Question about Dryers
Brown Burn Stains and little holes from FRIGIDARE GALLERY HEAVY DUTY STACKABLE DRYER
Also dryer drum makes scratching noises
    New Friend:
  • 51 Answers
If you are using LP gas make sure the dryer is set to LP on the regulator. If a natural gas dryer is run on LP you will get way to much flame.
Posted on Jan 06, 2014
SOURCE: Frigidaire Gallery Heavy Duty Front Load Dryer problem
it's probably the nylon bushings that the drum rides on. they wear out and the drum rides directly on the pad that the bushings attach to.
Posted on Sep 02, 2008
  • 58 Answers
SOURCE: Dryer Won't Start
try to turn the drum by hand
Posted on Mar 12, 2008
jumptrout51
  • 3361 Answers
SOURCE: Burn marks on clothing
The front felt drum seal may be bad. It is attached to the front panel, around the door.
Check and or replace the rear drum support it has worn down the ball and cup support. It will soon begin making a grinding/squealing noise.
When it wears and drops down the gap is greater at the front around the felt seal. Laundry gets caught in the gap and scorches.
Posted on Apr 20, 2009
SOURCE: clothes dryer squeaks when running
Fixing Frigidaire model # FER641FSO, not stacking, but had similar problem. turnsout one of the coils came off. might try that...
Posted on Jun 10, 2009
hunter19_46m
  • 7482 Answers
SOURCE: my dryer makes a scraping noise when the bowl
UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
You may have two problems:
1...The felt seal around the door is faulty,broken, or out of place.This will cause the problem of zippers,buttons, etc. to get caught between the door and the drum
2...Drum rollers, this causes squeaks,and thump type of noises.
Your problem sounds like drum rollers have flat spots on them or in need of lubrication and the felt seal between the door and drum maybe faulty.
If you have a front loading machine,
Remove the electrical box that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt,and felt seal.
Check your felt seal at this time to see if you can reinstall it or you may have to replace it.
Remove the drum and belt and this will expose the drum rollers.
Check your rollers for flat spots, if they have flat spots on them replace them.
If they don't then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise and the problem of getting clothes caught in between the door and drum.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good Luck,
I hope this helps
Posted on Oct 29, 2009
My Frigidaire Gallery dryer squeaks and leaves brown crescent burn marks on our laundry items.
If you live in Pasadena, CA and you need a Dryer repair service our professional technicians will perfectly repair your dryer as fast as possible. All you need to do is to call at (626) 460-0903 or visit our website http://www.appliancerepairspasadena.com .
Dryer repair Pasadena CA Bosch LG Electronics Amana Beko
Sep 02, 2017 | Frigidaire Gallery Series GLHS269ZDB 36"...
I have a stackable kenmore washer dryer heavy duty extra large capacity 2 speed motor. The dryer has been making squeeling noise and has stopped toumbling around what can the problem be.
Could be the belt which connects motor and dryer drum. Could be the drum support rollers. Replace both either way -- common problem.
Jun 03, 2011 | Kenmore Dryers
We have a frigidaire gallery, heavy duty, stackable washer dryer. The dryer has stopped spinning. No grinding or anthing just not moving. Belt?
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Dec 22, 2010 | Dryers
I have a Frigidaire Gallery Stackable that has a screechy dryer
Sounds like it is worn out. Get a parts diagram and take it apart and see what parts are missing or worn out. The belt is probably coming apart and that is the black stuff. There are several plastic wear plates and a bearing/bushing for the drum, plus the belt idler and all these can wear out. The motor could also have a bad bushing in it but more than likely that will require a new motor as they don't usually sell just the bushing or end caps.
Sep 03, 2009 | Frigidaire FEX831CS Top Load Stacked...
Sounds like the bearing is gone, call a repiar man or buy new as repairman 100 per call
Sep 03, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
The clothes get stained with brown burn marks while in the dryer.
The rear drum support needs replacing.
The front glides and felt seal needs replacing.
May 25, 2009 | Frigidaire FLEB8200DS Top Load Stacked...
Apr 20, 2009 | Dryers
Frigidaire combo washer/dryer screws inside come off
The drum shaft came loose from drum. You can YouTube it for procedure of disassembly of dryer. Remount shaft, if screws are bad may need new shaft with screws, make sure it is tight to drum. While you have it apart you can clean out lint.
Sep 27, 2017 | Frigidaire GLER331A Electric Dryer
GE DSXH436V1WW heavy duty large cloths get caught
This dryer doesn't have rollers at the front of the drum, it uses a felt rub strip between the drum and the front cover. You'll need to replace the rub strip. It's easy to do but you'll need to get the special high-temp adhesive.
Feb 24, 2009 | Dryers
Aug 31, 2008 | Frigidaire GLEQ2152ES Electric Dryer
Dryers Logo
63 people viewed this question
Top Dryers Experts
