Question about Hitachi Televison & Video
Startup problem Hitachi 32LD30U
Hi Guys. I have a 32" hitachi LD30U tv which ive had for around 4 years. When i switch the TV on the screen distorts between a scrambled blue screen and a normal screen. Kind of flickering. After around 10 to 15 minutes this stops and the tv works fine and is fully functional. Not sure if it`s on the way out. I`m hoping there is a simple solution which i`m overlooking. Any help would be greatly appreciated. Tom
    Top Expert:
  • Hitachi Master
  • 74,198 Answers
It sounds that the main power regulator board has the fault. Try by replacing the electrolytic capacitors there. These capacitors can deteriorate its value with time. As the set is about 4 years old, this might be the fault. If it do not help you, replace the power regulator board as card basis. If you wish to get some details, check the site linked here. http://electronicshelponline.blogspot.com/Pull up older posts. Check the site in 'Mosaic' view.It will make search easy.
Posted on Jan 03, 2014
4 Suggested Answers
SOURCE: Hitachi 32LD6600 - When the
Hi i have this tv and last night the screen went black i can hear sound ok but no picture just a black screen, Also i can see dark
outlines /shadows of whats on the tv, can you tell me please what has caused this
Posted on Apr 21, 2008
falter
  • 245 Answers
SOURCE: Hitachi 32'' lcd tv picture runs slow sometime and goes dark
go in touch wit HITACHI costumer help and service and tell them ur problem u have.....how old is ur TV?
hope u get a answer from hitachi....and good luck
Posted on Mar 12, 2009
SOURCE: Problem with Hitachi P50H401 Plasma TV - Will not
I have the same model, P50H401 and it developed the same problem two days ago. This set is 2 1/2 years old in service, being purchased in December 2007. The original manufacture date was October 2007.
The set was turned on and operating at the time and then promptly shut down by itself. The front blue LED power indicator began flashing four times in a loop or cycle.
The flashing LED sequence in this instance points to a problem with one of the following boards: PSU, X-Sus, Y-Sus or SDRs (there are two SDR boards, SDR-U and SDR-D, both are connected off of the Y-Sus board on the left hand side of the frame when rear facing). The set shuts down to prevent further damage to other boards or components.
I could power cycle the set but it would shut down after after a few seconds. Power LED would stay solid, I could hear the PS relays switching, and audio would output through the speakers. Then as the screen was just about to illuminate, the entire set would just shutdown. The blue LED would again go into the 4X flashing sequence.
I could not visually detect any signs of severe component damage on the main PS board. The two large electrolytic capacitors which have been mentioned as problematic in other threads seems fine. The where slightly raised on the top surface, but not blistered or completely blown open.
The only indication of component damage that I could detect visually was on one of the small surface mounted ICs on the SDR-U board.
Through reading other posts on this site, I learned that I was able to remove the suspect SDR-U board and then re-power the set. Doing this proved that the PS, X and Y Sus, and the SDR-D boards where o.k. The PS held, and the lower half of the screen illuminated. (I would only do this for as brief a period as required to determine if the the other boards would function and the screen would illuminate. Do not pro-long operation in this state so as to not cause further damage.)
It was somewhat difficult to locate the correct SDR-U board. My local service rep did not have one in stock, and the Canadian parts distributor was also out of stock. They estimated 10 - 14 business days to order one up from the U.S.A. (Hitachi closed their consumer electronics division in Canada back in 2009.)
By chance, I checked with another service rep in an adjacent town. He had a board for the P55. We did a visual comparison on the two boards and determined that it would be compatable.
The easy part was removing the defective SDR-U board and installing the replacement. The hard part was re-alinging the three ribbon tabs into the respective connectors on the SDR board. Be careful with these ribbons. The other end of each is fused to the plasma panel screen, so if you damage them, your screen is rendered useless.
I initially had the same problems as others have posted with having black or gray lines on the screen when the SDR-U was replaced. After gently adjusting the position of the ribbons as they are seated in the connectors, the lines disappeared. This was a slow and frustrating procedure, but it worked, Be patient.
Posted on Jul 03, 2010
Looking for tv manaul for my 32 in hitachi tv CLU-4591AV
I lost my TV manual when I moved last year so I went on to a website called Buyspares and I was able to buy a replacement one, you may find the below link helpful
http://www.buyspares.co.uk/tv-projector/hitachi/catalogue.pl path=492589:497749,112858:492631&l=C
Good Luck.
Mar 02, 2011 | Hitachi Televison & Video
Loss of some channels on 32LD30U B
Weak digital signal. Either antenna or tuner.
May 03, 2010 | Televison & Video
Hi I have a hitachi 50 inch projection tv and
there is no tube in a projection tv it will be the conversion chips if picture colours aer distorted
Dec 12, 2009 | Hitachi 51F59 51" HDTV Projection...
I conect my laptop to my hitachi lcd 32ld30u b
Your laptop probably has the option to display:
* laptop screen only
* external screen only
* both screens
If your laptop has a key (usually BLUE) labelled FN,
check the other keys that also have BLUE labelling.
Hold down FN, and press the appropriate other BLUE key,
to cycle through the above 3 output options.
Oct 08, 2009 | Nikada Televison & Video
Red and Blue color bowing...
Hi, you`ve lost your convergence IC`s, At our shop here in western florida this runs right around $246.00, price will depend on your geographical location and who you call. gl, video-tek
May 29, 2009 | Hitachi 50FX30B 50" Rear Projection...
Hitachi C50-FD2000 Screen Distorted
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs. To get fixed either call in a local TV repair company or goto sites such as Tv Repair Kits to get a repair kit with instructions. Here is there link.
http://www.tvrepairkits.com/xcart/home.php?partner=papa1dude
They have put together complete kits for most models that include the parts, step by step photo instructions, repair assistance, etc.
Jan 02, 2009 | Hitachi C50F200 50 in. Rear Projection...
Green picture and distorted
Mar 11, 2008 | Hitachi 42V710 42" Rear Projection HDTV
Hitachi 43FDX01B (convergence) problem
hi i have same prob iv bin told its a convergence chip an thay r £150 ! thay go bout evry 6 years an its comon .. any way there coming 2 fix mine 2day so ill let u know if it sorts it out my mail is mjoutlaw@hotmail.co.uk thanx
Jan 30, 2008 | Hitachi 51F500 51" Rear Projection...
Pink Screen
There is a service bulletin for this problem - you need to reintialize the memory settings in the service menu - I have a pdf file showing how to do this.
Sep 09, 2007 | Hitachi 50V500 50 in. HD-Ready LCD...
43fdx01 hitachi
possible convergence overdrive from the IC's. This will cause the symptom you describe. ....accordianman
Jul 17, 2006 | Hitachi 43FDX01B TV
Televison & Video Logo
67 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
