted on Jul 29, 2014
03 Mazda MPV fuel gauge drops when parked facing downhill & takes time to correct once level. Is this a known issue & is there a fix?
MPVClub.com :: View topic - p1455 & fuel gauge is intermittent on ...
forum.mpvclub.com/viewtopic.php?t=27060
Jul 19, 2012 - 8 posts - ‎4 authors ... on (P1455) and right around that time the fuel gauge started dropping quickly. The code refers to the fuel tank level sensor circuit but the MPV still ... Joined: 03 Jun 2003... Locate the fuel pump fuse in the fusebox under the driver side kick panel. .... also there are other genuine mazda parts discounters.
Sep 01, 2015 | Mazda Cars & Trucks
19 11`761`238
Bio-cone-tics use logarithms on a mathematical level to ensure no room for error. hope this clears it up for you.
Oct 19, 2013 | Cars & Trucks
Hanna hanna clue famous people starts with r
Hello i dont know any hanna hannas but if your playing clue pics on level 19 the answer is Rihanna :)
Aug 12, 2013 | Office Equipment & Supplies
GAME WILL NOT ADVANCE TO NEXT LEVEL
I am getting EXACTLY the same problem. I have tried everything to fix it :(
Apr 01, 2013 | Zynga Cafe World
My kids were on level 19 on the smurfs game. they tell me, suddenly gargamel's picture appeared, and there was a message from papa smurf that gargamel found the village and that the smurfs have all run...
I have the same problem. Only the upper-part of my village is left, and little roads are left. Everything else is gone. I am still in level 24. Gargamel appeared, and it was like all starting over again... I just have 5 smurfs left.
Mar 22, 2011 | Smurf Village Send Smurfs
Is water hardness set at 19 softer or harder than water set at hardness level 25?
Water hardness set at 19 would be softer than 25...expressed as gpg or Grains Per Gallon
Nov 01, 2010 | NRS Fleck 5600 - 64,000 Grain Timer Water...
How to replace a thermostat 1996 mazda mellinia
Thermostat - REMOVAL & INSTALLATION
CAUTION When draining the coolant, keep in mind that cats and dogs are attracted by the ethylene glycol antifreeze, and are quite likely to drink any that is left in an uncovered container or in puddles on the ground. This will prove fatal in sufficient quantity. Always drain the coolant into a sealable container. Coolant should be reused unless it is contaminated or several years old.
1.5L, 1.6L, 1.8L (except K8) and 2.2L Engines
  1. Disconnect the negative battery cable. Drain the radiator to below the level of the thermostat.
  2. If necessary, remove the air cleaner assembly.
  3. If necessary, disconnect the coolant temperature switch at the thermostat housing.
  1. Remove the upper radiator hose.
  2. Remove the mounting nuts, thermostat housing, thermostat and gasket.
Do not pry the housing off.
To install:
  1. Clean the thermostat housing and the cylinder head mating surfaces.
  2. Insert the thermostat into the rear cylinder head housing with the jiggle pin at the top. The spring side of the thermostat should face the housing.
  3. Position a new gasket onto the studs with the seal print side facing the rear cylinder housing.
  4. Install the thermostat housing and 2 nuts. Tighten the nuts to 14-22 ft. lbs. (19-5 Nm).
  5. Install the upper radiator hose.
  6. If detached, connect the coolant temperature switch.
  7. If removed, install the air cleaner housing.
  8. Fill the cooling system. Connect the negative battery cable, start the engine and check for leaks. Check the coolant level and add coolant, as necessary.
2.0L Engine
See Figures 3, 4, 5, 6, 7, 8, 9 and 10
  2. Drain the engine coolant from the radiator to below the level of the thermostat.
  1. Disconnect the lower radiator hose from the engine.
  2. Remove the housing bolts, thermostat housing, thermostat and gasket.
To install:
  2. Make sure that the thermostat jiggle pin is aligned with the gasket projection.
  3. Install the thermostat to the housing. Align the gasket projection with the opening in the housing. The spring side of the thermostat should face into the housing.
  4. Install the thermostat housing cover and tighten both bolts to 14-19 ft. lbs. (19-25 Nm).
  5. Fill the cooling system. Connect the negative battery cable, start the engine and check for leaks. Check the coolant level and add coolant, as necessary.
Hope helps (remember rated this).
Jul 08, 2010 | 1996 Mazda Millenia
What is the oil capacity of a Kohler Courage 19 engine with filter change and how do I reset the hour meter to let it know that I changed the oil?
all models are diffrent start by pouring 1 quart of oil in and check the level on dipstick if it is at the full level start the machine let it run 30 seconds and shut it off and let it set for 1 minute then check the oil. add as needed. as far as i know there is no way to reset the hour meter. thanks jd
Sep 18, 2009 | Mtd Garden
Have a 19 hp john deere zero turn riding mower. starts up, blades turn, has oil. will not move forward or backward. does the hydrolic oil level have anything to do with that?
ck on traction motors for lever or nut to release fluid. Can you move mower with engine off?
If so, this is your what is wrong traction motors
are disengage
Aug 30, 2009 | Garden
Cant get through level 19 on ds lite game escape(42game)
hi
been looking for this game no one has any cheats etc but i found this may help you out
Welcome to My Site
hope this help you.
riz.
Mar 22, 2009 | Nintendo DS Lite
Stairmaster Stepmill 7000 Pt Logo
118 people viewed this question
Top Stairmaster Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
Matt Olenzek
Matt Olenzek
zr800o1le
zr800o1le
Level 1 Expert
Are you a Stairmaster Exercise and Fitnes Expert? Answer questions, earn points and help others
