Question about Creda Ovens
No gas coming through
We have a Creda double oven second hand but hardly used. When the gas supply is connected, the ignition wont work, and no gas comes through the oven. The fan however works. When the gas is disconnected, the ignition works. We dont understand, we have set the clock to manual, and done everything as we should have, any suggestions would be really appreciated.
  • 6,784 Answers
Hi. you will need to replace two devices. you will need ot replace the ignitor and you will also need to replace the coil assembly that is located on the burner assembly. these two devices are faulty and, this is causing the interruption you are experiencing.
The coils actually control the gas valves. they provide the resistance that initiates the opening and closing of the valves and, the ignitor ignites the flame.
Posted on May 21, 2009
  • Steven Baguley
    Steven Baguley Nov 26, 2013
    i have a Creda Gainsborough gas oven, the grill ignites fine but the ignition just keeps on sparking once the gas is lite, any ideas
Where do i find batteries for ignition in my creda expression l152g gas cooker ?
Not normally batteries, most are mains powered, but your is a single AA battery. The manual states;
The battery is not covered by the guarantee. Use an alkaline AA battery. The battery holder is located in the plinth panel below the oven door. Open the oven door fully. Press the tag on the left hand side of the battery holder/cover and withdraw it just enough to get access to the battery. Fit the new battery with the end marked "+" on the same side of the battery holder as the red lead. Replace the battery holder by pushing it firmly into the hole in the plinth.
The spark unit is usually under the hob on the left side. Check the connections as they can get really messy and even break through. Also spray the igniter posts with oven cleaner and leave for an hour, clean off with a plastic brush and water. Dry thoroughly. On the hobs, remove the burner and wash them, the underside as well as they rely on the earthing through the aluminium ring, remove and clean that too.
http://imagebank.indesitcompany.co.uk/brochures_online/pdf/Creda/Cooking/HBC150GG.pdf
Feb 17, 2018 | Creda Ovens
No flame
when this happens it is usually because of a faulty flame/gas safety valve.
Sep 08, 2008 | Amana AOGD2750 Gas Double Oven
Creda Solarplus (48906) top oven and grill not working
Electric stoves do not have pilot lights or igniters it could be the power control board has failed .
Mar 12, 2016 | Creda Ovens
Oven igniter works but oven doesnt lite. Strong smell of gas also. Stovetop works fine. Whats wrong!!!?
replace the ignitor,even though trhe ignitor glows orange its getting weak and cant pas enough current to open the gas valve to supply enough gas to fire the venturi tube,so it supplies gas but wont ignite this is where your odor is coming from
Jan 06, 2013 | Ovens
Creda Capri Oven - Ignition
I downloaded the manual from http://www.manualsmania.com and here is the section on replacing the battery:
Use an alkaline AA battery.The battery holder is located in the plinth panel below the oven door.Open the oven door fully. Press the tag on the left hand side of the battery holder/cover and withdraw it just enough to get access to thebattery. Fit the new battery with the end marked "+" on the same side ofthe battery holder as the red lead. Replace the battery holder by pushingit firmly into the hole in the plinth.
Jun 03, 2010 | Ovens
Oven wont lite. top pilots all ignite
oven ifnitor has failed / remove bottom of oven to replace. not a hard job.. ignitor cost 49 to 70.00 depending on model best to use a maytag flat style . this will cost you less.. mm hope this will help you mm
Dec 06, 2009 | Magic Chef 9112 Gas Double Oven
Maytag gas oven wont restart after pre heat
you have a bad oven sensor /faulty connection or bad control board.look for probe coming thru inside rear wall.should read 11k ohms cold.go bad a lot part number Hope this helps ,please rate my response :)
12001655
Jun 25, 2009 | Maytag 24" Built-In Single Gas Wall Oven -...
Oven not working
main oven not heating in my creda
Aug 11, 2008 | Ovens
Creda convection oven wont heat up
my ge profile double electric oven, bottome convection wont heat up
Feb 19, 2008 | Ovens
Ovens Logo
170 people viewed this question
Top Creda Ovens Experts
ashburton
Craig Butler
Craig Butler
Pcm2048
Are you a Creda Oven Expert? Answer questions, earn points and help others
